Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Reply
Thread Tools
Old 05-20-2003, 02:58 PM   #1
V8BoatBuilder
Transplanted Bostonian
East Brunswick, NJ
V8BoatBuilder's Avatar
97 Mountaineer V8 4x4
Vehicle Specs
1997 Mountaineer A/C Issues
I decided to start my own thread to try and diagnose/fix my A/C system.
Symptoms:
When put on Max AC, A/C system will cycle on for 2 seconds, then shut off for 10, then go on for 2....
Ambient Air temp: 80 degrees, Low side pressure: 30psi High side pressure: 100psi. I did the "5 seconds charge test" (depress low side valve for 5 seconds, listen for constant or petering out hiss) - and it passed with a constant hiss.
I tried to add a can of 134a, and the system behaved the same - it didn't want to take the can.
I can hear the low pressure switch clicking on and off with the system - I'm thinking that it, or the high pressure switch may be defective.
Is there any way to test the switches? I was thinking my air compressor.....
Let me know what you think
__________________
-Aaron !!!!GO RED SOX!!!!
Off Road: 97' Mountaineer: V8, 4x4, 4.56s, 4" Superlift, SOA, TrXus 33x12.5 - Under The Knife
Work: 00' Ranger 4cyl 5spd
On Road: 2006 VW Jetta TDI/6spd DSG. Fill it with diesel, please.
Octopus Yachts, LLC Engineered Marine Electrical Systems
V8BoatBuilder is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 05-20-2003, 04:50 PM   #2
V8BoatBuilder
East Brunswick, NJ
Vehicle Specs
I went ahead and purchased a new cycling switch (the one on the accumulator near the low side port) for $15.
Still the same problem, the 2 second cycling on/off. It appears to be pressure related, with the fresh can of 134 disconnected, the pressures are as follows (85 deg amb)
Low side: On=35 Off=40
High Side: On=115 Off=110
The sytem is cyling pretty fast now.
When I open the can of 134 into the low side, the low side pressure stabilizes at around 70 - but the cycling continues.
I put a manual push button switch inplace of the cylcing switch. Sure enough, the Low side pressures went down to at least 10psi before i cut it out. I'm trying to add 134a as we speak.
Ok.... More diagnostics:
Using my new pushbutton, I put in the can of 134a. I dipped the 12oz can in hot water - it emptied pretty quick. Now I'm getting weirder results. When I reconnect the cycling switch, it still does the "on 2, off 2" routine. However - the pressures don't change, and are as follows: Low 106 psi, High 100 <<Those are not typos, the low is higher than the high! Its most likely
I'm thinking a blockage somewhere, say orifice tube or accumulator. But I'd hate to tear into the system.
Any thoughts? I know this is a lot here, but hopefully someone can help me shed some light onto my problem.
What am I doing wrong?
__________________
Old 05-20-2003, 05:29 PM   #3
mikeh
St. Louis, MO
98 XLT SOHC V6
Vehicle Specs
When you check the pressure on the low side does it jump from nothing to way high back to nothing as the compressor cycles on and off?
If this is happening then you are low on 134a and probably have a leak somewhere. As posted on the other AC thread the accumulator rusts out and needs to be replaced on this X. You probably need a new one like mine did.
Under that foam cover is a bunch of rust which is caused by the foam cover holding water against the accumulator.
Good Luck,
mikeh
__________________
Mike H
mikeh is offline   Reply With Quote
Old 05-20-2003, 11:14 PM   #4
V8BoatBuilder
East Brunswick, NJ
Vehicle Specs
Mike - thanks for the heads up, it reminds me: I was reading another thread about A/C and someone said that they found a leak in the accumulator behind the foam. It will be my next step to check, but tomorrow I get my wisdom teeth yanked so my Mountaineer will have to wait.
__________________
Old 05-21-2003, 07:12 PM   #5
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
V8...
