cbrock
- February 12, 2006
- Athens, GA
- 05 Infiniti G35 Coupe 6MT
I believe I have a bad transfer case causing a thumping noise when in motion. Is it safe to completely remove the front drive shaft and only rely on RWD from here on out? Or at least until I can afford a new xfer case. One local shop tells me that removing the front shaft will throw an error code and screw up the transmission but that is contrary to what I've read on here. I don't need the AWD since I live in GA where it snows once every 5 years, and no way I'm getting on the roads with other nutjobs in those conditions!!
If it is safe to remove, how do I go about doing so? I wasn't able to find any instructions by searching.
Any help is greatly appreciated in advance!!
-Chris
-Chris
