Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Broken Shift Lever 2002 Explorer 4X4
Reply
Thread Tools
Old 07-22-2011, 03:00 PM   #1
Spit
Columbus Ohio
2002 XL
Vehicle Specs
(Original Poster)
So I get a call this morning from my daughter...she and her husband were not able to get her Explorer to shift out of Park. He forced it and broke the shift lever....not the die cast piece with the ears that the lever attaches to with a pin...but the actual lever itself! Broke it right off at the pin!
2 things...why wouldn't it shift out of park? Where can if get the lever? I see the Dorman 905104 kit for the die cast piece...but that's not what is broken here...the lower inch & half of the lever along with the pin is still in the steering column.
I think i can install the 905104 if that is what it needs..but like I said it isn;t what broke...I did read the owner's manual and tried to to the interlock bypass thing...putting a screw driver tip through the slot but it didn't work.
Any ideas?
Spit
Spit is offline   Reply With Quote
Old 07-25-2011, 10:00 AM   #2
Spit
Columbus Ohio
2002 XL
Vehicle Specs
(Original Poster)
Fixed
I pulled the pin and removed the broken off lower piece of the shift lever. Once it was out I could get it to shift using a pair of needle nose pliers, drove to a junkyard at first they wanted to sell me a complete steering column...when I showed him the broken handle...not the die cast cylinder..he said that I was lucky and that a handle alone would work. He let me pull a replacement lever for $10..seems to be shifting fine with no sticking? I wonder if the handle being bent or partially cracked at the pin hole was the entire problem.
No doubt when it cracked completely it would get pushed into a locking position from the indent spring. Any thoughts or ideas on this?
Spit
Reply
Tags
2002, shifter
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