I'd be suspicious of either a blocked expansion valve, or a compressor problem. The system itself is pretty easy ... expansion valve, low side pressure switch, overpressure cutout on high side and the compressor about comprise it. I fear that recovering the refrigerant and opening it up and seeing what you find may be your only chance to diagnose it. Your numbers do NOT sound good. A blocked expansion tube usually means system failure. I hate to tell you my gut feeling on this one.
Happy exploring...
Chris
Glacier991 is offline   Reply With Quote
Old 05-21-2003, 07:33 PM   #6
V8BoatBuilder
East Brunswick, NJ
Vehicle Specs
Chris - thanks for jumping in on my thread.
I'm determined to get this system working, i purchased the truck in the winter knowing the A/C was bad, and got one heck of a deal. I'm doing most of the work myself, doesn't matter what.
If you where here to work on the truck with me, what would your next step be? I'm going to evacuate the system as a first step. Then remove the orifice tube to check for black death. Keeping my fingers crossed, I'll post photos of what I find.
After I posted, I took the manifold off of the truck and I think they may have been wrong. The pressues I posted above may be due to me be being funky with the manifold valves and hoses. We'll see - it would be great if it is just the accumulator, o-tube and a flush.
What is your opinion on AC components such as O-tubes and accumulators from Autozone, Pepboys, etc. I know the guys on www.aircondition.com despise them. If it does turn out to be a compressor, then OEM is the only way I'd go.
While it's open, what do you think about replacing the valve cores? How is this done? I did some searches at www.aircondition.com and they seem to think that Explorer failures are due to 1) accumulator blanket 2)
valve cores 3) compressor front seal
Opinions?
Thanks,
Aaron
__________________
Old 05-22-2003, 01:10 PM   #7
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
V8 -
Let's start methodically without jumping into opening it up until we have some concrete ideas of pressures. Try again hooking up your manifold (and don't feel bad I HATE the newer setup used on 134a systems with all their backflow prevention stuff and all). Get hi/low pressures and ambient temp, and if it is cooling at ALL, vent temps. describe your readings once you are confident you are getting an accurate read. Let's go from there.
We can talk schrader valves and all that once we decide, and if we decide, to open er up.
Happy exploring
Chris
Old 05-27-2003, 02:12 PM   #8
V8BoatBuilder
East Brunswick, NJ
Vehicle Specs
Results!
Chris,
After a delay due to getting my widsom teeth out, I'm back and ready to solve this A/C problem. I went out to the truck today and found some interesting things.
1) I removed the foam from around the accumulator. WHOA. Inside was a mess of rust, what appeared to be oil, 134, and some UV dye. I'm betting this thing is leaking.
2) I hooked up the manifold after working out my backflow valve issues. Here is what I found:
Ambient Temp: 60 degrees (This NE weather is crazy)
P static: 76psi
P on: Low=25 before cut off
High=100
The system had its usual 2 sec cycling.
I tried to add gas from a can at amb temp, and the low side held at around 60, the high fluctuated around 100. The system continued to cycle, but the cycles were longer. I didn't bother jumping the cycling switch this time. I chose not to add that much gas, I merely wanted to see the system's response.
I'm thinking its time to open her up and buy some components. Let me know.
Thanks for all your help
-Aaron
__________________
Old 05-27-2003, 03:38 PM   #9
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
Aaron...
Now those pressures make some sense <g>. Your low cutout is kicking in at 25, which is about right. When you connect your can to the low side the pressure jumps to near static, which is to be expected. The low high side pressure is due to either insufficient refrigerant (probable) or a bad compressor (not impossible but a less likely 2nd choice). If your receiver/dryer/accumulator is as you say, it would be good to replace it. Add a couple ounces of oil to it. You are probably PAG oil, the sticker in the engine compartment should say. As long as you are discharged and open, be a good idea to take a look at the expansion valve. You will in all liklihood need a puller for that, and you can borrow or buy one at Autozone.
