Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Tow Rig Forum
Notices
Tow Rig Forum Towing, hauling, boats, campers, trailers etc... Trailer hitches, weight distribution, hitch ball, safety chains, tow bar and brake controllers. Discuss it all here!
Cant Find trailer plug
Reply
Thread Tools
Old 07-30-2009, 10:22 PM   #21
Silverblade
BC, Canada
97 SOHC
Vehicle Specs
just ran outside quickly, didnt spend much time but no connection on pass side on my 97 without tow paackage, any thoughts?
__________________
Black 97 SOHC, Black 20" Boss 226s w/ 275/45 Hankook Ventus ST06s, Diamond cut heads and corners, Billet, 99+ front bumper w/ Billet, 4300k HIDs, Clear/red/clear tails, Cold air.
Silverblade is offline   Reply With Quote
Old 07-30-2009, 11:50 PM   #22
TexanF250
Pearland, TX
96 Explorer Sport 4WD
Vehicle Specs
Quote:
Originally Posted by Silverblade View Post
wouldnt you want to hook it to the passenger side, as per the diagram posted at the top?
I bought a connector yesterday, oem ford part to connect a trailer. On the diagram it came with it said to plug into drivers side, which i did. The only thing coming out of the drivers side was the lights for the licence plate, so i disconnected those and ran it anyways. I have no running lights, left signal does nothing, right signal = hazards and brake lights work. I will try looking for a connection on the passenger side as per the diagram, hopefully I dont need new relays and connectors.
You found the correct location on the drivers side. Use a multi meter or test light to check all of the pins feeding the wiring harness for the license plate light. If the yellow, green and brown wires are dead, you are most probably missing a couple of fuses and a couple of relays. This was the case with mine. Look in your owners manual for the location of these fuses and relays.
There is a very large 30A fuse in the fuse box in the engine compartment that wwas missing on my Explorer. Also missing were the two realys in the relay box that is attached to the inner fender tucked behind the battery. I seem to recall that there was also a 15A fuse in the fuse panel inside the vehicle that might also ahve been missing.
TexanF250 is offline   Reply With Quote
Old 03-14-2010, 10:26 PM   #23
GopherBaroque
Washington
GopherBaroque's Avatar
'95 2D 4WD
Vehicle Specs
I removed the rear bumper from my 95 2Dr to paint it to match my new front winch bumper (RLC Welding). Here is a picture of the wiring behind it:
GopherBaroque is offline   Reply With Quote
Old 11-23-2010, 11:17 PM   #24
Newfiedan
Saskatoon, Sk, Canada
2003 ford escape
Vehicle Specs
need help with 01 sport trac
hey guys I have a buddy with an 01 sport trac he did not get the one with the trailer plug already but like most fords I am sure that there is a plug there for a factory add on harness. anyhow long story short anyone know where the plug is located on the sport trac and what harness I need to get to plug into it to give him his 4 way flat pin connector?
Newfiedan is offline   Reply With Quote
Old 02-12-2011, 04:07 PM   #25
jordan101
versailles,mo
97 xlt
Vehicle Specs
i have a 97 xlt 4.0 sohc and my connector is tucked under bumper like right under license plate. It is a light blue round connector with a cap on it.
jordan101 is offline   Reply With Quote
Old 03-06-2011, 11:08 AM   #26
Jason c
The Dark Knight
Portland, OR
Jason c's Avatar
2000 Limited 5.0L
Vehicle Specs
Just a note, on the 2000 explorers, the passenger side plug is for the back-up sensors.
Jason c is offline   Reply With Quote
Reply
Tags
towing, trailer
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
