Serious Explorations Ford Explorer and Ranger Message Board
#1 Resource for Ford Explorers and Rangers for 20 years 1996-2016
Searches ExplorerForum.com Only
2017 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
99 tranny slipping into 4th
Reply
Thread Tools
Old 02-07-2006, 12:04 AM   #1
nashman918
Corning, NY
99 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i have a 99 explorer sport with the 4.0 ohv engine and auto tranny. lately i've noticed that if i'm getting on it a little bit or if i'm going up a hill, it will slip slightly when going into 4th gear. the fluid is at the correct level and other than that it shifts fine. i'm just wondering if i should be concerned with it or if i should just run it.....thanks for any input
nashman918 is offline   Reply With Quote
( Join the Elite Explorers )
Join the Elite Explorers for only $20 a year
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose and fix problems yourself, and learn which modifications really work without having to experiment on your own. Elite Explorer members can change the forum "styles" to eliminate most ads, including the blue underlined links, and no ads on photos. Other benefits include the ability to store 1000 Private Messages, add your own avatar to your posts, upload photo attachments directly to your posts and to our Photo Gallery and more. Join the Elite Explorers today. Your support of the forum is greatly appreciated.
Old 02-07-2006, 12:40 AM   #2
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
Quoted: 4 Post(s)
The OD band slipping is a problem for these trannies. Candidly I think the frying of the servos and their ultimate hardening plays a role, but it is nigh on impossible to replace them in vehicle.
Your slipping transmission in OD is is something to avoid.... it will shorten the life of the trannie. Fixes? Try having the bands adjusted. That will help somewhat. On heavy duty uphills step on the accelerator until it downshifts to 3rd and then select D until you are on a more level surface. Your RPM's will jumnp about 700-800 to about 3,000 but that's a comfortable place for your engine.... and transmission. Depending on mileage, an EPC replacement and or shift kit (a place where the pressure riser on the Superior kit might be a godsend) might be a good idea. Check out the 5R55E VB Rebuild Diary in the stickied section for some idea what I am talking about.
I have nursed a yearand a half out of an A4LD with 220K miles on it by following these "rules".
Glacier991 is offline   Reply With Quote
Old 02-09-2006, 10:53 PM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 414 Post(s)
There is also another option that you could do. I did this on my A4LD a number of years ago. They sell an upgraded servo, and matching cover that is larger than the stock servo. The more surface area, the more apply pressure (hopefully) due to more fluid surrounding the servo. I think they now have even bigger servos as an upgrade that are available. I saw a bunch listed in a parts manual. I think the springs are still different. Some are soft, and other ones are firm. Maybe this could affect the apply pressure as well.
BrooklynBay is online now   Reply With Quote
Old 02-10-2006, 01:13 AM   #4
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
Quoted: 4 Post(s)
Servo replacement "in vehicle" is an exercise in complete frustration.
Old 02-10-2006, 01:21 AM   #5
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 414 Post(s)
I did it to mine when I rebuilt it. I didn't attempt it while it was still on the vehicle. My vehicle doesn't have that metal heat shield over them. The newer ones have it. I was interested in getting it, but the places that sell transmission parts don't stock it, and can't order it either. The books just list a Ford part #, but no aftermarket part #.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Copyright 2016 - 1996 Rick Horwitz Photography Explorer Forum is celebrating it's 20th birthday!!
Ford Motor Company is not involved in the management of this site in any way.
