Serious Explorations Ford Explorer and Ranger Message Board
#1 Resource for Ford Explorers and Rangers for 20 years 1996-2016
Searches ExplorerForum.com Only
2017 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
4.0 SOHC plastic thermostat housing
Reply
Thread Tools
Old 07-26-2009, 05:27 PM   #21
refluga
Vehicle Specs
Quoted: 0 Post(s)
1) The metal retaining clips look exactly like the "profile" of a Guiness beer glass...visualize the beer mug on it's side and that's what they look like.
Like this: http://i78.photobucket.com/albums/j1...dinGlass-1.jpg
2) To remove the metal sleeves - I did mine exactly like the previous poster. I removed the upper housing metal sleeves and used a small socket the same size as the outer diameter of the metal sleeves....then just align the socket on the sleeve and tap on the socket gently (so you don't crack anything) with a hammer so and they will come out. Doesn't require much force for them to come out.
refluga is offline   Reply With Quote
Old 10-21-2009, 12:03 AM   #22
rcanthony
n/a
Vehicle Specs
Quoted: 0 Post(s)
CAN The list
ford part # / description / (motocraft #)
4L5Z-8592-AA -- upper thermostat housing (RH165)
2L5Z-8592-BB -- lower thermostat housing (RH144)
1L2Z-8255-AA -- lower housing thermostat seal (RG614)
W702837-S300 -- thermostat seal (aka large o-ring)
2L2Z 8575 AA -- thermostat (RT1167)
3F1Z-10884-AA -- thermostat sensor (SW5491 or SW6146)
3L8Z-12A648-BA -- thermostat sensor (DY1004)
W706800-S303 -- retainer clips for sensors (I ordered 4)
W500015-S437 -- bolts for housing upper (I ordered 6)
W702527-S437 -- bolts for housing lower (I ordered 6)
I ordered the kit from www.fordpartswebsite.com
this was the only joint that seemed to have all the peices from one location...
I ordered extra bolts and clips because I ALWAYS lose or break these types of parts...
you probably DON'T need all of the parts as this will build one new complete assembly off the modern ranger/sporttrac pattern... you may have salvageable components, or do the early upper housing, late lower mix like the original poster mentions
(note the thermostat has to be entered into fordpartswebsite as the motocraft #)
cheerio
rcanthony is offline   Reply With Quote
Old 01-30-2010, 02:37 PM   #23
zabba501
Wilmington, DE
'97 xlt
Vehicle Specs
Quoted: 0 Post(s)
This thread saved me a "head gasket bill"....the lower housing is junk and mine was leaking through a bolt hole down the right side head. Thank you all.
zabba501 is offline   Reply With Quote
Old 02-17-2010, 01:12 PM   #24
PAPARAZZI
LOS ANGELES,CA
97 EXP. XLT
Vehicle Specs
Quoted: 0 Post(s)
PROBLEM SOLVED,,,
PICTURES AN PART #'S
http://bengrosser.com/howto/fordthermostat/
PAPARAZZI is offline   Reply With Quote
Old 05-21-2010, 01:13 AM   #25
bbqross74
Galt, Ca
1997 xlt 4x4
Vehicle Specs
Quoted: 0 Post(s)
thermostat housing upgrade
Just ordered all the parts from rock auto. Had to go to the dealer for the clips for temp probes. Checked out local parts stores but could not beat the price on-line. Thanks for the information everyone has posted. Will get the parts in this week and will take pictures of install and hopefully post so everyone who is interested can see how it went.
bbqross74 is offline   Reply With Quote
( Join the Elite Explorers )
Join the Elite Explorers for only $20 a year
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose and fix problems yourself, and learn which modifications really work without having to experiment on your own. Elite Explorer members can change the forum "styles" to eliminate most ads, including the blue underlined links, and no ads on photos. Other benefits include the ability to store 1000 Private Messages, add your own avatar to your posts, upload photo attachments directly to your posts and to our Photo Gallery and more. Join the Elite Explorers today. Your support of the forum is greatly appreciated.
