Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
2-1 downshift flare on 5R55E, TCC/EPC?
Reply
Thread Tools
Old 04-06-2012, 10:51 AM   #1
mp223
1999 EB SOHC
Vehicle Specs
(Original Poster)
Hi all, 1999 5r55e with 150K on the clock, fluid replaced at ~75k and again with a filter at ~140k. Otherwise all original.
When slowing down to stop I'll get a bump in RPMs when the transmission shifts from 2-1, eg: foot off accelerator and on brake, 1000 RPM -> 1500 RPM -> downshift 2-1 -> RPM drop to ~600 while stopped and idling.
I tried searching but only came across 2-3 flare issues. Could this be a symptom of my TCC or EPC solenoids going? Also, how likely is the IAC causing this problem?
mp223 is offline   Reply With Quote
Old 04-06-2012, 11:11 AM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Did you ever replace the servos?
BrooklynBay is online now   Reply With Quote
Old 04-06-2012, 11:18 AM   #3
mp223
1999 EB SOHC
Vehicle Specs
(Original Poster)
No. Everything is original.
Old 04-06-2012, 11:25 AM   #4
drdoom
VA
1997 XLT 4.0 SOHC 4WD
Vehicle Specs
You may want to clean the throttle body, and check the associated linkage i.e. accelerator cable. Do a TPS test also.
drdoom is online now   Reply With Quote
Old 04-06-2012, 11:31 AM   #5
BrooklynBay
Brooklyn, NY
Vehicle Specs
Dried out servo pistons could cause a shift flare. Clean the bores & check for wear. Adjust the bands.
Old 04-06-2012, 12:13 PM   #6
mp223
1999 EB SOHC
Vehicle Specs
(Original Poster)
drdoom: Throttle body was cleaned thoroughly a couple of months ago. Throttle cable is tight, TPS read 0.97v at idle and 4.something at WOT. I'm gonna pickup a couple of junkyard IACs and see what that does, my idle has always been low at ~500rpm and I wondered if the IAC malfunctioning could cause a jump in RPM in specific circumstances.
BrooklynBay: I'm getting conflicting information, do I have to drop the pan to check the servo pistons? Is there a particular servo I should be checking, perhaps a picture? I will try the band adjustment first.
Old 04-06-2012, 12:28 PM   #7
BrooklynBay
Brooklyn, NY
Vehicle Specs
There are two servos on the side of the transmission which usually dry out. The one in the pan is much cooler so I wouldn't worry about the seals on it. The bands should be adjusted after the servos are replaced. Keep in mind that both servos are a different diameter, and the internal springs on each one have a different amount of tension. Do one at a time to avoid confusion.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to: Ball joints on 3 gen 1 of 2 [Pictures] Hitchhikingmike Stock 2002 - 2005 Explorers 26 02-18-2011 01:23 AM
1 vs. 2 chamber exhaust Afboy143 Modified 1995-2001 Explorers 1 08-30-2006 05:15 PM
5R55E shift flare resolved bluestream1 Explorer & Ranger Transmissions, Transfer Cases, & Differentials 3 08-22-2006 07:29 AM
2 to 1 downshift clunk in drivetrain mikefox Under the Hood 2 03-27-2000 03:51 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
