Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
Help, annoying ticking noise
Reply
Thread Tools
Old 12-22-2011, 07:48 PM   #1
SouthernSAR
Naples, FL
SouthernSAR's Avatar
2004 Explorer ST XLS
Vehicle Specs
(Original Poster)
Exclamation Help, annoying ticking noise
So I just bought an 04 ST 2wd, and I've gotten most everything fixed up that needed to be fixed (brake light replaced, wheel bearing tightened). She runs fine, occasionally I'll lose RPMs and it'll seem like the engine is stalling or something, but that's another issue for another time...
Right now my problem is in the front drivers side area. Whenever the truck is shaken, bounced, or rocked, I hear a tick. I can't hear it or it doesn't happen while I'm in forward or reverse motion, just stationary. What is it and what could I do?
__________________
ZAPV373- 2004 Explorer Sport Trac XLS 2WD
Quote:
Originally Posted by jcerrion View Post
flame throwers come standard on the XLT.
SouthernSAR is offline   Reply With Quote
Old 12-23-2011, 05:21 PM   #2
LONO100
Bay Area CA
LONO100's Avatar
03 sport trac XLT
Vehicle Specs
the inconsistent rpm might be a vacum leak. check the sticky on the p0171/p0174 check engine codes. this might be your culprit. also, if you hear a ticking noise in your engiine, check your oil and see if it is low. if it is, you could have low oil pressure which is causing your engine to make that noise. it could also be something worse, the timing chain tensioner could be broken which is bad. does it make the ticking noise when you first start it in the morning and then seem to go away as you drive it and get the engine warm?
LONO100 is offline   Reply With Quote
Old 12-23-2011, 09:50 PM   #3
SouthernSAR
Naples, FL
Vehicle Specs
(Original Poster)
The ticking seems to be coming from the suspension in the front drivers side. Sorry about the confusement with all the excess info about rpm drops and whatnot :/
__________________
Old 12-23-2011, 11:04 PM   #4
OffTrac
Dublin, GA
OffTrac's Avatar
'01 Sport Trac 4x4
Vehicle Specs
check your sway bar end links.
__________________
My Registry
OffTrac is online now   Reply With Quote
Old 12-24-2011, 06:30 AM   #5
600remguy
SW Ontario
'04 SportTrac XLT 4Paw
Vehicle Specs
Quote:
...very closely. Try turning top or bottom with a wrench. May appear ok, but be busted inside plastic spacer.
600remguy is offline   Reply With Quote
Old 12-24-2011, 07:11 PM   #6
SouthernSAR
Naples, FL
Vehicle Specs
(Original Poster)
Alright, thanks I'll try that tomorrow. Merry christmas [eve]!
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
1998 5.0 ticking noise under load idoticsoigpa Stock 1995 - 2001 Explorers 1 10-14-2011 10:43 PM
2000 V8 5.0 ticking noise? RAF Under the Hood 17 11-28-2009 04:31 PM
Ticking Noise... WCL Stock 1995 - 2001 Explorers 0 08-31-2009 06:37 PM
Ticking Noise Tozzi Under the Hood 13 06-17-2008 08:28 AM
engine ticking noise gooal22 Under the Hood 21 12-17-2003 08:52 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
