EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Overheating: Radiator or head gasket?
Reply
Thread Tools
Old 07-14-2010, 06:33 PM   #1
tweakedlogic
memphis, tn
'92 XLT
Vehicle Specs
(Original Poster)
So my truck over heats. I have a stock motor and radiator, w/ 17" electric fan.
the first time it happened is after I fixed the A/C. I noticed in stop and go traffic the temp would rise. I never let the needle get above the A in Normal. I would shut off the a/c.
I then installed the current 17" fan replacing the 15" fan.
It was better for a few weeks. But I did some suspension mods and it has sat for two weeks until today. I was running around town and noticed the temp was already at A. so I shut off the a/c and it started to cool down. I parked for a while and left the e-fan on. got back in and it was @ O. Cool. I left the a/c off, but got stuck behind some traffic for several minutes. I saw the needle start to climb again. the a/c was off.
It doesn't use any water and I've never seen any leaking. So, is it a clogged radiator, or a bad head gasket?
Gaskets are cheap, but a pain to install. radiators are easy to install, but expensive.
I don't know what to do.
__________________
2001 4x4 Sport Trac. it's new to me, so no mods yet.
1992 XLT 4 door 4WD: 32s on 17" Mustang GT rims, 4.56 w/ modified LS in rear, 2.5" lift from F150 coil springs, F250 shock mounts, shackles, Pro comp shocks, hard way rear disc conversion, Ported and polished intake, Dynomax exhaust, e-fan, + other mods I've done since this edit. (Switches, Black,)
tweakedlogic is offline   Reply With Quote
Old 07-14-2010, 06:42 PM   #2
Ahteixeira4x4
Turlock, Ca
92 XLT
Vehicle Specs
If you have water in your oil than it is your head gasket.
Ahteixeira4x4 is offline   Reply With Quote
Old 07-15-2010, 12:50 PM   #3
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
what fan are you using?the ex needs about/over 3000cfm to stay cool
__________________
92 xl 5.5"duff arms,3"BL,PJ 36x14.50,wrapped headers,side dump exhaust,.20 over,HF oil pump,422cam,45cc 95tm p+p 10.67:1 heads,p+p lower manifold,75mm TB,90mm maf,36lbs injectors,P+P GM M90 Supercharged & intercooled!!SCT tuned!!electric fan,4.88s aussie locked front & back!!next NOS&W/M
http://www.explorerforum.com/forums/...=double+vision
jd4242 is online now   Reply With Quote
Old 07-15-2010, 01:02 PM   #4
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
What your describing is not enough airflow. If its fine at say 50mph cruising then its more likely the fan. If at 50mph it overheats then your looking at the radiator..
For head gasket you would have oil in the water, water in the oil and or smoke out the tailpipe.
Since your running an electric fan, you really need to make sure its pulling enough cfm. There have been mixed results using the blackmagic fan which pulls "around" 3000 cfm on the 1st gen explorers. It seems to be partly related to how the vehicles are driven and in what climate.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is online now   Reply With Quote
Old 07-15-2010, 06:18 PM   #5
tweakedlogic
memphis, tn
'92 XLT
Vehicle Specs
(Original Poster)
I don't remember the CFM rating. It's the same fan I use in the Rx7. If it's enough for the heat generating rotary @ 8000 RPM on the track, it will be enough for any stump pusher.
I don't have any oil in the water, or water in the oil, and no steam from the tail pipe. I guess it must be the radiator. Darn! I didn't want to replace it until I could afford the 2 core triple pass. @ $600, I will have to wait for that and buy a OE. Thanks guys.
__________________
Old 07-15-2010, 07:21 PM   #6
rhauf
Ca
rhauf's Avatar
'93 and '91 explorer
Vehicle Specs
get rid of that elec fan and put in a stock clutch fan and shroud.. it'll work way, way, way better.
i'd also replace the radiator. i'm just running the best one i could get from autozone and it works great (even towing, even in 100 degrees) of course i'm running the stock fan too.. which whurrs like crazy when its hot.
it is possible that it could be a cracked head/blown head gasket just not involving the oil... but id put my money on cooling first.
__________________
Check out my Youtube page, many explorer and 4wheelin' videos
http://www.youtube.com/user/rhauf1
rhauf is offline   Reply With Quote
Old 07-15-2010, 07:46 PM   #7
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
8000 rpms on the track means your moving.. If your moving 50mph or so then the fan isn't helping anything since you moving 50mph is going to push more air than that fan can..
Now, if you said it could keep it cool a 8000 rpms while in neutral, that would be different.. When your not moving or your moving slowly is when the fan is doing its job...
~Mark
__________________
Old 07-15-2010, 08:26 PM   #8
92exp4x4
Covington, Kentucky
92exp4x4's Avatar
92 XL 2-door and others
Vehicle Specs
Maniak is right, if you are moving at all, then the fan's need to exist goes down. Also the shroud makes a big difference to how much air is pulled through the core of the rad. With no shroud the air can be drawn from between the fan and the rad because it is easier to move it from there. Think the path of least resistence. Also there were two radiators available. A single row core and a 2 row. I have converted all mine over to the 2 row for more capacity. If yours is a two row then the core will be about 2 inches thick.
