| 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Home | Register | Members Rides | Vendors | Top Posters | FAQ/Rules | Social Groups | Search | Today's Posts | Mark Forums Read |
| Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35 |
Thread Tools |
#1 |
Lifted & Loaded
Makkah
2008 XLT 4WD V6
According to Pat Barrett of Level 10 Performance Transmission Hamburg, New Jersey in Muscle Mustang & Fast Fords article. Cold-start valve failure is one of the most popular failing points of the 5R55W/S, there is a special circuit in the valvebody that restricts fluid flow to and from the trans cooler. This is done to bring the trans up to operating temperature quickly.
It was designed for extreme cold weather startups, like 20-30 below zero. In a perfect world this valve works perfectly, but we don’t live in a perfect world, adds Barrett. Level 10’s overhaul eliminates the valve to prevent any problems because 99 percent of these cars aren’t going to be fired up in that extreme weather. According to Barrett, he would rather have the fluid flowing all the time so you can pull into the burnout box with full fluid flow. ![]() Read more: http://www.musclemustangfastfords.co...#ixzz1fqxHvizN I emailed Pat Barrett asking him, how to do this modification? And this is what he sent me In order to modify cold-start valve to remain locked: http://www.ratiotek.com/5r55w-complete.pdf
__________________ - Allaa' - Basic Off-Road Techniques 2008 Explorer XLT 4WD V6 - Lifted & Loaded 2000 Crown Victoria P71: 4.6 PI Engine Swap, MZT, 70mm TB, P&P Plenum, Steeda UDP, J-Mod, B&M Trans Deep-Pan, External Trans Oil filter, BOC Tuning |
#2 |
Lifted & Loaded
Makkah
2008 XLT 4WD V6
So what do the experts of this forum think about this modification???
What if I combine it with AP dipstick-deep-pan and an extra auxiliary trans-cooler __________________ - Allaa' - Basic Off-Road Techniques 2008 Explorer XLT 4WD V6 - Lifted & Loaded 2000 Crown Victoria P71: 4.6 PI Engine Swap, MZT, 70mm TB, P&P Plenum, Steeda UDP, J-Mod, B&M Trans Deep-Pan, External Trans Oil filter, BOC Tuning |
#3 |
Virginia
2008 XLT Ironman
I am no expert but I think in your climate in particular this will be a very beneficial modification.
You might see if your existing transmission cooler is sufficient after performing it. Were you ever able to get your scanguage to read your transmission temperature? That will tell you for certain what your temps are now vs after the modification. __________________ Mods: 265/70/17 Mickey Thompson Baja STZ on 17x8 Black Rock Viper 900B wheels, Bentley style grille, Raptor style LED grille lights, Pacer performance clearance lights, 30" 180W LED light bar behind grille, BTF upper control arms, Fox 2.0 5" travel emulsion coilover shocks in front/rear Truxx spacers, 1" body lift, front skidplate under radiator, recovery shackle mounts My Rig:http://www.explorerforum.com/forums/...47#post3004247 |
#4 |
Lifted & Loaded
Makkah
2008 XLT 4WD V6
Now I'm doing a complete overhaul and waiting for the parts to delivered, and I'm applying this modification and hope to finish by next Monday
From the past, I know that the existing transmission cooler combined with AP dipstick-deep-pan ware insufficient to cool down the transmission during extreme off-road conditions and dunes-bashing abuse. due to the cold-start-valve was keeping a minimum high-heat level. I hope this time I'll get better results. __________________ - Allaa' - Basic Off-Road Techniques 2008 Explorer XLT 4WD V6 - Lifted & Loaded 2000 Crown Victoria P71: 4.6 PI Engine Swap, MZT, 70mm TB, P&P Plenum, Steeda UDP, J-Mod, B&M Trans Deep-Pan, External Trans Oil filter, BOC Tuning |
#5 | |
Virginia
2008 XLT Ironman
#6 |
Lifted & Loaded
Makkah
2008 XLT 4WD V6
I couldn't get the temperature readings from scanguage II
