Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Ford Explorer, Ranger, Bronco II, Mercury Mountaineer and Mazda Navajo, Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Reply
Thread Tools
Old 10-30-2009, 12:33 PM   #41
Oxygen
USA
00 XLS
Vehicle Specs
so on my 00 XLS OHV , the transfer case is always working? i think that is what you are trying to say haha..
i have never changed the fluid on my transfer case, but i hardly use the 4WD high/low...
__________________
00' XLS
Oxygen is offline   Reply With Quote
Old 10-30-2009, 08:17 PM   #42
meyek91974
Louisville, Kentucky - Let me no f u r nearby
meyek91974's Avatar
1997 XLT 4x4 4Door
Vehicle Specs
Dk Exp Be SURE-
Your dash switch "should" read: AUTO 4WD HIGH 4WD LOW - - If this is the case you have automatic all wheel drive, like a Subaru..... If it's: RWD-4WD HIGH-4WD HIGH, then you don't have automatic and you have to switch the lever on the dash. BE SURE YOU ARE DRIVING LESS THAN 15MPH WHEN YOU SWITCH ON 4WD HIGH - AND COME TO A FULL-AND-COMPLETE STOP WITH THE VEHICLE IN PARK BEFORE SWITCHING TO 4WD LOW. - - BE FURTHER SURE that you do not drive in 4wd on dry pavement and if on pavement only drive as straight as possible (DONT TURN) when in LOW. - - - Lastly, you SHOULD find somewhere off-road, or even gravel, to use your 4wd about once a month or couple/few months. Keep it used and try it out so you know it has a problem before you need it and it's not there.
__________________
Keep-on keep'n on
meyek91974 is offline   Reply With Quote
Old 11-04-2009, 10:08 AM   #43
Ranger 96
Michigan
1996 Ranger
Vehicle Specs
Quick Question
1996 Ford Ranger 4.0L Purchased with 110,000 Miles Transfer case oil probably never changed..... Any Oil recommendations (Amsoil, Royal Purple, Stock?????)
Ranger 96 is offline   Reply With Quote
Old 11-04-2009, 12:09 PM   #44
Oxygen
USA
00 XLS
Vehicle Specs
royal purple is good, mobil 1 synthetic, etc.. i used valvoline in my differential and my transfer case i used valvoline mercon V tranny fluid, its made for fords.. i think the valvoline stuff works great
__________________
00' XLS
Old 11-04-2009, 07:11 PM   #45
ozmedia
Vehicle Specs
UK From Mobil's tech team
Quote:
Originally Posted by shortstack View Post
do you guys think synthetic will make any difference in the transfer case?
Using synthetic ANYTHING, oil additives or trans fluid in an older car will in fact start leaks. Synthetic trans fluid will eventually cause the torque converter's stator blades to wear and slip prematurely (documented by Mobil1). Synthetic oil causes gasket leaks galorem first hand findings from working as a Ford tech. most such leaky trucks were ones that were switched to synthetics in a hope to make them last longer.
Synthetic oils are full of detergents and soluable abrasives to remove grease deposits, in older vehicles grease and grime actually holds them together quite well, detergents will usually cause leaks and premature wear, not prolong life. There are SOME semi-synthetics made especially and marketed toward older cars or high miler's but you are still better off running a quality standard oil and just changing it frequently instead. the only time I'd recommend synthetics is after a rebuild, run standard oil for the first two changes, to allow for natural parts wear and brak-in, then use Mobile 1 or your preferred synth. in older or high mileage vehicles you are just welcoming problems.
My Ex has 587,000kms now, and runs perfectly, passes air care etc.
NOTE: the transfer case for an electronic transmission, 97-99 Ex with 5R55E transmission for example, is permanently filled when new, not supposed to be drained, does not even HAVE a drain plug just a filler with a catch to stop debris. You can still check it and top up as needed but once it's dead it's dead. Draining and refilling just delays the inevitable a bit longer but also results in premature seal wear.
ozmedia is offline   Reply With Quote
Old 11-05-2009, 08:21 AM   #46
Ranger 96
Michigan
1996 Ranger
Vehicle Specs
T-Case
Typically with my experience most 4x4's wine a little bit in 4 low, my ranger wines in 4 high, I contribute that to old or a lack of fluid (changing it later today). Should I have any other concerns?
Old 11-19-2009, 12:01 PM   #47
ozmedia
Vehicle Specs
Quote:
helical gears whirr, just the way they work. If it is getting noisy, and has TWO plugs a lower drain and upper fill, you'll be okay to change it. Just use standard fliud though, I wouldn't bother with synthetic. Synthetics are a trend that people have started to think is a miracle in a bottle, and we all know there's no such thing.
If it's an older ranger, your chances of killing the torque converter stator blades and front pump seal will escalate with synthetics due to the detergents. For a newer vehicle, after being broken in with regular fluids to allow proper initial parts wear and seating, no problem running synth.
Old 11-21-2009, 08:23 PM   #48
Ranger 96
Michigan
1996 Ranger
Vehicle Specs
Hey thanks for all of the help, I have a new question.
The truck (ford ranger 1996 4.0L) has new top notch wires and Platinum autolite plugs, and i am having studder issues when I accelerate or try to hold a constant speed. The truck will accelerate strong if I floor it, but to gradually accelerate it studders.
Reply
Top of Page
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Search ExplorerForum
US Flag
We Support Our Troops!
Explore the site!
Contact Us
This web site is not affiliated with or endorsed by the Ford Motor Company.
Ford Explorer is a registered Trade Mark of the Ford Motor Company
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
All tips and information provided on this site by either "Serious Explorations®" or it's contributors are for use at your own risk and discretion.
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
Some modifications described within this website may void your factory warranty.
Copyright 2009 - 1996 Rick Horwitz Photography
