Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Modified 2002 - 2005 Explorers
Notices
Modified 2002 - 2005 Explorers Questions related to modified 2002 - 2005 Explorers and Mountaineers. For Sport Trac and Sport models use the 1995-2001 forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
Fog Lamp Mod
Reply
Thread Tools
Old 10-18-2008, 10:38 AM   #1
jp450
Pepperell, MA
jp450's Avatar
'05 XLT V8
Vehicle Specs
(Original Poster)
Fog Lamp Mod
On my 99 ex I was able to jump the relay to keep the fog lamps on when the high beams were on. Is there a mod to do the same thing on my 05? I attempted to jump the relay and the fog lamps stay on. Any suggestions?
Jeff
__________________
2005 XLT V8
jp450 is offline   Reply With Quote
Old 10-18-2008, 11:54 AM   #2
ShawnTRD
Spener, NY
2005 Explorer Limited
Vehicle Specs
I would like to know this also.
ShawnTRD is offline   Reply With Quote
Old 10-18-2008, 11:57 AM   #3
BWilliams
Elite Streeter
Buffalo, NY (home) // Rochester, NY (school)
BWilliams's Avatar
'05 XLT Sport
Vehicle Specs
Sadly, it would take significantly more work to do on a 3rd-gen, in particular some rewiring to bypass the stock relay and use a new relay in it's place with the power run directly from the battery.
The way that the 3rd gen fogs work is that the high beams are an on-on relay... When your highs are off, the relay coil is deenergized, and so the power runs from the high-beam relay to the fog light relay, and then to the fogs themselves. When you flick the highs on, the coil energizes, pulling the switch in the relay (and therefore the power) to the high-beam circuit and cutting power to the fogs. The fog relay stays engaged, though, just with no power running through it.
You'd have to wire up another relay that takes power from the battery and uses the signal from the stock switch to energize the coil.
HTH.
__________________
Regards,
Bradley Williams
'05 Explorer XLT
Illusion's Elite Registry
BWilliams is offline   Reply With Quote
Old 10-18-2008, 06:49 PM   #4
jp450
Pepperell, MA
jp450's Avatar
'05 XLT V8
Vehicle Specs
(Original Poster)
Thats what I was thinking but was hoping there was another way... I guess not...
Thanks,
Jeff
__________________
2005 XLT V8
Old 10-22-2008, 08:06 PM   #5
XtremeRanger
Columbus, Ga
'95 Ranger XLT
Vehicle Specs
maybe in left field, correct me if Im wrong........me installing the fog light factory ford kit on my GF's truck is running thru my mind right now......
Couldnt you just cut the blue/? wire(for the fogs) at the headlight switch and splice to the parking light wire? you wouldnt be able to cut them off technically but it would prolly do the job...
__________________
1995 Ford Ranger - Not Stock
2002 Explorer XLT 2wd 4.0 Black everything but a sunroof., Manik Grill Guard, Mounty Cluster, Tint, Yakima MegaWarrior Basket, 6K HID's
2005 Saturn VUE Redline AWD
2006 Saturn ION Redline - in the rebuild process, shooting for 300HP
XtremeRanger is offline   Reply With Quote
Old 10-23-2008, 12:29 PM   #6
Uafan
Whippany, New Jersey
2004 XLS
Vehicle Specs
I did it, I just hardwired my HID fogs to my battery..
Uafan is offline   Reply With Quote
Old 10-23-2008, 07:58 PM   #7
BWilliams
Elite Streeter
BWilliams's Avatar
'05 XLT Sport
Vehicle Specs
Quote:
Actually, you would cut the light-blue/black wire coming from the headlight switch and connect that to slot 86 on a relay whose power comes straight from the battery instead of running it to the stock CJB.
Obviously, much easier if you're installing the fogs yourself instead of trying to rewire the stock fogs, but the procedure would be the same for someone who already has fogs installed.
Quote:
Where did you take the sense wire, then, to tell the ballasts to turn on... the headlight switch wires before they go to the relay box? If so, you did the same thing that I'm suggesting, just using the ballasts in place of relays.
__________________
Regards,
Bradley Williams
'05 Explorer XLT
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