Assuming the expansion valve is ok, if it were me, I'd pull a good vacuum on the system and recharge it with the factory amount of R-134 and see what gives.
If the expansion valve is sooty and crudded, well, then we have another issue. As for the schrader valves, I'm not sure from what you are saying that they are a problem. You may just want to leave them alone.
Keep us posted on your progress.
Old 05-27-2003, 05:15 PM   #10
V8BoatBuilder
East Brunswick, NJ
Vehicle Specs
Purchasing Parts
Tomorrow after work I'm picking up a new Accumulator and orifice tube. I'm using new Motorcraft parts. It will be interesting to see the condition of the inside of the system.
When I'm re-building:
1) How much oil should I put back into the system? Is it necessary to use ford OEM oil, or will any PAG do it?
2) Do you recommend adding a Dye to the refrigerant?
3) I've read about "smart" orifice tubes, or Variable Orfice Valves "VOV." Are these things worth it, or a gimmick?
Thanks,
Aaron
__________________
Old 05-27-2003, 06:42 PM   #11
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
Aaron... (assuming your system is PAG oil) any PAG is fine, certainly nothing wrong with picking it up while you at your Ford store. As for Dye, that's an individual call. I hear some claim is has a long term adverse effect, others say that's hogwash. Genetech is even offering R-134 with dye already in it! It's a cheap way for a DIY'er to find leaks, so your call. VOV are reasonably new, and make claims of improved cooling at idle. Some think one more moving part is one more moving part too many. I have no experience with them to be able to answer your Q. As for oil, I'd ordinarily add an ounce to an ounce and a half to a receiver/dryer/accumulator when I replace it. You mentioned seeing some oil around what you suspect was the leak, so I upped it to 2 ounces. Just pour it into the unit before you install it.
Good luck.
Happy exploring
Chris
Old 05-30-2003, 05:21 PM   #12
V8BoatBuilder
East Brunswick, NJ
Vehicle Specs
FIXED!!!
This is a copy of the original writeup: http://www.explorerforum.com/forums/...436#post667436 I may update the main post, please check there for new thoughts.
I purchased the truck in the winter knowing the A/C wasn't working. Even on warm days, the compressor would cycle on for a few seconds and then shut off for ten. Pressures were low.
Diagram of A/C system, courtesy of www.ackits.com
Daignostics
On 1996-1998 V8 Explorers and Mountaineers, Ford wrapped the accumulator with a foam blanket. My guess is they figured since the accumulator is in the low side (hoses are cold) and it is right over the passenger exhaust manifold, they wanted to insulate it. However, the accumulator sweats, the foam trapped in the moisture and the steel rusted.
Comparison of New and Old Accumulators
After peeling away the foam, I found a mess of rust, PAG oil, and flourescent dye. (Ford adds dye in the factory) A new Motorcraft Accumulator was $65.
Repair
The system was discharged, and the accumulator removed. One of the fittings is a simple hex nut, the other is a spring disconnect. The spring disconnect tool is also used on the fuel system, and can be purchased at Autozone for less than $10.
While the system was open, I wanted to inspect and change the orifice tube. Located in the inlet to the evaporator (the one that get's cold, near the dash). It is a filter/metering valve.
Old Orifice Tube, 109,500mi
Often times the orifice tube is an excellent indicator of system health. If a compressor is going, little metal fragments will start to clog up the screen. If the compressor is gone, "black death" will load up the orifice tube with gunk. http://www.ackits.com/index.cfm?fuse...=Black%20Death
My orifice tube was fine, and did not need replacement. However, since the system was open, the tube was out, and a new Motorcraft OEM tube was $4.00, a new one was installed. A special puller is needed to remove/insert the o-tube, I "rented" one from Autozone for free.
When assembling the system, the o-ring seals were dipped in the air conditioning oil, PAG 46. 2.25 oz of PAG were also added to the accumulator before it was reassembled to replace lost oil. The Cycling switch was re-attached to the accumulator.
