Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2007 - 2010 Explorer Sport Trac
Notices
2007 - 2010 Explorer Sport Trac All questions about the stock 2006- 2010 Ford Explorer Sport Trac.
4x4 vs. AWD ?
Reply
Thread Tools
Old 07-10-2010, 09:51 AM   #1
TruckerAlex
Vehicle Specs
(Original Poster)
4x4 vs. AWD ?
Hi!
I am looking in to the Sport Track, but I do not know the difference between 4x4 and awd. Can some one explain this? Thanks !
TruckerAlex is offline   Reply With Quote
Old 07-10-2010, 03:05 PM   #2
GSU4x4
Statesboro, GA
'07 Sport Trac XLT
Vehicle Specs
Someone can correct me if I'm wrong but AWD is when your vehicle is always using all 4 wheels to drive with, AUTO 4WD (like on the ST) is when the truck feels like it is losing traction and changes from 2 wheel to 4 wheel drive, but only at lower speeds (less than 45 mph)
My ST has the AUTO 4X4 system and I personally dont like it, I would much rather have a button to allow me to stay in 2WD if I want (like my old '98 4x4 Ranger).
__________________
07 Sport Trac V8 4x4 XLT - Silver Birch
08 Honda 600RR - Sunfire Pearl Orange
GSU4x4 is offline   Reply With Quote
Old 07-10-2010, 04:22 PM   #3
FLOffroad
08 Sport Trac Limited V6
Vehicle Specs
He's correct.
AWD is designed more for keeping traction while on road and possibly adverse road conditions.
4x4 is for offroading, and not to be used on the road (except for the Auto 4WD in the case of Sport Tracs and Explorers)
FLOffroad is offline   Reply With Quote
Old 07-10-2010, 05:44 PM   #4
SkanlaxJMO
Syracuse, New York
96 XLT
Vehicle Specs
4wd is a 50% power split between the front and rear differential.
AWD typically has a 60% rear 40% front and that changes when under different acceleration and speeds etc. AWD is a street/ mild weather type system.
__________________
2005 F-150
SkanlaxJMO is offline   Reply With Quote
Old 07-10-2010, 10:29 PM   #5
JohnnyO
Sport Trac Moderator
Pittsburgh, PA
JohnnyO's Avatar
'08 Sport Trac
Vehicle Specs
The later Sport Tracs and Explorers are not AWD because the front wheels do not receive power all the time, even in 4-Auto. The front end only kicks in when the traction control detects slippage. Personally I find it irritating so when I need 4wd, which I needed a lot of this past winter, I just lock it in 4-Hi and very often I turn the traction control off because when ALL the wheels are slipping it makes the engine take a crap at the least opportune times. This essentially gives you open diffs front and rear and in deep snow my '08 didn't do nearly as well as my old '05 Trac or '02 Ranger did with their limited-slip rears.
__________________
'08 Sport Trac, Gibson exhaust, K&N, Firestone Destination A/T's, Steelers regalia.
"It is not the multitude of ale-houses that occasions a general disposition to drunkenness among the common people; but that disposition arising from other causes necessarily gives employment to a multitude of ale-houses." -- Adam Smith, 1776
JohnnyO is offline   Reply With Quote
Old 07-10-2010, 10:49 PM   #6
kstrayhorn
Landmark, Little Rock, AR
'02 XLT
Vehicle Specs
With the bwm, they are the same!!
__________________
2002 Ford Explorer XLT
4dr 2wd with a 4.0 SOHC
Kstrayhorn's Build Thread/Registry
kstrayhorn is offline   Reply With Quote
Old 07-11-2010, 12:09 AM   #7
rhauf
Ca
rhauf's Avatar
'93 and '91 explorer
Vehicle Specs
geez everybody has a separate explanation.. well here's the right one.
4 wheel drive:
front and rear axle are turned in unison by the transfer case. they ALWAYS turn at the same speed regardless of torque, traction, etc. pros: best traction off road, because power is never taken away from the axle with traction and given to the axle without traction. cons: does not allow for a difference in rotational speeds between from and rear axles. for instance, while turning a corner, one axle (or wheel) is forced to slip due to the difference in distance traveled (the front will make a larger arc around the turn than the rear) so with 4x4 you always have a 2x4 (rear wheel drive usually) option for use on high traction surfaces where this would become a problem (like dry pavement)
AWD (all wheel drive): There is a differential separating the front and rear axles, which allows for a difference in speed between front and rear. AWD is designed for on-road use, giving high performance in low traction conditions (snow, ice, wet roads, dirt roads etc) there is usually a clutch (limited slip) in the center differential, which helps prevent wheel spin on one axle alone. the cons to an AWD system are that it does not perform as well in extreme off-road conditions, it usually cant be disabled (more parts always running) and the biggest con in my opinion is that in most AWD systems, all the tires have to have the exact same diameter or it will damage the center differential. for instance, if one tire is warn down more than the others, you will be forced to buy a whole new set (or risk damaging the system)
__________________
Check out my Youtube page, many explorer and 4wheelin' videos
http://www.youtube.com/user/rhauf1
rhauf is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
