| 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Home | Register | Members Rides | Vendors | Top Posters | FAQ/Rules | Social Groups | Search | Today's Posts | Mark Forums Read |
| Elite Explorer Registry This is the registry for members of the "Elite Explorers"CLICK HERE TO BECOME AN ELITE EXPLORER |
Thread Tools |
#21 |
Johnstown, PA
1994 Explorer XLT
Thanks! I was set on keeping the 17s that it came with, I love them. Then I came across those on ebay and had to have them. Plus I can a 245 tire on them
![]() How's the 9-5 treating you? __________________ 1994 Explorer XLT | M5R1 swap | 2" Lift | 32" ProComp Mud Terrains 2006 Saab 9-3 Aero | 2.8 Full pressure turbo | 6MT | 280whp/325wtq |
#22 |
And den
Raleigh, NC
'99 Sport 4wd
great, its got a td04 and a new throttle body so its happier now.
__________________ Curtis My truck 3link D30 SAS. DONE '99 Saab 9-5 2.3T http://www.eastcoastgearsupply.com |
#23 |
Johnstown, PA
1994 Explorer XLT
Nice! Did you originally have the GT17?
#24 |
Rust? You mean character!
Pittsburgh, PA
'97 XLT SOHC
Stop that stop that, no more Saab talk! You have to disguise it as Explorer talk, :P
__________________ Adam 4.0 SOHC Modified w/ Magnaflow Exhaust... ![]() '10 Edge Sport ![]() |
#25 |
Johnstown, PA
1994 Explorer XLT
Ok, back to Explorer content! Engine is OUT! She put up a fight but the most important thing is it's out.
Going to do some research about what i should do while it's out. My plan is to clean, pressure test and replace the leaking gaskets as the engine made no sounds and didn't smoke while I had it running. Bad new so far is the AC evaporator pipe was broke (had been sliding in and out when I bought it). When removing the engine it popped the whole way out so I'll be removing AC for right now. Might look for some junk yard replacements later down the line. ![]() ![]() And a good look at the hole I have to patch...grrrrr....
#26 |
Pittsburgh, PA
'97 XLT SOHC
So......
Where is dee turbo? __________________ Adam 4.0 SOHC Modified w/ Magnaflow Exhaust... ![]() '10 Edge Sport ![]() |
#27 |
Johnstown, PA
1994 Explorer XLT
Pick N Pull I got the trans from has an old Merc diesel with one on it......
#28 |
Johnstown, PA
1994 Explorer XLT
Made hopefully my last trip to the pick n pull for trans parts. I got the block plate for the manual, clutch and brake assembly, clutch switch, and manual speedo cluster. I had a false alarm for a manual 1354. Someone already snatched up the unit but left the shift. I think I'll be stuck with my electric for a while.
I should be able to get started putting it all back together by June. I really can't wait.
__________________ 1994 Explorer XLT | M5R1 swap | 2" Lift | 32" ProComp Mud Terrains 2006 Saab 9-3 Aero | 2.8 Full pressure turbo | 6MT | 280whp/325wtq Last edited by IAmTodd; 04-22-2012 at 09:22 PM. |
#29 |
Johnstown, PA
1994 Explorer XLT
Got the bugger mounted on the engine stand tonight and pulled the plugs. OH MY no wonder it didn't run all that great for the short period I had it running. I assume these were the original plugs. All 6 were very similar. Is this any indication of a problem or just neglect?
#30 |
Wannabe Elite Explorer
IL
95 Sport 4x4
WoW previous owner or owners received a compliment when you used the word hack... Welcome Back!!
__________________ 95 Sport 4x4, 3.73, tt/shackles, K&N FIPK, 33X12.50X15 BFG T/A, 15x10 DC-1's, Pro Comp ES9000 shocks, Flowmaster Catback, ARB OME Leaf Springs, 2" BODYLIFT "Thy shall Not Leaveth Thou Chariot Stocketh" Explorer 2nd Genesis GRNMACHINE |
#31 |
Duluth, MN
'99 Sport
That is just plain awesome...I have never seen a plug like that.
__________________ '99 Explorer Sport 5.0 AWD t-case with 2wd spindles (identity crisis) '99 Explorer XLT 4.0 SOHC 4x4 for daily driver/off road use |
#32 |
Pittsburgh, PA
'97 XLT SOHC
I am wondering if that is some type of achievement.
