EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Modified Explorations!!
Notices
Modified Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
trans temp gauge?
Thread Tools
Old 05-04-2004, 10:22 AM   #1
Bigcheck1
Marlton, NJ
2004 Nissan Xterra
Vehicle Specs
(Original Poster)
trans temp gauge?
curious as to how some of you have hooked yours up? do i need to tap into the pan or can i run the sensor into the rubber hoses to get an idea of the temp? with me still having a trans warranty, i'd need to have it tapped into the pan by the trans shop. but i will do all the other wiring. i've hooked up gauges before and am just curious as to how a trans temp gauge works.
__________________
2004 Nissan Xterra, Gun-metal 17's with BFG's, Super Black, Brushguard, Rockford Stereo, Thule racks
Previously: 92 XLT, 5 inches lift, 33 Xterrains, Ramsey Winch, Kicker system. 95 Wrangler, Sahara, 30x9.50 All-terrains.
Bigcheck1 is offline
Old 05-04-2004, 11:15 AM   #2
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Quote:
Mine, a DaKota Digital ( http://dakotadigital.com/ ) electrical unit, is installed in the fitting in my aux tranny filter housing ( I got mine from Summet - http://www.summitracing.com/ ). Works perfectly.
Good luck.....
__________________
Al Franklin
My truck
My Quest for 30
RIP Al Franklin! 1947-2010. Gone but not forgotten! :(
aldive is offline
Old 05-04-2004, 08:10 PM   #3
bipolarbob
B
Kelowna,British Columbia,Canada
91 Eddie Bauer
Vehicle Specs
Get an inline filter from Summit, and it will have a place to screw it in.
bipolarbob is offline
Old 05-04-2004, 08:15 PM   #4
MONMIX
I fix dents
Millersville , Maryland
MONMIX's Avatar
2000 Explorer Sport
Vehicle Specs
OR you can get the Perma-Cool filter guage combo.
You get the guage with the added bonus of a useful filter.
The guage send is built right into the filter mount.
__________________
MONMIX
Wheels and intake for sale
Live your life for a change
My Explorer
CHURCH.... sort of
MONMIX is offline
Old 05-04-2004, 09:30 PM   #5
B94Sport
Geneva, IL
05 Subaru Impreza WRX STi
Vehicle Specs
I put mine in the metal tube right before it turns into rubber and goes to the tranny cooler. Bought a small pipe cutter and cut out a section and then replaced it with a T pressure fitting that the sender screwed right into.
__________________
2005 Subaru Impreza WRX STi
1994 Sport 4x4, Auto
B94Sport is offline
Old 05-06-2004, 12:41 AM   #6
4LB2
San Diego, CA
86 Bronco II
Vehicle Specs
Somebody is making an aftermarket pan that has a few goodies including a port for a temp gauge.
-James
__________________
86 Bronco II
4.0L -> C5 -> BG1354 -> D28/8.8"
JBA headers -> Highflow cat -> Flowmaster 40
3" Duff lift -> Cut fenders -> 31" BFG's
Warn brush guard -> Warn x8000i -> 2 Hella 500's
Under Construction
4LB2 is offline
Old 05-06-2004, 08:10 AM   #7
Trckmagik
Ole Bag
Celina, Texas
Trckmagik's Avatar
1996
Vehicle Specs
If you go with a t fitting, you will want to install it on the hard line that goes into the radiator. This is the way the tranny fluid flows.
-Leaves tranny
-Enters cooler thats built into the radiator
-Exits the radiator
-Enters the factory tranny cooler
-Exits the cooler and returns to tranny.
If you tab in at a cooler or one of the hard lines located at the bottom side of your motor you will be getting a tranny temp after its left one or both of the factory coolers. I will try and get some pictures up for you.
__________________
Brian Green
1996 V-8 Explorer
1994 4x4
Trckmagik is offline
Old 05-06-2004, 08:36 AM   #8
Trckmagik
Ole Bag
Celina, Texas
Trckmagik's Avatar
1996
Vehicle Specs
Here is a link to my pictures. I hope it helps.
http://www.explorerforum.com/forums/...d.php?t=107505
__________________
Brian Green
1996 V-8 Explorer
1994 4x4
Old 05-06-2004, 09:28 AM   #9
Bigcheck1
Marlton, NJ
2004 Nissan Xterra
Vehicle Specs
(Original Poster)
since there are two lines to the radiator from the trans, how do i know which one will be the line that is going to the radiator and is the hot one? is it the top or bottom line?
__________________
Old 05-06-2004, 09:32 AM   #10
Trckmagik
Ole Bag
Celina, Texas
Trckmagik's Avatar
1996
Vehicle Specs
I havent looked at this on my 1st Gens so I am not sure. You should have a hard line going to the top of the radiator like mine. That should be your line.
__________________
Brian Green
1996 V-8 Explorer
1994 4x4
Old 05-06-2004, 09:36 AM   #11
Bigcheck1
Marlton, NJ
2004 Nissan Xterra
Vehicle Specs
(Original Poster)
Quote:
there's two hard lines, i was also thinking that the top one will be the hottest line, since it has to travel through the radiator. i'm gonna be hooking up a cooler as well so i guess i have to tap that line as well???? or should i do it to the bottom line as one last cooling before it enters the trans. my gauge, gauge pod and cooler all should arrive here shortly.
__________________
Old 05-06-2004, 09:40 AM   #12
Trckmagik
Ole Bag
Celina, Texas
Trckmagik's Avatar
1996
Vehicle Specs
The top one will be the hottest. As for the cooler, you can tap the cooler into the bottom lines. I also kept my stock cooler.
__________________
Brian Green
1996 V-8 Explorer
1994 4x4
Old 06-12-2004, 04:53 PM   #13
sk1er17
My "Jeep Thing" itches...
Jackson,NJ
sk1er17's Avatar
'98 Sport
Vehicle Specs
Quote:
-James
Who?
__________________
>>My Elite Registry<<
Explorers Gone... Went to a Silverado with 8" lift and 37s, then to a 2008 Sierra Denali with 3" lift and 33"s... Now, finally back in an off-road worthy rig...2007 Jeep Commander Hemi QDII (front & rear e-lockers).
Build Thread: Here
sk1er17 is offline
Old 06-12-2004, 09:06 PM   #14
4LB2
San Diego, CA
86 Bronco II
Vehicle Specs
Quote:
Originally Posted by sk1er17
Who?
Can't remember exactly but I believe 410 has one or had one on his old tranny.
There was a thread on it awhile ago. I'll try to find it later.
-James
__________________
86 Bronco II
Under Construction
4LB2 is offline
Old 09-29-2004, 12:45 AM   #15
Heath
Elite Moderator Intoxicator
Rigby, ID
Heath's Avatar
'01 XLT Slightly Modded
Vehicle Specs
Good info guys... I'll be doing this soon hopefully... Thanks...
__________________
Rigby, ID
2001 Explorer V8 XLT with a mod or two
"Never fight an ugly guy, he has nothing to lose"
Mugshot Updated 8/6/10
To support the site and upgrade to an elite membership, Click Me!
Heath is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Trans Temp Oil Temp explorer97 Under the Hood 7 05-11-2003 11:47 PM
Temp Gauge Explained guzzler528 Under the Hood 7 01-14-2003 12:27 PM
Help w/ trans temp gauge. DocVijay Under the Hood 4 02-03-2002 11:19 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