Old 06-01-2010, 11:24 AM   #26
bikerboy29680
'98 XLT
Vehicle Specs
Quoted: 0 Post(s)
I am changing out the leaking thermostat housing on my 1998 Explorer SOHC and plan on replacing the upper housing as well. The dealership quoted me the part number F17Z-8594-A of the upper housing at $98.33. Can any one verify that this is the correct part and where I can find it cheaper. RockAuto doesn't show this number. Thanks.
bikerboy29680 is offline   Reply With Quote
Old 06-02-2010, 12:01 AM   #27
bbqross74
Galt, Ca
1997 xlt 4x4
Vehicle Specs
Quoted: 0 Post(s)
Did some research through CSK auto parts (kragen parts store) and rock auto and found the numbers they show are the same. I was unable to get anything to match with the factory part number that the dealer gave to bikerboy. From what the picture shows it looks the same as the origional one I just reused on my 1997 explorer 4.0l sohc eng. With the research I have done on this website and reading previous replies from other enthusiasts I removed bushing from new lower housing and reused my old upper housing without taking bushing out of old upper housing. Hope this helps.
Old 06-02-2010, 12:42 AM   #28
BK_89iX
CA
'97 SOHC
Vehicle Specs
Quoted: 0 Post(s)
I swapped out the t-stat in my '97 SOHC yesterday. My upper cover had a chunk out of the beveled surface that contacts the t-stat o-ring, presumably from the warranty timing chain cassette work years ago. The top of the t-stat can easily catch on that plastic ridge upon removal if you're not careful. Called around and got the $99 price for the upper, but nothing in stock locally. Decided to reuse the cover it and it's working fine so far.
However, my upper cover had no protruding metal bushings. Neither did the lower. I'd like to keep a good one on hand for "just in case" sake, but now I'm confused about the correct part. Am I interpreting the descriptions correctly that either the upper or lower part will have protruding metal bushings?
BK
BK_89iX is offline   Reply With Quote
Old 06-02-2010, 01:15 AM   #29
bbqross74
Galt, Ca
1997 xlt 4x4
Vehicle Specs
Quoted: 0 Post(s)
Just an update from my thermostate housing upgrade. Got all the parts I needed from rock auto. It took about 4 days to get. All the parts matched the numbers I had ordered. Read all the postings from other explorer anthusiasts on how to change out the thermostate housing. Found out that when removing the hosesfrom the housing that the housing had become brittle from age. Some of the necks on the housing had brocken off inside the hoses. I had to remove the pieces which took a little more time. Ounce the upper housing was removed I could see that the temp probe bases were leaking and were loose in the lower housing. The lower housing has three tabs that help to line the housing up with the intake manifold when removing the lower housing one of the tabs had broken off I had to fish the piece out from the manifold. The installation went pretty well with the information I had found from this forum. Sorry I did not get a chance to take pictures for everyone to see. Thanks to everyone for the information it really helped with my project.
Old 06-02-2010, 01:25 AM   #30
bbqross74
Galt, Ca
1997 xlt 4x4
Vehicle Specs
Quoted: 0 Post(s)
The upper housing or cover did not have any protruding bushings but the new lower housing that I purchased did. The guide bushing from the new lower housing would not go into the reused upper housing. From previous messages from other enthusiasts the choices were to either remove bushing inserts from upper housing or remove the new guide bushing from the new housing. Hope this helps
Old 06-02-2010, 01:36 AM   #31
BK_89iX
CA
'97 SOHC
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Got it - thanks.
BK
Old 06-02-2010, 08:25 AM   #32
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer AWD
Vehicle Specs
Quoted: 211 Post(s)
Yes, sorry it's the lower housing that is the problem, that part has the sensors in it. The upper is fine to keep if it's not hurt from removing the hose. Regards,
__________________
Don
91 Lincoln LSC/SE/GTC, 99/93 Explorer Limited 4WD, 98 AWD Mounty, 98 Limited with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors.
