- November 11, 2005
- Brooklyn, NY
- 88 89 93 95 96 Aerostars
Sonnax has a fix for the A4LD sensitive torque converter clutch release issue. It is very simple since it involves installing a time delay check valve on the vacuum line where the MAP sensor is connected to. Here is the link: http://www.sonnax.com/bulletins/tech/T3-EL-197.pdf