Evacuation
After the system was buttoned up, a vacuum was pulled. This is where the difficulty was. A/C systems MUST be vaccumed to remove air. The vacuuming accomplishes two things: 1) It removes air from the system. When expanding, air does not get cold like 134a, yet has volume, reducing cooling capacity. 2) A vacuum will lower the boiling point of water(moisture). Moisture in the A/C system can form acid.
The ideal vacuum pump is a dedicated electric refrigeration pump, capable of pulling down to 50 microns, or 29.9 in Hg. No one in the Boston area rented them, they cost $200. I had used a ventrui effect air-driven vacuum pump on two previous R12-R134a conversions, which cost me $30.
Robinair Air-Vac
The the AirVac however did not pull past 26inHg. My medium sized compressor (5hp, 5.1scfm@90psi, 22gal) could not keep up with the 90psi the AirVac's needs. I held the 26in HG vacuum for about 1 hour, with the Air_Vac running. I cycled it on/off not to strain my compressor. I wasn't too worried about moisture since the system was open for less then 30min, on a very dry day. The excess air, would mean higher vent temps. Oh Well. I have since heard that the pull to 26inHG is almost instant, but the AirVac can pull to 29.7in HG if given enough time.
EDIT:Many people who use these make a manifold to run two compressors, to maintain constant high pressure and not damage the compressors. Also, I've heard that it is possible to make a vacuum pump from an old compressor (Refigerator, dehumidifier, window A/C). I may look into this, there a window unit from the 70s in our basement)
Charging
With the engine off, the first 12oz can of 134a was discharged into the system's high and low side upside down as a liquid. The can emptied 100%. A second can was attached, right side up. The high side valve was closed, and the engine started. The A/C control was on "Max A/C," the temp all the way cold, and the fan on max. All windows/sunroof were open.
Gauge Manifold
Charging was done using the temperature probe of my Mac Tools 710 Digital Multimeter. Very accurate, it's remote probe reads in tenths of a degree. I added gas untill the vent temps settled on 40.5 deg F. The Ambient temperature was 76 degrees, High side pressure was 190psi, Low side pressure was 30 psi. Adding gas took a VERY long time, almost 30 minutes. I've heard people say that you can dip the can of 134 into hot water to speed of the process, but others say not too. I chose to take it slow and easy. You can see when the clutch cycles by the increase/decrease in vent temp. Often the difference will be by 3 degrees. As the system nears full capacity, the cycling will stop, and vent temps will remain constant. The sticker on the dash says the system will hold 1 lb 14 oz of R134. This is 30 oz, exactly equal to 2.5 12 oz cans of R134. I estimate I was able to add about 26-27 oz of R134, leaving about 3oz of air in the system.
The clutch does not cycle often now, and the air is nice and chilled! Special thanks go out to Chris, Glacier991, who gave me advice along the way.
__________________
Old 06-06-2003, 11:11 AM   #13
mikeh
St. Louis, MO
98 XLT SOHC V6
Vehicle Specs
Re: FIXED!!!
Quote:
Nice writeup V8BB. But no thanks for me when I described your problem to a tee?
Come on I want my props.
I wish I had the equipment to do this one myself. It cost me $300 at the dealer. What was your final cost including tools that you had to buy? I guess it wouldn't have saved me too much. It's just that I hate to take the truck to dealer.
mikeh
__________________
Mike H
Old 06-06-2003, 07:36 PM   #14
SVO LOU
Greenville, SC
97 Mountaineer AWD
Vehicle Specs
Awesome write-up with pics. Great post.
Lou.
__________________
97 Mountaineer AWD- homemade KKM intake, 99 Cobra wheels, JBM billet grille....
93 Cobra - Too many mods to list.
94 Taurus SHO - Ahhh, forget it.....
SVO LOU is offline   Reply With Quote
Old 06-06-2003, 11:26 PM   #15
V8BoatBuilder
East Brunswick, NJ
Vehicle Specs
Mike - you definitley hit my problem right on! So i'll give you some props
http://www.imcool.com/articles/airco...ccumulator.htm
As for the tools, lets see:
1) Gauge Manifold/Hose Set: $60 (Got a great deal!)
