| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Home | Register | Members Rides | Vendors | Top Posters | FAQ/Rules | Social Groups | Search | Today's Posts | Mark Forums Read |
| Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories. |
Thread Tools |
#21 |
Elite tree-smasher
Bloomington, Indiana
04 Ranger Edge
Thanks, I will definitely give it a clean and see what happens. I should not I tested the coil pack and the resistance checked out fine. I'm still kind of suspicious about the wires as well, I will take a look at them once it gets dark and see if there is any arching going on.
__________________ Jesse '94 Eddie Bauer DD/Beater "Old Faithful" RIP '04 Ranger Edge DD "Black Knight" You want to see my face? |
#22 |
Elite tree-smasher
04 Ranger Edge
Well I may have found the issue. I finally remembered to go out and have a look with it nice and dark outside, and sure enough, I got arcing going on with that number 4 wire. It looks like a bad connection down towards the plug, that's where most of the action was. It also shot some random arcs on the other side where that wire goes around the back of the motor. I also some a little arcing on the number 1 and 2 plugs.
Also, I revved it up while I was watching, and the arcing actually went away mostly, which explains a lot. Remember this wire tested out at less than 10k ohms resistance, which should be pretty good. Definitely didn't tell the whole story though. Whenever I get paid I will grab a set of Autolite wires and throw them on to see what happens. Edit: Went and looked some more, is it normal at all to have arcing right at the end of the boot where the wire goes over the plug? I ask because cylinders 4,5, and 6 all had a bunch of arcing at the actual spark plug like that. The more I watched it the worse it got on #4, too. It was shooting all the way up the wire almost. Cylinder 2 had a pretty nasty one too. __________________ Jesse '94 Eddie Bauer DD/Beater "Old Faithful" RIP '04 Ranger Edge DD "Black Knight" You want to see my face? Last edited by Willard; 04-08-2012 at 09:24 PM. |
#23 | |
Wannabe Elite Explorer
Southeast USA
2000 Sport
Quote:
I'm sure you've found the problem and it should run like a champ with new plug wires. __________________ 2000 Sport 4x2, 4.0 ohv, 5R55E w/Superior shift kit, 3.55 diff, Mazda truck alloys/BFG TAs, RoadMaster Active Suspension, EE anti-sway bar, F&R poly bushings, camber kit, Rancho shocks, Hooker Aero Chamber muffler, Medium Wedgewood Blue..... Bought another 2000 Sport (God help me ), 4.0 ohv auto, 60K actual miles, Cragar SS alloys/BFG TAs, AAL, EE anti-sway bar, Gibson cat-back, Harvest Gold, GT leather interior.
#24 |
Elite tree-smasher
04 Ranger Edge
I'm pretty confident I found the issue as well. I can't wait to get money to put some new plug wires on this thing, hopefully it helps the gas mileage on it. I've been averaging 16.5 with quite a bit of highway, and I would like to see better with this truck
#25 |
Elite tree-smasher
04 Ranger Edge
Well, got the new wires today and installed them and did a seafoam treatment while I was at it.
It definitely runs better, and after a good long drive I got back and let it idle for a few minutes, and no misfire ![]() It still isn't a perfectly smooth idle, but I think it's probably as good as a 3.0L will get. The torque seems to be better, I noticed it downshifted less on the hills, and it seemed to climb better overall. So I'm gonna hope I've got this kicked, and now its time to save up for some power adders for this little motor
#26 |
Southeast USA
2000 Sport
Good job!
Cool Ranger. __________________ 2000 Sport 4x2, 4.0 ohv, 5R55E w/Superior shift kit, 3.55 diff, Mazda truck alloys/BFG TAs, RoadMaster Active Suspension, EE anti-sway bar, F&R poly bushings, camber kit, Rancho shocks, Hooker Aero Chamber muffler, Medium Wedgewood Blue..... Bought another 2000 Sport (God help me ), 4.0 ohv auto, 60K actual miles, Cragar SS alloys/BFG TAs, AAL, EE anti-sway bar, Gibson cat-back, Harvest Gold, GT leather interior.
| Suggest this thread to friends: |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 2001 Explorer Sport 4.0 SOHC Cylinder Misfire Codes | ironhed85 | Stock 1995 - 2001 Explorers | 44 | 03-24-2012 05:41 PM |
| Constantly have to replace ignition lock cylinder. 95 ford ranger 4 cyl 2wd | DUPEY87 | Ford Ranger - Mazda B-Series Forum | 3 | 06-23-2011 09:54 PM |
| Recurrent plug 4 misfire fixed! | greasemanicure | Under the Hood | 6 | 10-18-2010 09:24 PM |
| I can't find the starter relay on an 02 Ranger with a 4 cylinder. | dagodrummer | Ford Ranger - Mazda B-Series Forum | 1 | 07-20-2009 11:42 PM |
| 2004 ranger tranny help | takidd4597 | Explorer & Ranger Transmissions, Transfer Cases, & Differentials | 0 | 12-15-2008 12:46 PM |
| Thread Tools | |
