Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
A/C Problems
Reply
Thread Tools
Old 05-06-2012, 07:30 PM   #1
jestep
Bonaire, GA
93 Ford Explorer
Vehicle Specs
(Original Poster)
Unhappy A/C Problems
Got a 98 Explorer, the A/C qiut working, upon troubleshooting found the compressor clutch bearing came apart. I bought a new clutch and installed it while the compressor was still installed in the truck, now it makes a grinding noise when the clutch does engage, but it doesn't always engage. Could this be a freon low problem, or did I screw it up installing it. I will say the new clutch came with 5 washers of different thickness and I'm not sure where they go. Had no problems with the A/C prior to clutch bearing going out. Thanks for your help
jestep is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
4x4 4.6L ford explorer with heating and a/c problems tngirlns Stock 2002 - 2005 Explorers 1 01-07-2011 10:10 AM
A/C Problems Blacksheep Josh Stock 1991 - 1994 Explorers 2 08-03-2006 05:32 AM
A/C Problems RajnCajun7 Under the Hood 1 07-27-2004 09:01 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
