Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Ford Explorer - Ranger Tires & Wheels
Notices
Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here.
Reply
Thread Tools
Old 03-08-2003, 12:07 PM   #1
99Mounty
Chicago, IL
99 Mountaineer
Vehicle Specs
what's the biggest spacer you'd put on?
simply put, getting a spacer/adapter is sort of like getting rims with a different offset.
i'm looking into something like a 1.75" aluminum 6061 adapters. i need minimum of 1.5" adapters (adapters, as in those big spacers with studs on em).
1.75" would allow me to fully turn the steering wheel with the same clearance between the tire/upper a-arm and the tire/front stabilizer bar. however, i can still use a 1.5"... but i can only go 90-95% full turn without rubbing.
my question is - what's the biggest spacer/adapter you would put on? i know rick's using a 1" and a couple other people are using 1.5"... do you think it would be ok to go with 1.75" spacers ?
any thoughts, comments are very appreciated.
thanks!
99Mounty is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 03-09-2003, 02:06 AM   #2
NOTAJP
Moderator Emeritus
Mountain Home AFB, ID
NOTAJP's Avatar
No more Exploder
Vehicle Specs
I think you could, but I would want to take into consideration wheel backspacing, and width. This will put more stress on your wheel bearings, though I wouldn't think much more than replacing 8" wheels with 10" wheels. That does make a big difference in bearing life.
I have considered the same thing with my wheels if I did a SAS but wanted to keep my new rear disk brakes.
__________________
US Air Force Mission Director
'96 Ford Bronco (daily driver)
'67 Land Cruiser trail rig project
"My Give a Damn is Busted!"
NOTAJP is offline   Reply With Quote
Old 03-09-2003, 02:48 PM   #3
Hartman
From lowered to lifted
Indianapolis, IN
Hartman's Avatar
'95 4WD
Vehicle Specs
1.75 is a HUGE spacer! Personally, I wouldn't run spacers period. But if I had to, I certainly wouldn't go bigger than 1 inch. Besides the stress you put on the bearings, with that big of a spacer the wheels will start to stick out way more than the rear, which looks a little funny IMO.
__________________
32x11.5x15 BFG A/Ts, TT/shackles.
college = no money for mods.
Hartman is offline   Reply With Quote
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
