EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
2001 Sport 4x4 issues
Reply
Thread Tools
Old 10-25-2011, 05:35 PM   #1
Matt ATO HP
Orlando
2001
Vehicle Specs
(Original Poster)
I just picked up a 2001 Explorer Sport 4x4. Pretty solid truck thus far, but the 4x4 won't engage. When I shift into 4high or 4low the lights on the dash don't come on and there is no change in drivability. I have not gotten the chance to get under the car to see if there is anything I am missing, but I did pull off the dash (I was thinking that it may have just not been connected) and everything seems fine there. I am at a loss! Any help or suggestions would be awesome!!! Thanks in advance.
Matt ATO HP is offline   Reply With Quote
Old 10-26-2011, 08:07 AM   #2
albi1cnobi1
Elite Mountaineer
South Jersey
albi1cnobi1's Avatar
99 Mountaineer V6 4x4
Vehicle Specs
The first things to look for are blown fuses. Fuse #6 is a 20a maxi fuse in the battery distribution box. Fuse #26 in the fuse panel as well. Second, a common problem with this system is the shift motor. It's bolted to the back of the transfer case. If it wasn't used much and the motor locked up, or the internal stop is bad you'll have an issue. If the fuses are good you can try tapping on the shift motor lightly( read-don't beat it to death) with a hammer. Sometimes that frees it up. If you get a used one from the JY just remember it won't work unless you bolt it to the transfer case. The motor uses the t-case for it's ground.
__________________
Al
99 Mountaineer 4.0 SOHC.
TT/Warrior Shackles, 2" BL, 32x11.5/15 BFG A/T's, Rancho 5000's, Supplemental HHO Generator(out for cell redesign), Electric Fan Conversion, AVM Manual Lockout Hubs, Dual Battery System, Gibson cat back exhaust. EATC Mod. BW1354 swap, finally done! My 4405 To 1354 Swap Thread Support your own economy, Buy American, all of our jobs depend on it.
albi1cnobi1 is offline   Reply With Quote
Old 10-26-2011, 01:24 PM   #3
Matt ATO HP
Orlando
2001
Vehicle Specs
(Original Poster)
It looks like the fuses are in different locations, the ones I checked were 11, 25, and 35 in the fuse panel and 7 and 13 in the battery distribution box (that is the info I got from the ford service manual online). But, point of the story is they are all fine. I am going to be getting under the truck later today to see if I can further eliminate problems.
If the shift motor is frozen and I switch to 4wd, does that mean that the lights will not come on? Like I said, I am going to be playing with it later today to try to get to the bottom of this. It isn't like I need 4wd right now, but it is nice to know that I have it available (and not have to manually get under there to engage it) if the need arises.
Old 10-26-2011, 01:30 PM   #4
albi1cnobi1
Elite Mountaineer
South Jersey
Vehicle Specs
Yes, if the motor isn't switching the lights won't work. There is a sensor ring in the round flat area on the end of the shift motor. As the motor moves the sensor ring rotates and contact switches tell the motor when to start, stop and which indicator lights to light up. Right, you have a sport. Fuses are a little different.
__________________
Al
Old 10-26-2011, 01:46 PM   #5
Matt ATO HP
Orlando
2001
Vehicle Specs
(Original Poster)
Thanks alot for the help, I am going to get working on it right now!
Old 10-26-2011, 02:34 PM   #6
Matt ATO HP
Orlando
2001
Vehicle Specs
(Original Poster)
So, I tried the tapping trick and that did not seem to make any difference. What might my next steps be?
Old 10-26-2011, 03:28 PM   #7
mtwrench540
monterey,va
2000 explorer elt
Vehicle Specs
4wd
have some one help. have them put truck in neutral and switch from auto to 4wd and 4wd lo while you listen and feel shift motor on transfer case.
mtwrench540 is offline   Reply With Quote
Old 11-02-2011, 03:21 PM   #8
Matt ATO HP
Orlando
2001
Vehicle Specs
(Original Poster)
So, I just got done putting in the new motor... it isn't the problem! Lights still are not coming on and I don't hear any noise when switching into 4x4. Now I am at a loss.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Electrical issues, 2001 Sport 1998Explodasport Stock 1995 - 2001 Explorers 1 09-30-2010 07:43 PM
2001 Explorer Sport 4x4 problem ddansvob Explorer & Ranger Transmissions, Transfer Cases, & Differentials 0 01-09-2009 09:39 PM
2001 sport 4x4 / shaking at 60-70 mph markcentral66 Under the Hood 3 04-11-2005 08:29 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
