| 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Home | Register | Members Rides | Vendors | Top Posters | FAQ/Rules | Social Groups | Search | Today's Posts | Mark Forums Read |
| Modified 1991-1994 Explorers Questions concerning modifications to the 1991-1994 Explorer, Mountaineer, Ranger and Navajo. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Helena Mt.
91 Sport
Just replaced my front AND rear wheel bearings about a week ago. Due for an alignment soon.
MY PROBLEM: I am experiencing a low frequency hum at speeds between 25-45 mph. Sometimes it's constant and sometimes it "warbles". I had a buddy drive down the road past me and didnt hear anything abnormal from outside the vehicle as he passe by, and the wheels dont seem to wiggle while in motion. The sound seems to be just inside the vehicle, under my feet. Could this be due to the alignment being off? Or could this be a balancing issue? Or is this just the nature of huge tires? It's pretty loud, i can hear and feel it over my modified 4.0-6cylinder engine when im reved up to 4.. 91 explorer sport 5.5" lift 33" rubber Locked front and back Geared 4.56 |
#2 |
GREEN SCREAM!!
Hattiesburg, MS
'93 Sport 4x4
Hard to say. Could be a lot of things, from regular tire/road noise to just pooly balanced wheels/tires, or even an irregular wear pattern on the tread that hums differently depending on the pavement surface.
If you raise up the wheels/tires and check the wheel bearings/ball joints and everything is tight with no wobble, and the rest of the drivetrain (driveshaft, u-joints, differentials, including fluid, etc.) is good, you should probably have the wheel/tire combo balance checked. Often an unbalanced tire, especially a larger, heavier one, will give that hum that warbles. There's a chance it could be fixed with an alignment as well, but that would be a pretty serious correction. If it aligns fine, and no issues are found otherwise, you could just have noisy tires. Keep in mind some tires just wear funny, or cup and make noise, too, so it might be something you have to get used to until the next set of tires. __________________ "I think man has always gone where he has been able to go, and I think that when man stops going where he can go, he will have lost a lot. Man has always been an explorer. To me, there's a fascination in thrusting out and going to new places. It's like going through a door because you find the door in front of you." - Michael Collins |
#3 |
Denver Colorado
'93 Explorer XLT
Out of curiosity, what 33" tires do you have? and how old/what pressure are they at?
#4 |
Helena Mt.
91 Sport
I bought the vehicle a month ago and it came with
33x13.5r15 superswampers (rear) 33x12.5r15 pro comp-xtreme (front) Both with about 80% tread left on them. I plan on changing the tires in the next few months to all Runway Enduro M/T's. |
#5 |
Helena Mt.
91 Sport
P.S.
They're both rated at 35psi max and I have them at 30psi. |
#6 |
GREEN SCREAM!!
Hattiesburg, MS
'93 Sport 4x4
Mud tires in general and super swampers in particular are well known for their loud hum on the pavement, just how they are. They also don't always balance all that well.
You could be getting additional noise due to the different tread patterns front and rear, which might be combining to make a certain annoying frequency or two that gives whatever noise you're hearing. It'd definitely be a good idea to get all 4 treads of the same type and size if you plan on using 4WD, having tires with different diameters when all 4 wheels are being driven is a no-no. __________________ "I think man has always gone where he has been able to go, and I think that when man stops going where he can go, he will have lost a lot. Man has always been an explorer. To me, there's a fascination in thrusting out and going to new places. It's like going through a door because you find the door in front of you." - Michael Collins |
#7 |
Helena Mt.
91 Sport
Yeah, I agree with your statement on the tread matching. It's DEFINITELY a good idea, and the reason why I want to change them out ASAP.
The previous owner (ironically) was a member of this forum, as I found out after I bought it at a local used dealership. Googling the specs of my rig and happening upon a pic of her, it took me here and I got to read all his posts over the years. Kind of fascinating really. WAExplorer was his name. Anywho.. I dont know what he was thinking with 2 different tread types on the wheels seeing as how he seems to have done all the custom work himself and should have known better... Time to save up some paychecks! |
#8 |
Denver Colorado
'93 Explorer XLT
I know the feeling. Since you're aiming at new shoes, I would wait on the alignment till you get em.
I agree with Anime that the two different tread patterns are probably causing some freaky harmonic resonance thing. My wife's Heep has M/T's and even though they are all the same and at proper pressure, god forbid you go more thaqn 5k miles between rebalancing them. The oscillating drone that they start giving off can be maddening... and they're only 31".
| Suggest this thread to friends: |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| How to Remove stock steering wheel and install aftermarket wheel on 95-01 Explorers | GIJOE | Modified 1995-2001 Explorers | 26 | 12-25-2011 10:12 AM |
| Stuck in 4 wheel low, 97 Explorer | lg06479 | Stock 1995 - 2001 Explorers | 4 | 12-15-2011 04:17 AM |
| Help me out | COMMOCOZY | Ford Explorer - Ranger Tires & Wheels | 13 | 11-07-2011 02:19 PM |
| Possible wheel and tire problem | FHBasketball | Ford Explorer - Ranger Tires & Wheels | 1 | 01-22-2008 01:40 PM |
| Steering wheel off | atistang | Stock 1991 - 1994 Explorers | 6 | 01-11-2008 01:01 PM |
| Thread Tools | |
