Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2011 - 2014 Ford Explorer 5th Generation Explorer > Stock 2011 - 2014 Ford Explorer Discussion
Notices
Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2013 Ford Explorer problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost.
2013 Blinker...am I the only one??
Reply
Thread Tools
Old 04-28-2012, 08:19 AM   #21
VinceL
Spring, TX
2013 Explorer Limited
Vehicle Specs
Quote:
Originally Posted by LeFurg View Post
I agree.
Both ways are by accident because there's not enough catch or resistance there to prevent the high beams from being mostly flashed (lever pulled) or sometimes activated (lever pushed). There needs to be more catch / resistance to require more effort in order to flash high beams and a "click" noise to signal the driver when that effort requirement has been met. I just hope those on here who are with Ford hear this and relay the message to the engineers.
I agree 100%. The high beams should require more resistance to activate, and having said that, I would prefer less resistance activating the blinker.
Having said all that, my wife doesn't seem to have a problem with it, and it's her car, so there you have it
__________________
We just bought American!
She got the 2013 Ex
Meet the Gray Ghost HERE
Check out the Gray Ghost on Fuelly.com
Average Mileage: 21.3
Best Tank: 26.5
VinceL is offline   Reply With Quote
Old 08-22-2012, 02:39 PM   #22
usmcsdiwife
Vehicle Specs
I'm having the same issue. I took it to the dealer and there is nothing they can do about it. If I get a ticket for accidentally flashing my high beams, I'm making the dealer or Ford pay for it.
usmcsdiwife is offline   Reply With Quote
Old 08-22-2012, 03:29 PM   #23
peterk9
Toyota Highlander Convert
Ottawa, Ontario area
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
Quote:
Welcome to the Forum usmcsdiwife.
As I've mentioned before is other posts, I'm not a big fan of this turn signal setup. I haven't had the same flashing problem but sometimes when I have the signal on, if I touch it again it turns the signal off instead of staying on. I also prefer to have it signal more than 3 times in the other mode.
There is nothing technically wrong with the turn signal. It is what it is, like it or not. Just make sure that you don't pull it topward you when you want to activate the signal.
__________________
Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).
Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds
peterk9 is offline   Reply With Quote
Old 08-22-2012, 04:20 PM   #24
OzzieMike
Broken Arrow, OK
2013 Ford Explorer XLT
Vehicle Specs
I agree with others here...it does take getting used to...but it works as designed, I'm sure. For me, I'd like to see a little less effort required to signal a turn (not a lane change).
__________________
2013 Explorer AWD XLT; Ruby Red; Equipment package 202A, Power Liftgate; Navigation
OzzieMike is offline   Reply With Quote
Old 08-22-2012, 04:59 PM   #25
boltsfan17
California
2013 Explorer Limited 4WD
Vehicle Specs
I must be in the minority. I like the blinker system a lot. I don't mind that it blinks only three times since that mode is really just for changing lanes. Speaking of high beams, I wish Ford would bring back the floor button you hit with your foot to turn on the high beams. I really enjoyed that driving the family Bronco in my teen years.
boltsfan17 is offline   Reply With Quote
Old 08-22-2012, 10:47 PM   #26
phareous
Charlotte, NC
2013 Ford Explorer Limite
Vehicle Specs
I despise the turn signals...it shouldn't take so much force to push the thing down. Ford engineers screwed up
phareous is offline   Reply With Quote
Old 08-23-2012, 06:27 AM   #27
jnbhobe
Erie,Pa.
2011 Explorer Limited,
Vehicle Specs
It doesn't bother me, other than I turn them off when I've turned them on already.
jnbhobe is offline   Reply With Quote
Old 08-23-2012, 07:15 AM   #28
OzzieMike
Broken Arrow, OK
Vehicle Specs
LOL....seems like more and more people around where I live wouldn't be bothered by them at all, since they don't seem to use turn signals at all!
__________________
Old 08-24-2012, 01:13 PM   #29
FordCustSrvc
Official Ford Rep
Dearborn, MI
FordCustSrvc's Avatar
Vehicle Specs
Quote:
Originally Posted by VinceL View Post
I agree 100%. The high beams should require more resistance to activate, and having said that, I would prefer less resistance activating the blinker...
I'm having the same issue. I took it to the dealer and there is nothing they can do about it...
Quote:
Originally Posted by peterk9 View Post
...I also prefer to have it signal more than 3 times in the other mode.
There is nothing technically wrong with the turn signal. It is what it is, like it or not. Just make sure that you don't pull it topward you when you want to activate the signal...
Quote:
Quote:
Originally Posted by boltsfan17 View Post
...Speaking of high beams, I wish Ford would bring back the floor button you hit with your foot to turn on the high beams. I really enjoyed that driving the family Bronco in my teen years.
Quote:
Originally Posted by phareous View Post
I despise the turn signals...it shouldn't take so much force to push the thing down...
VinceL, usmcsdiwife, Peter, OzzieMike, boltsfan17, & phareous,
I suggest feeling how sensitive it is compared with another Explorer.
Also, I recommend “turning” these great suggestions into the “Your Ideas” section here :
http://www.Social.Ford.com
Be sure to copy the link and share so others can comment and rate.
