| 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Home | Register | Members Rides | Vendors | Top Posters | FAQ/Rules | Social Groups | Search | Today's Posts | Mark Forums Read |
| Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well. |
Thread Tools |
#1 |
Wannabe Elite Explorer
amber check engine light
Hi All,
I'm new to this forum. My son has a 2005 ford ranger 2 wheel drive. He recently had a oil change. Since then his check engine light has appeared. The shop I brought it to said that it was running lean. It was either the O2 sensor or the catalytic converter. They cleared the code and said to continue to drive the ranger. The light has reappeared again. Not sure what to do now. Thanks for any info. And thanks for having me on the forum. Franco Hope BC Canada
#2 |
Auburndale, Wisconsin
1994 Mazda B4000 4WD
This probably isn't any help.....but my check engine light is on 99.9% of the time.....at least I think it is....put a piece of black tape over it about 2 weeks after I got the truck.
Seriously tho, it could be anything.....it's just a sensor sending a message back to the computer. If the truck runs and drives fine, I would say to ignore it, especially if you have taken it to the shop and they have said to continue on. AutoZone used to do a free code check. (Don't know if they still do). You could go there and double check that the information that you got from the shop is acurate. Otherwise replace the O2 sensors and see if the light stays out after it's been reset. Not sure if there is any way to test them. Just some ideas. Happy hunting! (GO BLACK TAPE!) |
#3 |
Offroad Moderator
anaheim hills,california
95 ranger 4x4/ 91 X 4x4
..Get your codes read and bring the code numbers back here so other members can assist you on your fix..
..You will need an ODBII reader to pull the codes while member n.a.mccanna on the other hand only needs a paperclip to check his codes..
__________________ I have Rocks in my head. What's in yours? ![]() '95 ranger xl 4x4 2.3L std cab, 2 sticks Ranger RegistryThe Squirrel '91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's ListHow to: Wheels,Tires, & Lifts... Buy Explorerforum.com Items here |
#4 |
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Ditto on getting the DTC number(s) to isolate the issue.
Waste of time and money by guessing and changing parts. |
#5 |
I have a code 86......REPLACE TRUCK!!!!!!!!!!
#6 |
Michigan
2003 Ranger 4.0L FX4
I had a P0174 code come up a few times over the course of a few months on my 99 Explorer (had the 4.0L V6 that the Ranger can also come with, if that's what your son has) which was a "System too lean, bank 2" code. The Explorer had only 74,000 miles on it at that point so I was hearing it was unlikely the O2 sensor had already failed. I probably had 4 or 5 different opinions from people at the oil change place, Auto Zone, and online forums. I ended up having a mechanic look at it, and he could very audibly hear air sneaking through where the worn out upper intake manifold gasket should have been. I had that replaced, and the code went away. Then it sprang back up 5 months later, and was coming back daily after I reset it. I did a visual inspection and discovered that the damn PCV valve was hanging loose outside of the hose coming from the manifold. I replaced the valve while it was partly freed, and the code hasn't come back since.
#7 |
cleveland, oh
Autozone does still check for free if the check engine light comes on and so do other auto parts stores, like O'Reilly's. I had a 97' Ranger that needed an oxygen sensor with low miles, like 60,000ish. It happens since parts do wear out. I, too, wouldn't randomly replace parts since it can get expensive and frustrating. Also, my Ranger had two oxygen sensors -- Bank 1 and Bank 2 or lower and upper. I, think, they can be cleaned very carefully, but I don't think they can simply be tested.
| Suggest this thread to friends: |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Check Engine light | BigPerm | New Member Forum | 0 | 12-05-2011 11:32 AM |
| check engine light keeps keeps coming on | nuts | New Member Forum | 1 | 11-16-2011 01:23 PM |
| Rough idle, check engine light on, black soot | 93redxlt | New Member Forum | 2 | 04-23-2005 07:30 PM |
| please help w/ check engine light | erik671 | Under the Hood | 4 | 05-16-2001 10:19 PM |
| Thread Tools | |
