EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
93 Ranger Transmission
Reply
Thread Tools
Old 11-19-2011, 01:17 PM   #1
MarkOPKS
Overland Park, KS
2002 XLT 4.0
Vehicle Specs
(Original Poster)
My buddy has a 93 ranger 3.0 4x4 5 speed manual, and his tranny has a pretty decent leak at the top near the shifter. He has filled it up regularly, so it's definitely not low on fluid. When the truck is in neutral and the shifter is to the left (near 1st/2nd), there is a pretty bad grinding noise. Its weird bc the the shifter is still in neutral. Also when shifting into 1st and 2nd it grinds for a second, but drives fine.
Any ideas? Thanks for the help
MarkOPKS is offline   Reply With Quote
Old 03-19-2012, 08:52 PM   #2
D.L.M.Sr.
Omaha,NE.
'93Ford Ranger
Vehicle Specs
US tras. noise from D.L.M.Sr.
The noise that you are most likely hearing is the bearings going out.The slight grinding that you are getting is because the syncros are going bad. trans. needs rebuilt/replaced. I had the same problem,did not fix,now looking for replacement. I have told trany has to come out of '91-'94 ranger 3.0 only,or mozda B3000 '94 only. Personaly if I had the money I would try to make another trany fit,after all the 2.9v6 is only 1 10th of one liter smaller, and do not know why Ford would not make the trany fit more the one engine size,espiecally when there are so close to each other.About the leak you my be over filling,or the gasket for some reason or other has gone bad. Check fill level pull fillplug on side of trany,fluid should beable to touch fluid by putting little finger in and bending it.If you can do that it is full,if fluid wants to come out when you open plug it is over filled and will find the easyest way out.
Last edited by D.L.M.Sr.; 03-19-2012 at 09:06 PM. Reason: for got to advise on leak.
D.L.M.Sr. is offline   Reply With Quote
Old 03-20-2012, 12:08 AM   #3
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
This link shows how to fix what is probably your leak: http://www.therangerstation.com/tech...aintenance.htm
__________________
Bill Collins
93 Ranger XLT 4X4
"Beauty is only sheet metal deep."
RangerX is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Transmission leak at radiator sabasigh Explorer & Ranger Transmissions, Transfer Cases, & Differentials 11 02-12-2013 10:51 AM
History of the Ford Ranger Tbars4 Ford Ranger - Mazda B-Series Forum 9 04-20-2010 09:50 PM
Transmission issues in old Ranger Thelt Ford Ranger - Mazda B-Series Forum 6 10-21-2008 12:47 PM
'93 X motor and transmission replacment Xplorer92 Under the Hood 1 05-14-2005 07:39 AM
98 Explorer Rims on a 93 Ranger? gijoecam Ford Explorer - Ranger Tires & Wheels 3 07-10-2001 09:51 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
