| 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Home | Register | Members Rides | Vendors | Top Posters | FAQ/Rules | Social Groups | Search | Today's Posts | Mark Forums Read |
| Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap. |
Thread Tools |
#1 |
Lubbock, TX
01 Green XLT
How to: END ALL 98-01 REAR WIPER PROBLEMS!
How to: END ALL 98-01 WIPER PROBLEMS
This will show you how to install a 2002-03 Sport rear window glass with the integrated wiper into a 98-01 4 door. Recommend two people. This was performed on a 1998 4 door using a 2003 Sport glass from the JY. Get the glass, wiper assembly, as much interior wiring as possible, the gas shocks (or buy new ones), and if the interior panel matches yours, grab that too (if you can’t, that’s okay. You can reuse the old) Total Cost: $125 Step 1-Remove old rear glass: Need torx bits and a screw driver. 1.) Disconnect the defrost 2.) Disconnect the lift shocks 3.)Unscrew the window from the hinges Step 2- Wiring: For this, you will need four wires (I grabbed three that were 4 feet, and one that was 6 feet) 1.)Remove the rear lift gate panel. 2.)Find motor wiring and splice away ![]() +For this install, you will need a constant 12v. The existing wiring does not have a 12v source, so I wired into the 25 amp source coming from the wiring of the old stock amp.Try to tap a fused line. Here’s how to wire I wired it in: 1.) Drop the roof liner down just enough so you can see the wire connection that goes into the lift gate. 2.) Splice the constant 12v into the Brown/White wire. Now you have a constant 12v. *On 98-01 Explorers, it takes two electrical pulses for the wiper to make one complete cycle. They both go thru the White/Orange wire. The Sport, though, only needs one electrical pulse to make one complete cycle. Therefore, the Sport wiper on the 2nd Gen will always make two complete cycles before pausing according to the speed setting. (trying to find a fix for it) For the connection, I ran the wires along the right side of the lift gate panel, splice to the Sport’s native female plug, and had the Sport’s male plug to it where the defrost plug comes out. Step 3: Place glass in position: It will mount just like the old one and the defrost plugs are the same. Put the new panel on and you’ll be ready to go. Or you can cut your own to fit the motor’s panel. See pics And... So far it works ALOT better then the old one! Now waiting on some rain to do a driving test. -Will __________________ 2001 Ford Explorer XLT V8 AWD- Not Named Yet! 1998 Ford Explorer XLT V6 4X2- 'Wendy' -Sold 1999 Ford Explorer XLT V6 SOHC 4x4- 'Partless' 2002 Ford Explorer XLS- Bro's car |
#2 |
It's green, not gray.
San Francisco, CA
'00 Mountaineer
I like that! Definitely gonna look into doing this. I've tried bending my wiper all different ways and just can't get it to work, so looks like this is the best option. Thanks!
#3 |
Wannabe Elite Explorer
Scranton, Pa
01' Mercury Mountaineer
do you have pictures of the wire routing locations
__________________ 01' Mercury Mountaineer 71' Chevy Chevelle Malibu 71' Chevy Chevelle SS |
#4 |
Supercharged OHV
Winnipeg, Manitoba
00 Explorer XLT 4.0 OHV
I love this! Some metal work and bondo to the old mounts and you could have a perfectly clean back end. :-)
I wonder..... would a newer X with the right colour tailgate bolt right on? __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#5 |
Knoxville, TN
98 Mountaineer A4WD
Thanks Will, that is a good solution.
Why did you tap into another constant power wire, if the 98 wiring already has one(black/blue wire)? I have the 2003 Sport hatch glass and wiring already. I was waiting to find a solution to the difference in wiring, four wires to three to the motor. I didn't know the hatch trim was different also, I'll have to see what those later panels look like. The later Sport hatch should bolt on, but the bottom trim will likely be different(swap your trim etc). __________________ Don 91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior. The best thing that could help us all, is the Fair Tax Plan. Be American, Buy American (Manufacturer)
#6 | ||||
Lubbock, TX
01 Green XLT
#7 |
Elite Mountaineer
South Jersey
99 Mountaineer V6 4x4
The violet/yellow wire that you didn't use is for the GEM wiper park sense. It doesn't do it when you turn off the truck because when you remove power it parks by default.
