Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
Suspension Lift Help!!
Reply
Thread Tools
Old 04-21-2011, 09:29 PM   #21
OffTrac
Dublin, GA
OffTrac's Avatar
'01 Sport Trac 4x4
Vehicle Specs
Strength would be the only reason for going with the D60; that and its already at arms length. If he uses it, I'll go with a D44.
I'll probably try to go linked in the first place only because I feel like if I did leafs, I'd want to change it in the future to a linked setup. I'd prefer to be one and done.
I was just thinking about supercharging because it would be easier than a full 5.0 swap. The 4.0 would be sufficient off road without anything, but highway speeds could use a little help. Power isn't really important when the highest speed limits around your town are 45. Occasionally I get out on the highway and go 55.
I already have 4.10 gears. That'll change.
I do have a spare 351W I could try to wedge in there if I really wanted to go crazy. I don't want to go crazy, though.
__________________
My Registry
OffTrac is online now   Reply With Quote
Old 04-22-2011, 04:08 AM   #22
Blake A
Florence, Alabama / Searcy, Arkansas
2001 Sport Trac 4x4
Vehicle Specs
(Original Poster)
Quote:
Originally Posted by chad551 View Post
A dana 60 up front is not any different than a Dana 44 other than it is stronger axle. You will still install it the same way either linked or leafs. There are several Explorers with Dana 60's up front. And if you put the correct gears in the axle a 4.0 will turn 37" tires all day long down the highway and on the trails.
Also Blake where did you see a D44 kit for a Sport Trac?
im pretty sure it was on 4wheelparts.com but i just googled Dana 44 front axle and found it.
im really leaning towards a spring over front end, i don't really like the look or ride of leaf spring front ends.
__________________
White '01 Sport Trac SOHC 2'' TT lift 31.10.50 BFG Mud Terrains KM2's Herculined Cladding.
Blake A is offline   Reply With Quote
Old 04-22-2011, 04:35 AM   #23
Tifoez & Lavinia
SW Pennsylvania
Tifoez & Lavinia's Avatar
'01 XLT
Vehicle Specs
Dk Exp
I have a complete donor 1979 Early Bronco 302 5spd on dana axles for $600. I'm swaping out the entire drive train, that should be sufficient..?.. Maybe on 35's
__________________
Booger.. '01 X XLT, SOHC, white gauges, trans temp gauge, no wheels. on blocks getting ready for carlisle
Tifoez & Lavinia is offline   Reply With Quote
Old 04-22-2011, 05:47 AM   #24
chad551
St.Louis, MO
chad551's Avatar
2002 Explorer Sport Trac
Vehicle Specs
I think I can safely say there is no "kit" that swaps a Dana 44 axle into an Explorer based vehicle Well at least a Sport Trac.
__________________
2002 Explorer Sport Trac, SOLD....My SAS Thread
Photobucket Site
My rock slider build
chad551 is offline   Reply With Quote
Old 04-22-2011, 05:51 AM   #25
chad551
St.Louis, MO
chad551's Avatar
Vehicle Specs
Supercharging a 4.0 would be easier than a 5.0 swap for me mainly because in Missouri we have emissions and a PCM from an older Explorer with a 5.0 would instantly fail my truck. I want a 5.0 swap so bad but I cannot do it. So I am now leaning towards the STS turbo setup for my truck.
__________________
Photobucket Site
Old 04-22-2011, 07:51 AM   #26
JohnnyO
Sport Trac Moderator
Pittsburgh, PA
JohnnyO's Avatar
'08 Sport Trac
Vehicle Specs
Quote:
If it's an early Bronco the newest it would be is 1977. 1978-up full size Bronco axles are too wide.
__________________
'08 Sport Trac, Gibson exhaust, K&N, Firestone Destination A/T's, Steelers regalia.
"It is not the multitude of ale-houses that occasions a general disposition to drunkenness among the common people; but that disposition arising from other causes necessarily gives employment to a multitude of ale-houses." -- Adam Smith, 1776
JohnnyO is offline   Reply With Quote
Old 04-22-2011, 07:10 PM   #27
Blake A
2001 Sport Trac 4x4
Vehicle Specs
(Original Poster)
not really a kit i guess but i just put in my trucks info and it popped up.
i know the jeep rubicon has a D44 but what about the sport? is it a 35? i know where one is parting out now.
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
