| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Notices |
| Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Austin, TX
'97 EB 4X4
How do bigger tires effect my speed?
I just put 265/75/R16 BFG A/T KOs on a my pretty much stock EB. How will this effect my speedometer? Is my speed going to be higher than what is registered on it and if so by how much? Can any of you guys help me out?
__________________
"I'm a rageaholic. I'm addicted to rageahol." --Homer Simpson |
| Sponsored Links (Less Ads) |
#2 |
GA
'05 Toyota 4Runner SE V8
__________________
Derek '02 Explorer Sport - gone '05 Toyota 4-Runner SE V8 |
#3 |
Mesa, AZ
'97 4x4 Sport
Yes, your speed will be higher by 5% than it was with your factory 255 70R16s. You can fix this by changing the $10 speedometer gear in your transfer case and about 10 minutes of your time. It'll also let your transmission shift correctly again. You need a gear with one less tooth than the one that is in there. If your '97 is like mine, then you probably have a 20 tooth black gear in there now. If you do, you need a 19 tooth pink gear. It's held on by one bolt and is easily accesable.
__________________
4.56 Powertrax No-Slip, SOHC V6, SuperChip, K&N FIPK (#57-2513-1), Borla cat-back (#14748), 2" torsion lift, 3" PA body lift (#853), Monroe Reflex shocks, 285 75R16 BF Goodrich T/A ko, 2WD mod Earnhardt Ford, Berge Ford, U-Haul ![]() My Explorer |
#4 |
Tucson, AZ
98 Expl XLT
Aggie,
Check your speedo first. Find some mostly flat and mostly straight freeway where you can set your cruise for while. Set your cruise at 50 on your speedo and time yourself over 4 or 5 1-mile stretches with a stopwatch. Then do it again at 60 and 70. For each speed, average the times to minimize timing errors and milemarker placement errors. Then use this formula: (1/S) x 3600 = mph to calculate your actual speed. Then divide the actual mph by the indicated mph to find out what percentage your speedo is off by. Doing it at the three different speeds and averaging the times just helps to reduce errors. When I went to 5.6% bigger tires, my speedo ended up off by only 2.8% (when my speedo says I'm doing 75, the radar gun says I'm doing 77), so that means it was wrong with the stock tires. Such a small error to me isn't worth correcting. Check yours and then you'll know if it's worth doing or not. Hope this helps.
__________________
Pete 98 Explorer XLT 4dr 5.0L Auto AWD |
#5 |
Austin, TX
'97 EB 4X4
Thanks Guys!
I just wanted to thank everyone who responded. This was exactly the info I was looking for.
__________________
#6 |
Yakima, WA
02 F250/Zuk twins
Where can you get the gear?
__________________
Gone wheel'n......I wish ![]() Andrew J. Nowicki ![]() The FORD III - 2002 F250 7.3L PowerStroke Diesel - Tow Vehicle Zuk Twins (87 & 88.5) Suzuki Samurai <-- It's a Samurai thing even I don't understand. My Home on the Web |
| Bookmarks |
| Thread Tools | |