__________________ Al ![]() 99 Mountaineer 4.0 SOHC. TT/Warrior Shackles, 2" BL, 32x11.5/15 BFG A/T's, Rancho 5000's, Supplemental HHO Generator(out for cell redesign), Electric Fan Conversion, AVM Manual Lockout Hubs, Dual Battery System, Gibson cat back exhaust. EATC Mod. BW1354 swap, finally done! My 4405 To 1354 Swap Thread Support your own economy, Buy American, all of our jobs depend on it.
#8 |
Lubbock, TX
01 Green XLT
Okay... I thought that it might not actually have a park function because when you apply 12v to the trigger wire, it does one revolution and returns to its resting position. but it could be an integrated park/trigger on the Sport. I will see what happens when I put the V/Y wire in. And while I'm at it, I'll get some pics of the wiring.
-Will __________________ 2001 Ford Explorer XLT V8 AWD- Not Named Yet! 1998 Ford Explorer XLT V6 4X2- 'Wendy' -Sold 1999 Ford Explorer XLT V6 SOHC 4x4- 'Partless' 2002 Ford Explorer XLS- Bro's car Last edited by Willcall; 11-08-2011 at 09:20 AM. |
#9 |
Elite Mountaineer
South Jersey
Any progress on this? If you get the bugs worked out let us know.
#10 |
Supercharged OHV
Winnipeg, Manitoba
hopefully this summer ill get my meter on the different wires and see what the different wires are doing on my 2nd gen over a beer or two.
maybe someone with a gen 3 can do the same. This would be a great mod to sort out. __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#11 |
Lubbock, TX
01 Green XLT
Sorry guys, This has been put in the back burner till I can sort Wendy's other more drive-threatening problems. I will try to figure it out as soon as I figure out everything else
#12 |
98 Sport
I don't suppose if you were doing this mod to a sport model it would be plug and play? I'm sure no such luck.
#13 |
Knoxville, TN
98 Mountaineer A4WD
91-94 models are all alike, and so are 95-97's. 98-01 4dr and Sport are the same, as well as the 2002 Sport rear wiper system.
#14 |
Supercharged OHV
Winnipeg, Manitoba
I have a feeling that making the rear wiper work properly on a different generation isn't going to be straight forward. There might be some more extensive rewiring required.
Anyone have a detailed schematic of the 2nd and 3rd gen wiper systems? __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#15 |
Lubbock, TX
01 Green XLT
Today I ordered the Ford Service and Wiring disc for the 03 Sport and I already have the 98-01 disc. Hopefully I will get the wiring sorted out soon.
-Will
#16 |
Knoxville, TN
98 Mountaineer A4WD
That's encouraging. I have many of the DVD's also, but up to 2002 IIRC.
#17 | |
Raleigh, NC
99 Ford Explorer XLT RWD
Quote:
The circuit with the 4-wire motor has a generic electronic module (GEM). I'm assuming it somehow controls the flow of current and the switching of relays in the circuit based on how you set the on/off/high/low selector switch. The battery junction box (power distribution box) under the hood has five sections. A diagram is embossed on the inside of the box's cover. The maxi-fuse section has slots 1-10. The mini-fuse section has slots 1-15. The relay section has slots 1-10. The diode section has slots 1 and 2. I can't remeber what the last section is but it only has one slot. This circuit's 15 amp fuse is in mini-fuse slot #8 and it's wiper-up relay and wiper-down relay are in relay slots #10 and #8, respectively. I think the GEM first allows current to flow only through the wiper-up relay, through the white/orange wire, into the wiper motor, out through the black/light blue wire, into the inactive wiper-down relay, and then to ground. Wiper goes up. The GEM then changes the flow of current to go only through the wiper-down relay, through the black/light blue wire, into the wiper motor in the opposite direction, out through the white/orange wire, into the now inactive wiper-up relay, and then to ground. The wiper motor is reversed. Wiper goes down. When the selector switch is turned off, the GEM controls current through the violet/yellow wire, into the wiper motor, and out through the black wire to ground. The wiper parks itself in the lowest position. One of the circuit diagrams with the 3-wire motor has the same color wires as your wiper motor. It uses only one relay. The GEM and the on/off selector switch are different than the 4-wire motor circuit diagram. There are two wires (or one wire spliced into two) in the battery junction box, one going from the 15 amp mini-fuse to the relay, and the other is the brown/white wire going from the same mini-fuse to the wiper motor. The violet/yellow wire goes from the relay to the wiper motor. The black wire from the wiper motor goes to ground. Last edited by jcevans2; 04-09-2012 at 02:26 AM. Reason: A better understanding of how it works |
#18 |
Raleigh, NC
You can download and print circuit diagrams from the Auto Repair Reference Center website. It saved me from taking the vehicle in for air conditioner repair. I thought it was a bad compressor clutch but it was just a broken relay in the fuse box.
