| 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Home | Register | Members Rides | Vendors | Top Posters | FAQ/Rules | Social Groups | Search | Today's Posts | Mark Forums Read |
| Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum |
Thread Tools |
#1 |
Wannabe Elite Explorer
Atlanta
1996 eddie bauer
ok, I screwed up.........
I installed a radiator and everything went fine. I developed a small leak on the upper transmission cooling line at the bolt that goes to the radiator. I decided to take the bolt out and put permatex on it, and when I started to unscrew it, I twisted the cooling line. I have to get this thing out or it will continue to leak. I did however out permatex on the transmision cooling line connector, so when I try to seperate the two connections, the transmission lines kinks further. Any ideas?
Also, I tried to largest wrench in my set 7/8, and it is too small........besides a crescent wrench, do they make one larger? |
#2 |
lou,ky
91 XLT, 02 XLS
I'm not sure, but I believe there should be 2 hex surfaces at the fitting. One is fixed on the line, and the other is threaded. What ou need to do is put a wrench on the fixed hex to keep it from turning, and another wrench on the thread fitting to unscrew it.
Try a 15/16", maybe larger. __________________ Make sure you have a left handed screw driver, thats the only tool for the job. |
#3 |
Atlanta
1996 eddie bauer
that is what I was doing but since I put permatex on the nut that is connected to the transmission line, it twisted the actual line, and now it has a small hole in it. Can I cut and spice it, or will I have to have it replaced?
#4 |
Elite - G-d Bless!
Kennewick, WA
1991 EB
How close is the damage to the fitting? If close enough I would think you can trim the line and re-flare the end, making up the loss with some careful bending.
#5 |
Atlanta
1996 eddie bauer
I am going to try that today. Can I still flare it when it is connected?
#6 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
you dont know what flaring is.
No you cannot flare it with it connected. you need to replace the broken section of line, you can either use metal or rubber, but likely you will need to cut the piece on there past the new hole you made, re flare the end and if its long enough go into the radiator, if not you will have to run a small section of rubber line between the metal line with the hole in it and a new metal line going into the radiator. Permatex will not stop it, the tranny cooling system is pressurized and this leak needs to be fixed. You tweaked the metal line = ouch! Yes they make wrenches of all sizes, up to even 2" and larger. __________________ 96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's 88 BII 5.0L conversion - BII 5.0l drivetrain thread My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates Wifes 07 FJ build - 2007 FJ cruiser locked and lifted |
| Suggest this thread to friends: |
| Thread Tools | |
