Brian1 91 XLT 4x4 | Ford Explorer Forums - Serious Explorations
Brian1 91 XLT 4x4
Brian1's 1991 Ford Explorer
Moab Edition
Drivetrain:
4.0 V6
BrianBuilt intake adapter with AEM Dryflow filter and Pre-filter
Dynomax cat back exhaust with
High flow cat
Spectre 3" Aluminum intake
BBK Throttle Body
5 speed manual trans With custom transmission mount
4.10 gears
Front D35 TTB, locked
Rear 8.8 with disc brakes, Powertrax No-slip locker, welded tubes to diff, Riddler Cover
Warn manual hubs
Manual BW1354 Transfer Case (swapped in)
Chassis & Suspension:
Skyjacker 2" coils and add a leafs
1" custom aluminum body lift
Quick disconnect front swaybar
Bilstein 5125s 10" shocks rear
Bilstein 5125s 10" shocks front
F250 Shock Tower Conversion
Custom Extended Radius Arms
Interior:
PRP daily driver seat
Cobra CB
E-track cargo tie down system
Lowrance HDS 5 Baja GPS for offroad explorations
Yaesu FT2800 HAM Radio
Wheels & Tires:
LT265/75R16 Dick Cepek Trail Country EXP tires (currently, Cooper STT and BFG MT in the past)
16" GenII teardrop wheels, formerly had 15" stock Gen II teardrop wheels
Misc:
Warn 9000lb multi mount winch with synthetic rope
Onboard Air using Viair 480c compressor and 2.5 gallon tank
Front diff guard from BrianBuilt
Rear u-bolt skid plates and raised shock mounts from BrianBuilt
Raised axle and t-case breathers
Custom Bolt-on Rock Sliders (version 2.0)
Custom Winch bumper
Custom rear bumper with tire carrier
9" Vision X ADV Cannons LED Lights (Old: 9" import LEDs and 7" HID Lights)
Reverse light
Pro-comp extended brake lines
9007 Headlight conversion
Fuel Pump Access Panel
Replacement Door Weatherstripping
Dual Batteries with auxillary fuse block
ARB Awning
ARB Fridge
Maxtrax Recovery Boards
Trasharoo Spare Tire Trash Bag
Project Super Stock
I would tell welcome to the site but you have been here a lot longer than me:D Nice rig. I like the roof rack.
is your explorer stock height? if so, WOW:eek: .
i cant belive you did all that without a lift and bigger tires.
nice pictures
It looks like you have 31's. And an Explorer with 31's is very capable of many things. I am amazed at what I can do with mine.
Yes my explorer is stock height with sagging stock springs. The tires are 29" BFG's (LT235 75R15) stock size.
The first picture I didnt make it. I was really close. I could have tried again with a different line but my foot was hurting from the clutch pedal. Get the moab video and you will see me trying to climb up that rock.
nice x u got there brian
any new updates?
The list above is pretty much current including my latest few mods like Viar on board air and the fuel pump access panel. I do have some mods in the works but my Explorer will stay about the same, just better :D
I will add this-
I have been focusing most of my 4 wheeling in remote backcountry locations as well as making trips to get there. With over 200k on the odometer I carry many spare parts for any backcountry repairs. Most fit in a small ammo can while a few others I have stuffed in other places. What I carry:
serpentine belt
computer
new fuel pump
new fuel pressure regulator
various vacuum and fuel hose
fuses both sizes
new starter relay
driveshaft bolts
new ujoint
radius arm hardware (nut/washers)
new locking hub
radiator cap
thermostat
fuel cap
TPS
IAC
misc wire and connectors
2 spark plug wires
1 new fuel injector
O2 sensor
Still on the list to get is a belt tensioner, MAF and fuel filter
Brian,
I'd suggest changing your fuel pump at 200,000 miles. Mine died at around 220,000 - fortunately, I was only 10 miles from my house.
Better to change it when you want to, at your house, than when it decides to die, somewhere out in the backcountry, in the middle of the night in the pouring down rain.
...Heck, he's already going crazy with changes..He even changed his Avatar..:eek:
I was looking at my old avatar a few days ago and noticed my Explorer still had the roof rack on it, that picture was old! It was time for a new one.
...And your Ranger happens to make a very small guest appearence in my new avatar :D
But not mine?!?!?!?!?!
^^^Ha Ha...:p:
...Where is that pic from? I just figured it was from your latest run..:scratch:
Mojave Road, huh? Hmmmm.......
