| 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Home | Register | Members Rides | Vendors | Top Posters | FAQ/Rules | Social Groups | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#21 |
Human-Animal Hybrid
Carmichael, CA
'97 Sport 4x4
This is for 97 SOHC
#22 |
Human-Animal Hybrid
Carmichael, CA
'97 Sport 4x4
Two more
#23 |
Greenville, SC
2000 Sport SOHC 2WD
That's it!
Page 23-6 clearly shows pin 46 connected to the air inlet control valve (solenoid). I tried separating the wires in the bundle on the engine side of the main engine harness electrical connector mounted in front of the ignition coil pack and looked for a brown wire. The colors are faded so I may have found one but I'm not sure. If I disconnect that connector will I be able to find pin numbers that correspond to the pin numbers at the PCM connector?
I really appreciate you posting all of the PCM related diagrams. It is a real service to me and other forum members! __________________ My Helpful Threads, Registry, 16.4/23 mpg, 3900 lbs, 5R55E, 3.73:1, 175 rwhp, Henson custom tune, CAI, Spectre air filter, Lightning 90mm MAF, 75mm throttle body, A/F ratio meter, synthetic oils, Accusump, 2 row radiator, 3+1 leaf springs, .75 inch drop, Edelbrock IAS lowering shocks, engine oil & ATF temp gauge & remote filters & coolers, remote crank |
#24 | |
Human-Animal Hybrid
Carmichael, CA
'97 Sport 4x4
Quote:
It is possible that the version of the manual that I have is an early edition and that they may have corrected the manual to show that circuit in the connector in a later version. My manual isn't from "official" sources. |
#25 |
Wannabe Elite Explorer
TORONTO
1997 SPORT 2WD 4.0L SHOC
Hello ,
i have 1997 sohc 2wd ... I am installing a new entrainment center with rear view camera and i need to find a back up light wire and a park position wire , i been told to do it from the dtr on the transmission and i am wondering if i have access to such wire from the pcm harness ? |
#26 | |
Human-Animal Hybrid
Carmichael, CA
'97 Sport 4x4
Quote:
#27 |
Cuiabá-MT
2001 Ford Ranger FX4
hi guys.
I am Brazilian and I do not speak English very well. precise outline of the pcm pin eec v of a 2001 ranger sohc v6 210cv. do not know if realized, but the third part of the pins on the page that has a think are the v8, which indicate the pins 91-104, lists four lambda sensors and injectors 2,4,6,8. cnsigo not find this part at the v6 referendum, could someone help me? |
#28 |
Springfield, Ontario
99 Explorer Sport 4x4
Will the 97 wiring diagram work for a 99 sohc? I am doing an engine swap and the new engine has a random wire sticking out about 2 inches from the pcm connection. there is no indication that the wire has been disconnected or taken out of the current wiring harness. I also checked my old wiring harness and there is no blue wire in the same location.
__________________ Derek Mann "Redneck Law: 4x4 just means getting stuck in more inaccessible places" |
#29 |
Nevermind my last post. Someone tapped into a wire.
| Suggest this thread to friends: |
| Thread Tools | |