2) Vaccum Pump: $30 (Though if i had to do it over, I may have bought a used electric rather than the venturi. But I had shop air)
3) Orifice tube remover: Rented free
4) Digital themometer: Part of my multimeter, which I use as often as a screwdriver!
5) General sockets, wrenches... yada yada...
That's about it. I bought the gauges/hoses and pump last year and did two "Wal-mart" a/c conversions on two Peugeots. So the set has been used on 3 vehicles so far, not bad.
As for the cost of the repair:
1) Motorcraft OEM accumulator: $65 (I could have had a cheapie knockoff for as little as $45.)
2) Motorcraft Orifice Tube: $4.00 (Not needed, but worth replacing while system was open)
3) PAG 46 oil: $5.00 8oz bottle
4) 3 cans R134a: $1.99/ea (got a LOT at a sale a year ago.... had a hunch)
__________________
Old 06-06-2003, 11:36 PM   #16
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
My hat is off to V8. I believe that a DIY CAN do A/C so long as they realize the issues and problems and act accordingly, not just dump in a "kit" and think they aced it. His post with pics was terrific and was what I hoped to have people here realize. YOU can do it, but BUY a gauge set fer chrissakes. I could add to his list but it's a good one. I'd add eye protection, but of course that is not a tool. just a MUST HAVE. If you are a DIY, read his post carefully. THAT is how you SHOULD do it.
Great work V8.
Happy exploring
Chris
Old 06-07-2003, 09:02 PM   #17
V8BoatBuilder
East Brunswick, NJ
Vehicle Specs
Chris is right about the eye protection - I've heard that a stray shot of 134a in the eye can cause blindness. I have a nice set of goggles from my school's chemistry department
I also should add can tap/valves to my list of things above, I had several from the "Death kit" conversions I did.
I chose not to add dye to the system (see earlier post). There was dye in the system from the factory, and there appeared to be residual amounts left in the system after it was recharged. If the system develops a leak, I will add dye then or just use a sniffer to find the leak. A/C systems are so fragile, why put added stress on an already weak compressor.
__________________
Old 06-10-2003, 04:14 PM   #18
V8BoatBuilder
East Brunswick, NJ
Vehicle Specs
Arrow Updates
Well I finally have a nice and hot day to test out my A/C, here are the results:
Ambinet temp: 83 degrees
Vent Temp: 49 degrees.
The above was taken with the engine at idle speed. Cooling was noticably better when the truck was moving.
Temp reading taken from center A/C vent, controls on max fan, max a/c, doors/roof open.
I'm not sure if that's "good" or "bad" compared to other Explorers, but it sure feels great!
__________________
Old 06-12-2003, 05:27 PM   #19
weebo
Louisville, KY
'92 XLT & '97 XLT
Vehicle Specs
great write-up.
I just found the ac problem on my '97 today...took my local guy five minutes to find a vacuum line that "Ford" had incorrectly installed last year when they replaced my intake manifold. Yep, I went all last summer with no ac because of the dealership.
I'm gonna go check the Accumulator though as I'm sure mine is rusty and quite possibly leaking as well.
Thanks again!
__________________
Randy
'97 XLT SOHC, K&N Gen II FIPK, 2" TT & Warrior Shackles, 31" x 10.50" BF Goodrich AT KO's, Safari Bar w/ Piaa 540 lights, Piaa Platinum White Headlamps, Aux. Tranny Filter, NR Auto Indiglo Gauges
weebo is offline   Reply With Quote
Old 06-12-2003, 05:31 PM   #20
weebo
Louisville, KY
'92 XLT & '97 XLT
Vehicle Specs
__________________
Randy
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