The best thing that could help us all, is the Fair Tax Plan.
Be American, Buy American (Manufacturer)
CDW6212R is offline   Reply With Quote
Old 07-09-2011, 01:26 PM   #33
BubbaFL
Central Florida
1986 Corvette
Vehicle Specs
Quoted: 24 Post(s)
Sensor part numbers
I just finished this project - it took a few hours to find the right sensors.
I used:
Motorcraft SW-6146 is the "temp sender"
Autozone / Duralast SW2301 "temp sensor" , equivalent of Motorcraft DY1004
The sensor for the computer, and sender for the dashboard gauge, are not interchangable - they are keyed differently:
The Duralast part is on the right and feeds the computer. The Motorcraft part is on the left and feeds the gauge.
BubbaFL is offline   Reply With Quote
Old 01-24-2012, 11:52 PM   #34
rokr1292
richardsville va
'01 Explorer Sport Trac
Vehicle Specs
Quoted: 1 Post(s)
Just looking at that picture of the sensor retainer clips, I'm thinking when I replace my thermostat (I'm just going to replace it all when I get paid) I might use some safety wire instead of those clips, just run it through in a "U" shape and twist the ends snug. I don't know, id just feel more comfortable with that than messing with paperclips
Ignore me, just clicked that that pic wasn't of the right clip. :P
__________________
Gold 2003 Ranger regcab 2.3 xlt. (Old dd, handed off)
Silver 2001 Explorer Sport Trac 4x4 (new dd as of 3/7/11)
rokr1292 is offline   Reply With Quote
Old 02-01-2012, 05:53 PM   #35
06ExplorerLTV6
Phoenix, AZ
2006 Ford Explorer LT V6
Vehicle Specs
Quoted: 0 Post(s)
US 2006 Ford Explorer LT V6 Coolant Leak Around Thermostat Lower Housing
It was great to see this older post on lower thermostat housing leaks. My situation is kind of perplexing to me... I took off the lower them housing, with the upper still attached and did not break off the tabs that align with the outlet... check for cracks, holes and the like to find nothing... then reinstalled it again and started the engine... and it continues to leak (pressurized streams) from what looks to be from right under the outlet (front and back sides) directly under where the lower housing bolts down too... could there be small leaks from underneath the bolt holes?
06ExplorerLTV6 is offline   Reply With Quote
Old 02-26-2012, 08:15 PM   #36
jkfoote
San Jose, CA
'98 XLT
Vehicle Specs
Quoted: 1 Post(s)
Successful repair
Over the weekend I successfully replaced the lower thermostat housing. Here are my notes.
First:
A. Fantastic writeups and part numbers made this possible. Wow. Thanks.
B. What a PITA.
C. This job flirted with the limits of my mechanical ability - I was in the deep end of the pool without a lifeguard! But maybe my limits are now expanded. And like felling trees, surviving it is a rush.
Everything basically went as described in the write ups with the following exceptions:
1. I had the same problem with the outboard temp sensor as described by this post: Temperature sending unit will not unscrew.
The problem turned out to be the plastic tabs holding the internal brass nut (inside the housing) failed so the sensor just spun in place. The solution was more disassembly to allow removing the housing with the sensor still attached.
2. The interference from the routing of the camshaft position sensor cable directly over the top of the thermostat housing was a pain. In the end I removed the radiator fan and shroud plus the passenger front wheel to get access, then removed the idler pully so I could see that the cable was secured by two nylon press rivets. If I'd known that going in I could have just disconnected the camshaft position sensor then tugged hard on the wire at the nylon rivets to get it loose.