but the transmission kept over heating to the level that it spills ATF from the breathing vent. and I always had to add ATF after each time I go off-road. also I forget to mention that I'm installing a catch/recovery can to solve this problem __________________ - Allaa' - Basic Off-Road Techniques 2008 Explorer XLT 4WD V6 - Lifted & Loaded 2000 Crown Victoria P71: 4.6 PI Engine Swap, MZT, 70mm TB, P&P Plenum, Steeda UDP, J-Mod, B&M Trans Deep-Pan, External Trans Oil filter, BOC Tuning |
#7 | |
Virginia
2008 XLT Ironman
Quote:
TXD RXF RXD MTH Name 07E0221674 046205160674 3010 000100080000 TFT 07E1221674 046205160674 3010 000100080000 TFT 07E0221E1C 0462051E061C 3010 000900500020 TFT 07E1221E1C 0462051E061C 3010 000900500020 TFT One of those should work. I can double check and see which one I am using. __________________ Mods: 265/70/17 Mickey Thompson Baja STZ on 17x8 Black Rock Viper 900B wheels, Bentley style grille, Raptor style LED grille lights, Pacer performance clearance lights, 30" 180W LED light bar behind grille, BTF upper control arms, Fox 2.0 5" travel emulsion coilover shocks in front/rear Truxx spacers, 1" body lift, front skidplate under radiator, recovery shackle mounts My Rig:http://www.explorerforum.com/forums/...47#post3004247 |
#8 |
Lifted & Loaded
Makkah
2008 XLT 4WD V6
I'll try the codes once I finish the overhaul. Now the transmission is dissambled on the bench waiting for the Level 10 overhaul kit.
#9 | |
Virginia
2008 XLT Ironman
Quote:
For your reference: I typically see 160-175 degrees F most of the time regardless of ambient temperature though it rarely gets over 95 degrees where I live. I have never driven mine in the sand or dunes but I would expect the temperature to go up above that. I can tell you that during a several mile climb on a mountain road at 65mph with OD off I have seen temps up to 205 degrees for a short period. __________________ Mods: 265/70/17 Mickey Thompson Baja STZ on 17x8 Black Rock Viper 900B wheels, Bentley style grille, Raptor style LED grille lights, Pacer performance clearance lights, 30" 180W LED light bar behind grille, BTF upper control arms, Fox 2.0 5" travel emulsion coilover shocks in front/rear Truxx spacers, 1" body lift, front skidplate under radiator, recovery shackle mounts My Rig:http://www.explorerforum.com/forums/...47#post3004247 |
#10 |
Lifted & Loaded
Makkah
2008 XLT 4WD V6
This is because of the cold-start valve. It is based on old style mechanical solenoid, it is very slow to respond well to the rapid variation of tepmerature. And always cause the transmission to over heat.
#11 |
Virginia
2008 XLT Ironman
Yes I have thought this too.
I just put those numbers up so when you get your transmission completed you can compare it to see if your average temperature gets lowered. If it works well for you I may also do the cold-start valve mod. __________________ Mods: 265/70/17 Mickey Thompson Baja STZ on 17x8 Black Rock Viper 900B wheels, Bentley style grille, Raptor style LED grille lights, Pacer performance clearance lights, 30" 180W LED light bar behind grille, BTF upper control arms, Fox 2.0 5" travel emulsion coilover shocks in front/rear Truxx spacers, 1" body lift, front skidplate under radiator, recovery shackle mounts My Rig:http://www.explorerforum.com/forums/...47#post3004247 |
#12 |
Lifted & Loaded
Makkah
2008 XLT 4WD V6
I'm very happy with this mod.
the first XGauge code worked for me now I'm seeing 130 - 145 F degree most of the time __________________ - Allaa' - Basic Off-Road Techniques 2008 Explorer XLT 4WD V6 - Lifted & Loaded 2000 Crown Victoria P71: 4.6 PI Engine Swap, MZT, 70mm TB, P&P Plenum, Steeda UDP, J-Mod, B&M Trans Deep-Pan, External Trans Oil filter, BOC Tuning |
#13 |
Virginia
2008 XLT Ironman
excellent!! I will definitely need to do this.