Cory
__________________
FORD SERVICE
p: 800.392.FORD
t: @FordService @Ford
f: facebook.com/FordExplorer facebook.com/Ford
FordCustSrvc is offline   Reply With Quote
Old 08-24-2012, 01:36 PM   #30
phareous
Charlotte, NC
Vehicle Specs
Cory
Existing one:
http://social.ford.com/your-ideas/te.../turn-signals/
Old 08-24-2012, 02:45 PM   #31
FordCustSrvc
Official Ford Rep
Dearborn, MI
Vehicle Specs
Thanks for posting the link, phareous.
Cory
__________________
FORD SERVICE
p: 800.392.FORD
Old 09-22-2012, 09:31 PM   #32
maliboo74
MA
Vehicle Specs
I found this thread by searching because I wanted to see if I was the one one too. I always hit the high beams whenever I go for the full right turn signal.
I just know one of these days the guy in front of me is going to get out of the car.
maliboo74 is offline   Reply With Quote
Old 09-22-2012, 10:05 PM   #33
VinceL
Spring, TX
Vehicle Specs
Yeah, the blinker stalk still annoys me. Too much effort to activate blinker, should have more to activate high beams. If they had the tensions reversed, it would be perfect in my opinion. Overall, a small complaint, but sometimes the little things mean the most
__________________
She got the 2013 Ex
Best Tank: 26.5
Old 09-22-2012, 10:25 PM   #34
phareous
Charlotte, NC
Vehicle Specs
I dispise the blinkers...half the time I just hold it instead of trying to click it. Sometimes I use two hands when I am stopped at the light. I hate it so much...easily the worst thing about the car.
Old 09-23-2012, 06:00 AM   #35
spitfisher
New England
2011 Explorer xlt
Vehicle Specs
I fixed my blinker stalk, it sold never happen again.
I sold my exp in a private sale yesterday
__________________
2011 Explorer XLT Tri-White plat. Dual panel sun roof, Rapid spec 202a package, tan interior, 20" polished aluminum wheels, tow package, cross rails for roof, Husky mats throughout & Thule 2100. Built June 23rd
spitfisher is offline   Reply With Quote
Old 09-23-2012, 09:19 AM   #36
Dr Plastic
Newport News, Virginia
Dr Plastic's Avatar
'13 XLT FWD
Vehicle Specs
I too find the lever extra hard to push down to stay on. Too hard if you ask me. Never had a car that was this tough to push down. I have onset rheumatoid arthritis in my hands and it can actually be painful at times.
__________________
2013 Explorer XLT FWD in Ruby red tint coat, 202A pkg, voice activated Nav, Tow and PWR lift gate.
U.S. Army Retired, 1978 - 1998
"Imagination is more important than knowledge" - Albert Einstein
Dr Plastic is offline   Reply With Quote
Old 12-01-2012, 11:19 AM   #37
the chickening
'13 Explorer Sport
Vehicle Specs
2nded.
I think I'd like to see less resistance for the 2nd "layer" of blinker rather than more resistance for the forward and back movements of the brights. The reason why the stick is accidentally going back and forth is because it takes some might to get that thing to the full blinker status.
My opinion about the way it works: I think it's great! I love the Euro features like this that the Explorer has. The only weirdness I've found is when doing a quick turn sequence, like a left at a light then an immediate right into a gas station. To use your blinker twice quickly for that, the 2nd attempt sometimes acts as a cancelation for the first turn signal. Therefore the 2nd turn, the right into the gas station, never happens. Minor, but still.
the chickening
2013 Explorer Sport - White Platinum
the chickening is offline   Reply With Quote
Old 12-01-2012, 01:59 PM   #38
peterk9
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
the chickening
As I've mentioned before, This is one item that I do not like on the Explorer. I can't tell you how many times I've accidently cancelled the signal. The problem is that the stalk always returns to the neutral position. I have no problem with it doing that when activating the 'lane change' feature, although 3 blinks is way too short. When actually signalling a turn, I would like to see the stalk remain in either the up or down position until the turn has been completed. I have had several occasions where the turn wasn't quite 90 degrees and the signal did not cancel itself.
__________________
Old 12-01-2012, 04:21 PM   #39
the chickening
'13 Explorer Sport
Vehicle Specs
If you're making a less than 90 degree turn, maybe just use the lane change feature?
__________________
the chickening
Old 12-01-2012, 05:19 PM   #40
peterk9
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
Three blinks won't do for me in signalling turns, especially if I'm in traffic. I'd have to hit it 4 or 5 times.
__________________
Reply
Tags
2013, blinker
Similar Threads
Thread Thread Starter Forum Replies Last Post
2013 Explorer Availability glenndibler 2013 - 2014 Ford Explorer Order Status Threads 20 03-05-2012 12:38 PM
Explorer sport blinker not functioning szhockeykidd Stock 1995 - 2001 Explorers 4 06-24-2010 05:23 AM
Brake and Blinker results in smoke from steering column! cherrybomb Stock 1995 - 2001 Explorers 8 10-18-2007 12:01 PM
right blinker issue mikenh2004 Stock 1995 - 2001 Explorers 1 09-16-2007 08:15 PM
"faulty" blinker arm jfman Stock 1995 - 2001 Explorers 2 12-10-2006 10:40 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
