Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
When Turning Tranny Slips
Reply
Thread Tools
Old 10-22-2004, 04:03 PM   #1
jason94exp
ohio
'94 xlt
Vehicle Specs
(Original Poster)
i HAVE A 94 EX. i HAVE A SLIGHT LEAK IN THE TRANNY THAT I CANT PIN POINT BUT THE BIG PROBLEM IS TO DAY I CAME HOME FROM LUNCH AND WENT AROUND THE CORNER OF MY DRIVEWAY THE TRANNY SLIPPED. i NOTICED AFTER DRIVING AWHILE THAT IT ONLY DOES IT WHEN I MAKE A TURN AND GET A LOT OF BODY ROLL HAS ANYONE HAD THIS PROBLEM OR HEARD OF IT BEFORE. tHANKS TO EVERYONE WHO HELPS THIS IS THE BEST SITE I HAVE BEEN TOO.
jason94exp is offline   Reply With Quote
Old 10-22-2004, 04:09 PM   #2
TSTONE
Giddy up!
Oakland County, MI
TSTONE's Avatar
97 Mountaineer
Vehicle Specs
TRY CHECKING YOUR TRANS FLUID LEVEL - then stop yelling
__________________
“Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, pork rhines in one hand, bottle of jack in the other, body thoroughly used up, totally worn out and screaming “WOO HOO what a ride!”
TSTONE is offline   Reply With Quote
Old 10-23-2004, 02:14 AM   #3
Brain
Golden, CO
'92 4X EB and '91 4X XLT
Vehicle Specs
Yep, I agree w/ TSTONE. Sounds like when you go around a corner, air gets sucked into the pump, the pressure drops for a few seconds (because the pump can't pump air very well) which will cause slipping. Probably need to check/add fluid. 2wd or 4wd?
Brain is offline   Reply With Quote
Old 10-24-2004, 10:50 PM   #4
jason94exp
ohio
'94 xlt
Vehicle Specs
(Original Poster)
4wd The level is normal in neutrol on level ground
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
