Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
Thread Tools
Old 08-09-2002, 12:57 PM   #1
Bored_2wd
Westmont, Illinois
'93 Ranger
Vehicle Specs
Argh! Truck occasionally dies right after startup. any ideas?
The 4.0 (5 speed manual) is dying right after starting, just as I back out of the driveway. Once I restart and take off, everything is fine. It seems to want to die about 10 seconds after starting, the rpm's just drop to where it chugs and tries to die.
Just this week I had it in for some work, in an attempt to fix this. Here's what's been done:
New Autolite plugs
New PCV valve
New Fuel filter
Ignition wires checked, they're fine(replaced 1 yr ago)
MAS Air Flow cleaned.
Other stuff done:
replaced radiator hoses/flush and fill.
brakes checked and are fine
clutch checked, fluid fine.
2 light bulbs changed in dash.
Any ideas on what's causing it to die? Once I get going it's fine.
--Bob
__________________
2004 Sport Trac 4wd blue stock (not for long!)
Recently sold a '93 Ranger 2wd (converted to 4wd with d35 from mazda Navaho) 4.0L 5speed 4" Skyjacker 4.10 gears. It had a '95 explorer disc 8.8 Powrtrax noslip 325x60xr15 BFG AT's Rhinoliner.
Bored_2wd is offline
Sponsored Links (Less Ads)
Old 08-09-2002, 01:17 PM   #2
Zer0LUXX
Baltimore, MD
2000 Sport
Vehicle Specs
Does this seem to happen when the engine is cold or hot? I have a similar problem with my 2000 X Sport. When the engine is hot and I restart it, it'll drop down to about 100rpm, almost die, and jump back up to 500-750 rpm to idle. Happens ONLY when it's hot. I thought it might be a vacuum leak, but I checked manifold and ported vacuum at school last night and the vacuum was great. Replaced the IAC, PCV, plugs/wires, new MAF but nothing has helped. It has only died on me twice since I've had it, both in the summer when it was really hot. Hopefully someone out there will give us both some ideas... anyone???
__________________
'00 Explorer Sport. V6 4.0L (SOHC)
K&N air/oil filters
15" BF All-Terrain tires
"it has only just begun..."
Zer0LUXX is offline
Old 08-09-2002, 02:07 PM   #3
Bored_2wd
Westmont, Illinois
'93 Ranger
Vehicle Specs
It seems to be first thing in the morning, so I'd say when it's cold. Hope someone else has run into the same issue. I haven't check anything related to the IAC, maybe its that. O2 sensors are newer, I've got replacements maybe I'll throw in this weekend and see how they adapt to that.
__________________
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
