Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
Thread Tools
Old 08-08-2002, 10:32 PM   #1
psychotic
Olathe, KS
psychotic's Avatar
RIP: '02 V8 Limited 4WD
Vehicle Specs
A way for FIPK to draw cool air?
I've read many 'free' mods about people connecting a dryer hose to a hole they've drilled in their air box to get much much more power. Is there a way to get my FIPK intake cool air? I like the dryer hose idea, but would i have to make my own airbox around the cone filter to keep it from pulling hot air in from the engine bay??? any ideas or anyone who has done somethin like this???
psychotic is offline
Sponsored Links (Less Ads)
Old 08-08-2002, 10:49 PM   #2
aldive
Sarasota, Florida
aldive's Avatar
1999 XLT
Vehicle Specs
What do you expect the temperature difference ( over ambient ) will be?
__________________
Al Franklin
My truck
My Quest for 30
aldive is offline
Old 08-09-2002, 01:00 AM   #3
psychotic
Olathe, KS
psychotic's Avatar
Vehicle Specs
I really have no clue what the temperature difference will be.... i'm guess it will depend on if someone can think of a way to get the filter to draw in the air coming from the dryer hose as opposed to drawing most in from the engine bay. Does anyone have ideas?
Old 08-09-2002, 01:23 AM   #4
Hartman
From lowered to lifted
Indianapolis, IN
Hartman's Avatar
'95 4WD
Vehicle Specs
I thought about doing this. Problem is, will the air even have enough momentum to flow up the hose and into the intake?
__________________
32x11.5x15 BFG A/Ts, TT/shackles.
college = no money for mods.
Hartman is offline
Old 08-09-2002, 01:31 AM   #5
Alec
Mod Emeritus
Houston, Texas
Alec's Avatar
2008 JK
Vehicle Specs
Using one of the code scanners that can read sensors:
after adding a custom aluminum heat shield to block header heat and and adding some dryer hose, my intake temps are about 5-10 degrees cooler than before when above 35 mph. now once I'm moving, intake air temps are about 5-12 degrees above ambient.
__________________
Alec "Dr. Candlepower" Rosenbaum
Daily: 2008 JK
Gone: EE "Splat", 2003 VW GTI VR6, 85 Bronco project
Alec is offline
Old 08-09-2002, 01:34 AM   #6
psychotic
Olathe, KS
psychotic's Avatar
Vehicle Specs
Hmm, as i see it, the air won't need momentum to move up the dryer hose, am i wrong?
Old 08-09-2002, 01:38 AM   #7
Alec
Mod Emeritus
Houston, Texas
Alec's Avatar
2008 JK
Vehicle Specs
depends on how you do it. if you rig up the dryer hose so it firmly contacts the air filter (or a sealed airbox), the hose should create suction when the motor needs air. I on the other hand, just routed my hoses so they're "near" the air filter. I sometimes go through deep water and live in a wet climate, so I don't want any suction from below the filter. Above about 30-35 mph, the air has enough force to flow up through the hoses. Below that it doesn't do anything.
It's nice to be able to go through water over 3' deep
__________________
Daily: 2008 JK
Alec is offline
Old 08-09-2002, 01:49 AM   #8
psychotic
Olathe, KS
psychotic's Avatar
Vehicle Specs
so lets say i had like a large heat shield over my fipk, and a few dryer hoses coming from it... they would create suction? and this shouldn't be a problem street driving, because there would be no water to suck up into the filter?
(this is what i was planning to do, i'm just not smart enough to figure out how to do it myself)
Old 08-09-2002, 03:51 PM   #9
Rhett
Let Them Eat Cake
Cape Girardeau, MO
Rhett's Avatar
94 Sport 4x4
Vehicle Specs
Alec, how did you mount your aluminum heat shield?
__________________
94 Sport 4x4; EA cone filter; Granitelli MAF; BBK 66mm TB; Jacobs wires; Magnaflow w/2.5" pipe; Rancho RS9000; EE sways; Apten dual-program chip; Visteon Super-Cool radiator; BFG 30 x 9.50's; AMSOIL throughout; etc. etc.
Rhett is offline
Old 08-09-2002, 04:17 PM   #10
Jason_25
ECX Member
New Bern, NC
Jason_25's Avatar
'95 Explorer "Expedition"
Vehicle Specs
Alec, do you have any current pictures of your intake? I'm very interested.
