Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer Audio & Navigation
Notices
Explorer Audio & Navigation Audio and navigation systems. CD, DVD, MP3, GPS, Video, Mobile Computer, Speakers, Amplifiers.
amp impedance
Reply
Thread Tools
Old 03-08-2005, 05:15 PM   #1
minime122
GA
'01 sport
Vehicle Specs
(Original Poster)
amp impedance
I've got a question that im probably gonna feel stupid for asking but here it goes. Im purchasing a Rockford Fosgate P210S4 10 inch sub its power range is 50-200 watts RMS with its peak power being at 400 watts it has a 4 ohm impedance. I need to know what kind of amp to buy for this sub. Im going to use a mono subwoofer amp. All the ones i see are rated for 2 ohm impedance i know ill need the amp to be at least 200 watts but does the 4 ohm impedance mean that i need to find an amp that can put out 4 ohms?
minime122 is offline   Reply With Quote
Old 03-08-2005, 05:37 PM   #2
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
yup, they must match.
Now your amp may be able to handle a 2ohm load but that doesnt mean it cant also handle a 4ohm load, it just wont be as powerful.
You see a 2ohm load on the amp just draws more power, forcing the amp to make more.
Now if you hook up a 2ohm speaker to a 4ohm stable amp = toast.
You can also wire two 4ohm speakers together to create a 2ohm load, thus usually doubling thepower output of the amp, so if you buy a 2ohm stable amp now you can upgrade later.
Most good amps on the market today are 2 ohm capable, some even lowed, 1/2 ohm WOW....
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 03-09-2005, 10:51 AM   #3
davesexplorer
Central PA
davesexplorer's Avatar
2001 F350 7.3
Vehicle Specs
A good option for you then would be a 2 channel amp, most are bridgeable to 4 ohms mono - perfect for the single 4 sub.
Or dont rule out the 2 ohm stable amps, if you get a 2 ohm stable amp it will allow you headroom if you choose to add another sub or even upgrade to a dual 4 model etc. Just look for what you need @ 4 ohms.
__________________
2001 F350 Extended Cab Long Bed Lariat 7.3 Powerstroke 4x4
1999 Mustang GT 5spd vert
davesexplorer is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