#19 | |
Raleigh, NC
Quote:
I think I understand how the 3-wire motor works now. The 3-wire motor circuit uses only one relay. The relay allows a current "pulse" through the violet/yellow wire into the motor and out through the black wire to ground. This causes an internal switch to move from the "park" position to the "run" position. This allows a continuous current on the brown/white wire to flow into the motor and through the black wire to ground (actually it's "pulsed" internally because of the internal switch). The wiper goes up. When the relay stops the current pulse through the violet/yellow wire, the motor's internal switch moves back to the "park" position, the current from the brown/white wire stops, and the wiper goes down to the same position as being parked, because on this window design, it has no need to lower itself off the glass. If go back to your original wiring configuration, check your fuses to make sure they are all the right amps and in the right place, and your relays are functional, I think this might work. I am assuming your 98 Explorer has the same circuit components in the same positions as my 99. You should verify everything yourself. 1. Disconnect the negative battery terminal and remove the rear wiper down relay from the battery junction box under the hood (relay slot #8). The rear wiper up relay (relay slot #10) will act as the single relay from the 2002-2003 rear wiper circuit. 2. Connect the violet/yellow wire of the 3-wire motor to the white/orange wire that previously went to the 4-wire motor. The violet/yellow wire that previously went to the 4-wire motor will not be used. 3. Connect the black wire of the 3-wire motor to the black wire that previously went to the 4-wire motor. 4. Connect the brown/white wire of the 3-wire motor to the black/light blue wire that previously went to the 4-wire motor. With the wiper-down relay removed, this wire will no longer get "pulsed" current. We will set it up to get continuous current. 5. The empty rear wiper down relay slot has five terminals - two horizontal and three vertical. The two horizontal terminals are #3 (the other end of the black/light blue wire) and #5 (a series of white/violet wires that connect to the 15 amp fuse in mini-fuse slot #8). Connect a jumper wire or cotter pin between terminals #3 and #5. 6. Reconnect the negative battery terminal, turn the key, and turn on the rear wiper. If it works, you should make arrangements at some point to replace the jumper wire or pin with a more solid connection between the black/light blue wire and the white/violet wire inside the battery junction box. If it does not work, then I have thoroughly wasted your time and mine. On paper, it looks like it would work. Last edited by jcevans2; 04-09-2012 at 05:41 AM. |
#20 |
Supercharged OHV
Winnipeg, Manitoba
Wow, thanks for spending the time to look at the diagrams JC!
This is something I will be trying this summer. Hopefully someone will beat me to it, and let us know if it works. __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
| Suggest this thread to friends: |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rear wiper problem. | stacypeters26 | Stock 1995 - 2001 Explorers | 23 | 10-15-2012 10:59 PM |
| 1995 Ford Explorer XLT rear end replacement? | tikisurfgod | Under the Hood | 5 | 09-12-2008 09:33 PM |
| 98 EB wiper problems | someeh | Stock 1995 - 2001 Explorers | 2 | 05-27-2008 08:03 AM |
| '01 Sport rear differential rebuild worklog & questions | the_tool_man | Under the Hood | 5 | 10-29-2004 01:04 PM |
| rear leaf spring problems '98 | golby | Explorer - Ranger Shocks, Suspensions, Lift Kits | 1 | 11-23-1999 12:32 AM |
| Thread Tools | |