__________________
My stable:
2 doors - '91 Eddie Bauer; '92 XL 5 speed; '92 Sport 2WD 5 speed
4 doors - '91 XLT; '93 XLT; '94 XLT, 6" lift, 33's; '94 Eddie Bauer 5 speed; '94 Limited
Others - '22 Model T, '48 8N tractor, '62 Fairlane 500, '93 F-Superduty 460, '97 F250 Powerstroke, '04 F550 service truck (company owned)
92exp4x4 is offline   Reply With Quote
Old 07-16-2010, 01:17 AM   #9
tweakedlogic
memphis, tn
'92 XLT
Vehicle Specs
(Original Poster)
I don't think you guys understand the rotary. it makes hellasious heat. the one thing that kills them. then boost them and run them on the lean side with advanced ignition curves and you have a kiln.
it is not the fan. I know this fan pulls more air than the stocker.
I was worried it may be the head gasket because a fiend of mine suggested it may be and wanted me to come over to his shop and test the head with a pressure gauge on the radiator. I would do it if he wouldn't make me do all the work while he made un-funny jokes and got in the way.
I will just ahve to for go some planed mods for a while linger so i can buy a radiator. It's just really bad timing. boss closed shop so I lost my job this week and after some suspension mods I really need an alignment.
I do appreciate your help.
__________________
Last edited by tweakedlogic; 07-16-2010 at 01:23 AM. Reason: deleted things that might mis-construde
Old 07-16-2010, 01:27 AM   #10
rhauf
Ca
rhauf's Avatar
Vehicle Specs
We understand that those rotary/Wankel engines have cooling problems, you made that clear. but that doesn't mean it generates more heat than a 4.0. which engine uses more fuel? i'd be inclined to think that the fuel consumed by the engine would be in direct relation to the heat generated by it (impacted very slightly by the efficiency of the engine)
besides, as pointed out, the car moving down the road doesn't require the fan. so the lower speeds are more critical on the fan.
i used to be big on removing stock fans, and replacing them with thermo switched electric fans to "Save horsepower" however, after dealing with the overheating problems, ive moved back to mechanical clutch fan and the overheating problems have gone away (on a variety of cars/trucks)
however if you're confident with the elec fan, which i guess you are, then i'd say upgrade the radiator, and maybe replace the thermostat in case it's jamming. then you can address a head issue if the problem persists.
__________________
Old 07-17-2010, 12:15 AM   #11
tweakedlogic
memphis, tn
'92 XLT
Vehicle Specs
(Original Poster)
Quote:
I'm going to do a radiator. I was planning on replacing it anyway but I can't afford that. So I'll buy an OE and toss it in, maybe keep it for a spare after the 3 core upgrade.
Thanks.
__________________
Old 07-17-2010, 12:21 AM   #12
rhauf
Ca
rhauf's Avatar
Vehicle Specs
cool. let us know how it works out.
__________________
Old 07-17-2010, 08:14 PM   #13
Czar Zach
Chino, California
1993 XLT
Vehicle Specs
I've recently replaced my thermostat, my head gaskets, and i have fluctuating heat problems also. So my next bet would be replacing my radiator, correct?
And if that's the case, would it be better to upgrade to a two core, or is it not too much of a difference than the one?
Czar Zach is offline   Reply With Quote
Old 07-17-2010, 08:35 PM   #14
mr2fix2it
new york
98 sport w/06 mustang 4.0
Vehicle Specs
stop throwing your money away even more so since you dont have any the problem is the fan not the radiator look at the replies and the logic the fan is not made for an EXPLORER this is not a mazda WENKEL
mr2fix2it is offline   Reply With Quote
Old 07-18-2010, 12:40 AM   #15
tweakedlogic
memphis, tn
'92 XLT
Vehicle Specs
(Original Poster)
It's not the fan. I really only have a problem when i run the a/c. it has been better the last few days as far as stop lights. I haven't turned on the a/c since the first post. This radiator has over 200,000 miles on it. this is a new body, but under the hood is the same i've been driving for over 5 years. When i pulled this motor from the other body, the a/c didn't work. so I don't ahve a reference point. perhaps, when I run the a/c, i am surpassing the capacity of the old radiator. One of the reasons I opted to use the e-fan is the old fan clutch was shot.
as for the Wankel, it may only be a 1.3 liter (or 2.6 depending on who you ask) but it draws more air than a 5.0. I'm sorry i ever brought it up. but I know it's not the fan.
__________________
Old 08-01-2010, 01:32 AM   #16
tweakedlogic
memphis, tn
'92 XLT
Vehicle Specs
(Original Poster)
I found out the 1800-RADIATORS has a local "store". Bought a new rad for $97. Installed it the next day. heat problems gone. I also swapped the t-stat, though i couldn't find a 180 degree model. only 195.
I am considering adding a 10" or smaller fan in front of the condenser just to further aid in cooling when running the a/c.
Thanks guys.
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
