EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Towing a 99 4x4 Explorer.....
Reply
Thread Tools
Old 02-04-2010, 01:54 PM   #1
drakeguy22
Old Forge, NY
99 Explorer XLT
Vehicle Specs
(Original Poster)
i was wondering if there were any do's or dont's when towing a 99 explorer???? i will be towing it with a Ranger+dolly from Tupper Lake to Old Forge... about 55 miles one way. was planning on disconnecting the driveshaft. its got a bad rear diff. any tips would help
__________________
99 Ford Explorer 4x4, Shackles, TT, 31x10.50 Duratrac's on 15x10 Soft 8's, true dual Cherry Bomb exhaust, Two 12's 2000 Watt AMP, Lightning Cap
99 Explorer, 4.0 OHV 5-spd
97 F250HD, 5.8, 4x4, 315's
82 Ford F-100
drakeguy22 is offline   Reply With Quote
Old 02-04-2010, 07:01 PM   #2
hazmat456
tomah wi
1997 mercury mountaineer
Vehicle Specs
is it awd?
are you planning on towing it backwards?(do to the bad diff) not sure if that is advisable,or even legal
do dollies have brakes?explorers are heavy,especially for a car,I think I would try to find a truck and full trailer.
__________________
matt
1997 mercury mountaineer 5.0 31"s
2004 cavalier LS sport
1996 dodge ram 1500 sport 5.9 magnum
23krs keystone outback "toy-hauler"
hazmat456 is offline   Reply With Quote
Old 02-04-2010, 07:28 PM   #3
96eb96
Albany, NY
96 EB V6 OHV 4WD
Vehicle Specs
Yeah, rt 28 is pretty hilly terrain over there if I recall correctly, right in the heart of the Adirondacks! What are you towing the ex with? A 4 dr ex is over 4000 lbs.
96eb96 is offline   Reply With Quote
Old 02-04-2010, 08:57 PM   #4
drakeguy22
Old Forge, NY
99 Explorer XLT
Vehicle Specs
(Original Poster)
towing will be done with a 2000 ford ranger.... and its a 4x4 not awd. like i said i planned on towing it forward with the rear driveshaft removed.... yes very hilly terrain...... yep right in the ADK's
__________________
82 Ford F-100
Old 02-04-2010, 10:03 PM   #5
99SportX
Duluth, MN
'99 Sport
Vehicle Specs
I pulled my 99 XLT home with my 99 sport this summer. I had to keep it around 55 for sure. If I went any faster it felt unsafe. For braking, don't expect to stop fast. Plan ahead, keep your distance from vehicles in front to minimize surprises. You pretty much cannot backup with a dolly so try not to get into a situation where you have to. I unbolted the rear d-shaft from the diff and tied it up to the frame. I only had one major hill to climb and that is when my trans temp got its warmest.
Keep in mind I was pulling with a V8 auto with upgrades, not a V6 auto. I was running factory trans cooler with towing package so it has the extra external cooler. Make sure you have adequate cooling, especially with hilly terrain. The V6 trans is not as strong as the V8 trans. It will probably hold up as long as it doesn't get too hot.
The longer wheelbase ranger may increase stability over the short sport explorer.
__________________
'99 Explorer Sport 5.0 AWD t-case with 2wd spindles (identity crisis)
'99 Explorer XLT 4.0 SOHC 4x4 for daily driver/off road use
99SportX is offline   Reply With Quote
Old 02-04-2010, 10:30 PM   #6
drakeguy22
Old Forge, NY
99 Explorer XLT
Vehicle Specs
(Original Poster)
orange
Quote:
im using a ford ranger... should have mentioned that huh
__________________
82 Ford F-100
Reply
Tags
car dolly, explorer, ford, towing
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