3. I have a vague recollection of seeing a mention of the heater hose problem. But I can't find it now so here it is again: The new lower thermostat housing's heater hose connector doesn't end up in exactly the same position as the original after reinstall. Fortunately the heater hose connection at the other end has an unusually long nipple, so just loosening the hose sliding it slightly inboard allowed everything to reconnect without leaks. If I had it to do over I'd replace this hose at the same time and cut the new hose slightly longer.
4. Definitely replace the bypass hose while you're there - you really don't want to do this again anytime soon.
5. Try not to drop sockets. It took me about 40 minutes to find the socket that fell off while reinstalling the throttle body. Sigh.
So with interruptions and the rental of the fan clutch tool the whole job took me about 7 hours. But then I'm old and feeble and my eyesight, manual dexterity and mental acuity are going to hell so it'll take you alot less time.
Bottom line: it worked perfectly, my leak is gone and I saved a pile of dough. Thanks again for all the great writeups.
jkfoote is offline   Reply With Quote
Old 11-29-2014, 11:32 AM   #37
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Vehicle Specs
Quoted: 926 Post(s)
NAPA and Dorman aftermarket sensor clips. (W706800S303)
http://www.napaonline.com/Catalog/Ca...034_0437476037
http://www.dormanproducts.com/p-6789...origin=keyword
swshawaii is offline   Reply With Quote
Old 09-23-2015, 01:16 PM   #38
SonicBlue302
Miami, FL
2001 Ford Ranger XLT 4.0L
Vehicle Specs
Quoted: 0 Post(s)
Hello. I recently changed my whole tstat assembly as well as it was leaking and would just like to add a few extra pointers with hopes of helping anybody doing this job in the future. My truck has a build date of 9/00' and came with the PUSH-IN style sensors and I opted for using the SCREW-IN type ones thinking theyd be more secure and less prone to leaking. At the end of the day I ended up breaking off the threaded part on the ECT sensor that came with my aftermarket housing as I was tightening it and ended up having to purchase a new ect sensor from Advance AP. The issue i'm having now is that the temp gauge sits 1/2 way all the time n goes up from there when the car reaches normal temp and sits around 3/4 of the way which left me feeling uncomfortable since I do a lot if driving. I am going to purchase another lower with the PUSH-IN style sensors and reuse my factory ones which were working fine since apparently the BWD ECT sensor purchased from Advance AP has a different voltage/resistance value, etc.
SonicBlue302 is offline   Reply With Quote
Old 09-23-2015, 01:25 PM   #39
SonicBlue302
Miami, FL
Vehicle Specs
Quoted: 0 Post(s)
Also, I have read on other posts that people have issues sometimes when changing or looking for O-rings on these sensors. I would like to add that you can also reuse your original O-rings if they're not destroyed and just put a good coat of #2 Permatex Non-hardening sealant on the orings and the housing to prevent leaks. You can also use Permatex on the new orings as well for extra peace of mind. Just my .02 and hope this helps someone in the future. I myself used Permatex on the o-ring that goes between the tstat housing and the engine block, tstat and upper hose cover, as well as where the hoses slip in since I've had leaks in the past from coolant hoses not sealing well especially on German vehicles which use clip-style locking pins instead of screw-on hose clamps. I also used a small amount of Anti-seize on hardware used to secure the tstat housing as they tend to seize up if you have a coolant leak since iron corrodes. Hope this helps someone else tackling this job in the near future.
Old 10-11-2015, 09:21 PM   #40
pinkic81
2003, sport trac
Vehicle Specs
Quoted: 1 Post(s)
Hello, I have an issue with the housing thermostat, the first one (original ) it has a huge leak so I replaced, but over of a year the new starting with a small leak and big leak, so I decide to buy a new one from different vendor but now started the leak again! so now I don't know where can I buy it from or where should I buy.... any body can help me.
Thanks in advance.
pinkic81 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Copyright 2016 - 1996 Rick Horwitz Photography Explorer Forum is celebrating it's 20th birthday!!
Ford Motor Company is not involved in the management of this site in any way.