Are you running just the stock transmission cooler or did you add an auxiliary? __________________ Mods: 265/70/17 Mickey Thompson Baja STZ on 17x8 Black Rock Viper 900B wheels, Bentley style grille, Raptor style LED grille lights, Pacer performance clearance lights, 30" 180W LED light bar behind grille, BTF upper control arms, Fox 2.0 5" travel emulsion coilover shocks in front/rear Truxx spacers, 1" body lift, front skidplate under radiator, recovery shackle mounts My Rig:http://www.explorerforum.com/forums/...47#post3004247 |
#14 |
Lifted & Loaded
Makkah
2008 XLT 4WD V6
Yes I'm running the stock trans-cooler + AP deep-pan with dipstick
for now I don't think I need an auxiliary cooler, I went for dune bashing and I abused the trans so much. The highest temp I got was 200 F which is still cool and ATF does not spilled out of the trans breather assembly any more __________________ - Allaa' - Basic Off-Road Techniques 2008 Explorer XLT 4WD V6 - Lifted & Loaded 2000 Crown Victoria P71: 4.6 PI Engine Swap, MZT, 70mm TB, P&P Plenum, Steeda UDP, J-Mod, B&M Trans Deep-Pan, External Trans Oil filter, BOC Tuning |
#15 |
Wannabe Elite Explorer
Orlando
2002 Limited 4x4
Thanks for providing your finding on this topic. I'm considering having my transmission rebuilt. My question....Does it make sense to make this modification to my 5R55S? I have the factory tow package on my 2002 which means it has a factory tranny cooler added. I live in Florida but potentially can see temperatures down to around 10 degrees F when I travel but that is VERY rare. I do tow a couple of horses in a horse trailer at times. Is there a downside to making this modification?
__________________ 2002 Ford Explorer 4x4 Limited P275/45R20 on 20" Rims Last edited by SyberTiger; 01-23-2012 at 03:49 PM. Reason: Correction, I have a 5R55S NOT a W. |
#16 |
Lifted & Loaded
Makkah
2008 XLT 4WD V6
the trans cooler line passes through the radiator, which means even in cold weather the ATF will reach the normal operation temperature.
this modification make sure that ATF will have a full flow through the trans-cooler all the time I'm not an expert but from my experience, I notice that the transmission does not over heat any more (before this mod, it was over heating even with the factory trans-cooler) for me I think this modification is a must. __________________ - Allaa' - Basic Off-Road Techniques 2008 Explorer XLT 4WD V6 - Lifted & Loaded 2000 Crown Victoria P71: 4.6 PI Engine Swap, MZT, 70mm TB, P&P Plenum, Steeda UDP, J-Mod, B&M Trans Deep-Pan, External Trans Oil filter, BOC Tuning |
| Suggest this thread to friends: |
| Tags |
| 5r55s, 5r55w, cold-start valve close |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| "How To" on a 2" body lift for '95 and up | Brian Ward | Explorer - Ranger Shocks, Suspensions, Lift Kits | 6 | 01-31-2012 10:38 PM |
| Gerald Jarrett - Simpsonville, SC | GJarrett | Explorer Registry | 74 | 12-25-2009 12:26 PM |
| Wal-Mart and Ethanol: It could be a beautiful thing. | Flounder | Exploring every thing under the sun!! | 17 | 08-12-2006 05:51 AM |
| Predictions on War!! | 96_explorer.com | Exploring every thing under the sun!! | 0 | 09-20-2001 01:20 PM |
| Thread Tools | |
