| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Home | Register | Members Rides | Vendors | Top Posters | FAQ/Rules | Social Groups | Search | Today's Posts | Mark Forums Read |
| Modified 2002 - 2005 Explorers Questions related to modified 2002 - 2005 Explorers and Mountaineers. For Sport Trac and Sport models use the 1995-2001 forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Atlanta
2003 Explorer
I just bought a used 2003 Explorer and I was wondering what was the best way to lift it. It has coil springs all the way around.
#2 | |
Virginia
2008 XLT Ironman
Quote:
Here is a ton of information that you can consider in making your choice. Take some time to research and you'll be able to make a better decision: http://www.explorerforum.com/forums/...d.php?t=290074 http://www.explorerforum.com/forums/...d.php?t=312012 http://www.explorerforum.com/forums/...d.php?t=219234 http://www.explorerforum.com/forums/...d.php?t=200639 http://www.explorerforum.com/forums/...d.php?t=279667 http://www.explorerforum.com/forums/...d.php?t=223741 __________________ Mods: 265/70/17 Mickey Thompson Baja STZ on 17x8 Black Rock Viper 900B wheels, Bentley style grille, Raptor style LED grille lights, Pacer performance clearance lights, 30" 180W LED light bar behind grille, BTF upper control arms, Fox 2.0 5" travel emulsion coilover shocks in front/rear Truxx spacers, 1" body lift, front skidplate under radiator, recovery shackle mounts My Rig:http://www.explorerforum.com/forums/...47#post3004247 |
#3 |
Atlanta
2003 Explorer
i mostly want it for just looks. i go offroad sometimes. and i want to be able to clear 32" tires.
#4 |
Virginia
2008 XLT Ironman
In that case you might consider a 1.5" or 3" body lift. They are the cheapest options and will let you clear 265/75/16 or 265/70/17 tires (about 32"). Won't affect your alignment or suspension either.
Look at these links for info (the 2nd and 3rd ones I last posted): http://www.explorerforum.com/forums/...d.php?t=312012 http://www.explorerforum.com/forums/...d.php?t=219234 Here are some pics of mine when it had a 1.5" body lift and 265/75/16 tires: ![]() ![]() and here are some pics of a guy with a 3" body lift and 265/75/16 tires: ![]()
#5 |
Atlanta
2003 Explorer
i want to have coil spaers all the way around.
3" in the front and 2" in the back |
#6 |
Virginia
2008 XLT Ironman
Too big. Read through some of those threads I gave you and the problems people had and you might change your mind on those sizes.
#7 |
Denver, CO
2004 XLT V6
Just use the search function and you will find all kinds of information.
A 2-inch lift is all you can safely do, any more than that will put excessive wear on the upper ball joint and cause it to rip out of the control arm. A 2-inch lift and a body lift will let you clear even bigger tires. Also, you can clear 32's bone stock without any rubbing. |
#8 |
Russia, Abakan, Republic of Khakassia
2004, FE 3, V8
who can help me...? I install custom lift spacers (2.25/1.75). With front spacers, i have no questions...but with rear i have a little problem...
The spacers ![]() after painting... ![]() ...The rear has established, a figured part to a coil spring, and a flat part to a body... I think it was necessary to make on the contrary...Is it rights? ![]() ... After install i have a metal knock at movement on roughnesses or diagonal posting, at movement on a highway, knocks isn't present...i think need rotate rear spacers... ...before ![]() ...after...
#9 |
Ashland Va
2005 Xlt 4x4
^^^ are those truxx? They don't look like btf
I've read with the rear truxx people had to modify it... Looks like one rear has more bolt holes... I think I remember truxx needed to be spun 180degrees and drill new holes like that back rear spacer in pic May also need to trim the studs on strut assemblies... __________________ Factory DVD, third row, rear A/C, Moon roof, Advancetrac RSC, Tow package, Leather everything, Eddie Bauer running boards.MODS- deep transmission pan w/dipstick, 1.5" Body lift, Expedition front tow hooks, Treadwright Guard Dog M/T 265-75/16 C Ply, Telescoping steering wheel mod, 4.56 gears limited slip front and rear,brembo brakes,front skid plate, Cb.FUTURE MODS-rock sliders, oba, steel front bumper w/ warn VR12000, possibly a M90 |
#10 | |
Virginia
2008 XLT Ironman
Quote:
IceMaNoFF, The rear spacers need to be installed in such a way that the mounting surface on the top of the strut, the spacer, and the strut mount on the frame are all in a straight line. It looks like you have installed it at an angle, this is not correct (unless the Russian Explorer is different.) Like this (disregard brake caliper hanging):
#11 | |||
2004, FE 3, V8
Quote:
Quote:
![]() ... Quote:
well, need do more holes and turn back as was on not lifted suspension?
#12 | |
Virginia
2008 XLT Ironman
I see now...that makes more sense.
You might try drilling the extra holes as you showed in the picture, then see if that fixes the problem. Otherwise, your truck looks good Quote:
#13 |
2004, FE 3, V8
tnx!=)
front wheel ![]() ...rear ![]() ...frame ![]() ...front axle
#14 |
2004, FE 3, V8
i did it! All ok...=)
#15 |
Ashland Va
2005 Xlt 4x4
Love those taillights __________________ Factory DVD, third row, rear A/C, Moon roof, Advancetrac RSC, Tow package, Leather everything, Eddie Bauer running boards.MODS- deep transmission pan w/dipstick, 1.5" Body lift, Expedition front tow hooks, Treadwright Guard Dog M/T 265-75/16 C Ply, Telescoping steering wheel mod, 4.56 gears limited slip front and rear,brembo brakes,front skid plate, Cb.FUTURE MODS-rock sliders, oba, steel front bumper w/ warn VR12000, possibly a M90 |
| Suggest this thread to friends: |
| Tags |
| explorer, ford, lift |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| I want to lift my 2003 Explorer Sport. | jgcoffey33 | Explorer - Ranger Shocks, Suspensions, Lift Kits | 13 | 08-28-2010 01:58 PM |
| Can I buy a 6" Suspension lift for an Explorer? | dany77 | Explorer - Ranger Shocks, Suspensions, Lift Kits | 1 | 08-12-2009 02:53 PM |
| 2000 Explorer XLS Brake Lights Weren't Working | l1k2gadd | Stock 1995 - 2001 Explorers | 0 | 05-31-2008 11:04 PM |
| Thread Tools | |
