Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Performance Lighting
Notices
Performance Lighting Aftermarket lighting. Driving lights, fog lights, rock lights, HID, halogen. Make your Ford Explorer light up the night!!
My headlights stay on too long.
Reply
Thread Tools
Old 10-24-2010, 07:13 PM   #1
jasonclo
Upper Michigan
99 sport
Vehicle Specs
(Original Poster)
Dk Exp My headlights stay on too long.
Hi people, my lights stay on a bit longer than they used to and I am pretty sure that they are draining my battery to the point of replacement now. I replaced the starter anyways, even though it didn't fix the problem. The slow start only occurs after I shut it off in low-light conditions. The automatic setting and timer after shut off is something I would like to remove completely. Anyone know how to do this? Very much appreciated.
jasonclo is offline   Reply With Quote
Old 10-24-2010, 07:28 PM   #2
swetrid
Reading Pa
2001 Eddie Bauer
Vehicle Specs
On my 2001 the switch is on the rearview mirror. Just turn it all the way to the left to turn off.
__________________
Resident Ford Tech for the last 17 years, 2001 Eddie Bauer 5.0L, Cherry Bomb Cat back, 2010 Ecoboost Flex
swetrid is offline   Reply With Quote
Old 10-26-2010, 10:18 AM   #3
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Welcome to this forum! I've moved your thread into the lighting section.
BrooklynBay is offline   Reply With Quote
Old 10-26-2010, 05:55 PM   #4
Bill Kemp
Elite Moderator Emeritus
Greenville, MI
Bill Kemp's Avatar
98 Mountaineer 5.0 AWD
Vehicle Specs
Quote:
Did this help your problem? Also maby your light sensor is covered or really dirty and is not sensing the light.
__________________
Bill Kemp
Mods to come.....
07 Lincoln MKX
Clones are people two.
Bill Kemp is offline   Reply With Quote
Old 10-27-2010, 01:18 PM   #5
shagr15
Chesterfield, Missouri
'99 XLT
Vehicle Specs
mine is the same way... the farther right you have the switch slid the longer the stay on. if you move it all the way to the left but not have it click, it keeps the automatic lights on and cuts them off right when you turn off the car.
__________________
99 XLT 15X8 Rock Crawler rims w/ 30 X 9.5 Goodyear Conquest tires, blacked out taillights, clear headlights, billet grille
http://s755.photobucket.com/albums/xx194/hmk1115/
shagr15 is offline   Reply With Quote
Old 10-29-2010, 04:32 PM   #6
jasonclo
Upper Michigan
99 sport
Vehicle Specs
(Original Poster)
Dk Exp Thanks
I wanted to thank each of you for replying. I did move the swithch and it worked. Turnes out the battery does need to go, too. Simple fix-but if you don't know...ask. Thanks again everyone. Jason
Old 10-30-2010, 09:24 PM   #7
BrooklynBay
Brooklyn, NY
Vehicle Specs
Thanks for the update!
Old 04-10-2012, 02:30 PM   #8
Packin
Wichita, KS
2001 5.0L V8 AWD LIMITED
Vehicle Specs
I am having this same problem with my EX, however in my case, I do have the switch all the way to the left (off position) and the lights still stay on an extended amount of time, before finally turning themselves off. I no longer have the option to choose between using the auto lights or not. Probably the switch in the mirror needs replaced?
Packin is offline   Reply With Quote
Old 04-10-2012, 02:45 PM   #9
Dan Whitaker
One fast putty tat
Raytown MO (Kansas City suburb)
Dan Whitaker's Avatar
No Mounty no more.
Vehicle Specs
When mine stared doing that I pulled the fuse for the auto lights. I don't remember which fuse & I don't have my Mountaineer anymore.
__________________
P r i c k me, do I not bleed Ford Blue.
Dan Whitaker is offline   Reply With Quote
Reply
Tags
battery drain, delay, headlights
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
