| 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Home | Register | Members Rides | Vendors | Top Posters | FAQ/Rules | Social Groups | Search | Today's Posts | Mark Forums Read |
| Explorer Babes (Ladies' Forum) A place to gripe about how much time our significant others spend on the message board. Okay, so it's a forum where we can spend as much time on the board as they do. If we don't do so already. |
Thread Tools |
#1 |
Indinapolis, IN
'03 EB
Sewing project advice is needed.
So I recently learned how to properly use a sewing machine. So, i'm thinking a decently easy project that i could make would be one of those soft cushy laptop case things, any advise or ideas on what i should use for material and softening material?
this sorta thing
__________________ Mods: 265/70/17 ; Tow Hooks; Telescoping Steering Wheel; Kenwood DDX616; Class III/IV Hitch |
#2 |
Admin
Pumpkin Pilot Wayoutin, Aridzona
'93 XL
I'm sending a link to this thread to Zukman, or actually Mrs Zukman (Sue). She does a lot of sewing.
__________________ Rick Horwitz, AB7FH "Serious Exploration's" Admin Rick's '93/'98 Explorer "The Great Pumpkin" Dodge Dart 512 Resto/Race 10.29 @ 129 2004 Mustang Mach 1 2003 Dodge Ram/Cummins Dually |
#3 |
Aerostar Forum Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Your thread was renamed & moved into the Explorer lady's section. It should get more attention in this section than in the electronics section. Soft foam material is fragile, so I would suggest a durable edging around the sides. It's not really necessary but it will extend the life of the bag. You could use a second color for the edging to add to the style of the bag. Is the zipper on the top or around the entire bag?
#4 |
Indinapolis, IN
'03 EB
Just on top, and are you saying to put a piping (like automotive seats) on the exterior? And thank you I didn't really know where to place the thread at.
#5 |
Brooklyn, NY
The edging would go around the outer perimeter. This is the plan:
1. Sew the material around three sides (exclude the top where the zipper attaches). 2. Turn it inside out then use a roll of edging material to connect on the top of those three sides. 3. Turn it inside out again, and sew the zipper. 4. Turn it inside out again which is the correct position since it's now finished. It's might be hard to get, but they make an edging attachment foot. It's not really necessary but it makes the job easier. |
#6 |
Indinapolis, IN
'03 EB
any ideas on what material would be soft yet not scratchy, and what for the inner padding
#7 |
Brooklyn, NY
Check a local fabric store. By the way, what kind of sewing machine do you use? Don't set the stitch length too close, and leave the pressure foot set at medium. A medium needle would be fine too. A very thin needle might break while a thick needle is only used for thick, dense material such as heavy wool which is used for a coat.
#8 |
Indinapolis, IN
'03 EB
well i was using a white i think, my dad has a large one at work that they just paid to have repaired and it still doesn't work but i'll most likely be using my mom's, not sure one bit what make or model it is
#9 |
Brooklyn, NY
Is it a residential or commercial machine?
#10 |
Indinapolis, IN
'03 EB
The two I will have worked with are residential but the still broken one is commercial
| Suggest this thread to friends: |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Advice Needed for Bronco IIs Project | MissEd | Bronco II | 6 | 03-29-2011 11:13 PM |
| 1993 ford explorer advice needed (interior) | dogs of war | Body Work & Detailing | 4 | 04-04-2010 06:13 PM |
| 96 Xlt 4x4 Urgent Advice Needed! | banspy | Under the Hood | 3 | 05-29-2006 07:25 PM |
| Advice Needed | 91xplorerman | New Member Forum | 11 | 11-03-2004 05:33 PM |
| Advice Needed: 99 Explorer Limited | Pirate | New Member Forum | 1 | 08-19-2004 12:34 PM |
| Thread Tools | |