#33 |
Johnstown, PA
1994 Explorer XLT
Things have started to go back together!
Removed the resistor so I can get true oil pressure on my new cluster. Still need to get the sender though. ![]() Also got the $%^ clutch pedal in. So glad I never have to deal with that again.
#34 |
Pittsburgh, PA
'97 XLT SOHC
Moar updates!!!!!
Looking good though. __________________ Adam 4.0 SOHC Modified w/ Magnaflow Exhaust... ![]() '10 Edge Sport ![]() |
#35 |
Johnstown, PA
1994 Explorer XLT
Only update right now is a clean engine and transmission. Cleaned a ton of crap off both. I have reason to believe the transmission has been apart at some point. Hoping that's a good sign. Time will tell on that though.
#36 |
Johnstown, PA
1994 Explorer XLT
GOOD NEWS! Things are starting to go back together. I just put my big order into RockAuto. With the exception of a few minor things and fluids, this will get me rolling.
I really lucked out the other day and scored two Warn manual hubs from the pick n pull for $25. Just need to put up the conversion kit. ![]() And I've gotten the floor patched and started to put some things back together in the interior. ![]()
#37 |
Johnstown, PA
1994 Explorer XLT
First round of parts came in!
![]() I need longer bolts for the slave cylinder. The existing one has a metal base and is thinner. I'm happy to report my fuel filter pretty much fell out of the quick connects. I normally have to fight with those things. With that out of the way I can grind out the rivets for the radius arm cross members and get that cleaned up. After that it's time to get the anchor back in the front and get it all buttoned up. It's killing me to take my time at this point but I know getting in a rush will only make things harder in the long run. __________________ 1994 Explorer XLT | M5R1 swap | 2" Lift | 32" ProComp Mud Terrains 2006 Saab 9-3 Aero | 2.8 Full pressure turbo | 6MT | 280whp/325wtq |
#38 |
Highlands Ranch, Colorado
'97 XLT
WOW! That is just awesome. And I thought the plugs in mine were worn when I pulled them at 118k miles. I would definitely say yours were the original plugs.
Here are mine, practically brand new compared to yours: __________________ 1997 XLT SOHC Auto 4wd 132,000 miles Explorer registry Also in the garage: 2012 Escape Limited 4wd V6 auto AND 2004 Saturn VUE 4 cylinder 5 speed Colorado 4x4 Adventures |
#39 |
Johnstown, PA
1994 Explorer XLT
If mine looked like yours I'd pop them back in!
![]() It is truly amazing it ran on those plugs. __________________ 1994 Explorer XLT | M5R1 swap | 2" Lift | 32" ProComp Mud Terrains 2006 Saab 9-3 Aero | 2.8 Full pressure turbo | 6MT | 280whp/325wtq |
#40 |
Johnstown, PA
1994 Explorer XLT
Rivets are ground off. I need to pick up a socket to remove the radius arm nuts then I'll work at getting the bracket off.
![]() Also order the nut kit for the manual hubs. I'm hoping to have the front end fixed up by the weekend and get the motor dropped back in this weekend. I'll make my yearly visit to Ford Nationals at Carlisle with the Swedish meatball for hopefully the last time. Next year it's back to Ford! __________________ 1994 Explorer XLT | M5R1 swap | 2" Lift | 32" ProComp Mud Terrains 2006 Saab 9-3 Aero | 2.8 Full pressure turbo | 6MT | 280whp/325wtq |
| Suggest this thread to friends: |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 94 explorer sport fuel pump problem | D_H | Stock 1991 - 1994 Explorers | 4 | 04-25-2012 04:48 PM |
| 03 explorer gas gauge .. slow to respond | Trek5000 | Stock 2002 - 2005 Explorers | 9 | 02-19-2011 08:48 AM |
| Need 02 Explorer Fuel Sender ckt Wiring diagram | Kentski | Stock 2002 - 2005 Explorers | 3 | 02-27-2007 09:43 PM |
| '94 Explorer Starting problem | spokanedj | Stock 1991 - 1994 Explorers | 4 | 12-12-2005 12:33 AM |
| Rancho shocks on '94 with lift | cherylj | Explorer - Ranger Shocks, Suspensions, Lift Kits | 0 | 02-06-2000 05:29 PM |
| Thread Tools | |