__________________
1995 Explorer "Expedition" 4.0 4x4
1987 Bronco II XLT 2.9 4x4
1988 Bronco II XLT 2.9 4x2
1997 Explorer XLT 5.0 4x2
My Truck
Jason_25 is offline
Old 08-09-2002, 06:15 PM   #11
Alec
Mod Emeritus
Houston, Texas
Alec's Avatar
2008 JK
Vehicle Specs
sorry, no current pics. I tried, but even to my trained eye it came out like looking at a pile of junk (which is what it is )
the al heat shield is just an aluminum sheet that's bent a bit into place with a few self-tapping screws in it to secure it. it goes from the 'floor' where the air filter is up to the bottom of the mas. up top, a strap that's screwed into the sheet runs under a hose clamp on the intake tube to secure it up there.
the dryer hose: one length extends from the opening of the stock air scoop to behind the bumper with a little scoop on it. another length starts in the front 'mouth' opening of the bumper, runs up behind the headlight, and exits to the front of the air filter.
with the shield i noticed the motor bogged a bit less in city driving. with the hose, i noticed a bit more throttle response on the highway.
__________________
Daily: 2008 JK
Alec is offline
Old 08-09-2002, 06:57 PM   #12
psychotic
Olathe, KS
psychotic's Avatar
Vehicle Specs
Hey guys, i just picked up some aluminum flashing and a 4 inch aluminum dryer hose. Sucking up water is no issue.... so which set up should give me more acceleration? Making a sort of closed box of aluminum around the intake with the dryer hose coming out of it and going down to draw cool air in around the fog lights or bumper.... OR using the aluminum to just make a heat shield on one side of the intake, and use the dryer hose in the same way, only just placing it near the intake.... what do you guys think? personally i think the box idea would give cooler air/more power... but i don't honestly know.
Old 08-09-2002, 07:48 PM   #13
Alec
Mod Emeritus
Houston, Texas
Alec's Avatar
2008 JK
Vehicle Specs
unless you form a completely sealed airbox, the dryer hose wont create suction. so might as well go the easy route and just seal off the filter on one side from the engine heat and run the dryer hose close to it. don't expect huge power gains, but it will help.
__________________
Daily: 2008 JK
Alec is offline
Old 08-09-2002, 08:02 PM   #14
psychotic
Olathe, KS
psychotic's Avatar
Vehicle Specs
the 4 in hose won't fit anywhere.... 3 in will do the trick... do they make 3 inch aluminum dryer hose?? I'm thinkin about using the 4 inch to cover my rubber intake tube
Old 08-09-2002, 08:46 PM   #15
Alec
Mod Emeritus
Houston, Texas
Alec's Avatar
2008 JK
Vehicle Specs
my dryer hose is vinyl. it's easier to bend w/o tearing and conducts less heat.
__________________
Daily: 2008 JK
Alec is offline
Old 08-10-2002, 01:40 AM   #16
Rhett
Let Them Eat Cake
Cape Girardeau, MO
Rhett's Avatar
94 Sport 4x4
Vehicle Specs
I used Cool Tape to insulate the air tube. Supposedly it reflects away most heat but since I have no IAT thermistor I can't verify this.
I'm gonna rig some sort of heat shield now, since I need to get my mod fix for the week hehehe
__________________
Rhett is offline
Old 08-10-2002, 01:53 AM   #17
psychotic
Olathe, KS
psychotic's Avatar
Vehicle Specs
whats cool tape?, where can you get it
Old 08-18-2002, 12:29 PM   #18
Rhett
Let Them Eat Cake
Cape Girardeau, MO
Rhett's Avatar
94 Sport 4x4
Vehicle Specs
Do a search on the forum here about Cool Tape if u want to know about it.
fyi, Martel Brothers Performance
www.martelbros.com
__________________
Rhett is offline
Old 08-18-2002, 01:06 PM   #19
diablo5969
ECX Member
sXc Member
Versailles, KY (Home) Poughkeepsie, NY (School)
diablo5969's Avatar
2004 Honda Pilot LX
Vehicle Specs
I want to do something like this too.
Create a type of heatshield around the intake, and use dryer hose to bring in cooler air.
Has anyone done this with a first generation Explorer? If you have, where did you mount the dryer hose?
I can't find a really good location without the hose bending and twisting a lot. Or is that not really a problem if the hose bends and twists a lot?
__________________
-- Chase
My 1994 Ford Explorer XLT
RIP 3/15/04: Explorer No More
My 2004 Honda Pilot LX: My New Truck
diablo5969 is offline
Old 08-18-2002, 01:08 PM   #20
aldive
Sarasota, Florida
aldive's Avatar
1999 XLT
Vehicle Specs
Whats the point?
__________________
Al Franklin
My truck
My Quest for 30
aldive is offline
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
