Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Classifieds: Explorer / Ranger / Bronco II Parts For Sale and Wanted > Explorerforum Vendors
Notices
Explorerforum Vendors These folks are helping to support the site. If you are a vendor and would like to be able to sell products on the site, please contact me to make arrangements. Email - ab7fh@yahoo.com
Behemoth Drivetrain - Planetary Doubler kits - The Strong Box
Reply
Thread Tools
Old 04-30-2012, 12:43 PM   #1
Behemoth DT
Torque Monster
Clarkson,KY
Vehicle Specs
(Original Poster)
NEW!! IMPROVED AND TOTALLY REDESIGNED!!
All of our Strong Box kits use stout planetary gears with 2.4:1 - 2.7:1 low range gearing. We can even use your planetary gears from electric shift transfer cases that you otherwise may be throwing in the junk pile.
At this time, we have kits for full size Ford transmissions, full size Chevy transmissions, and Ranger/Explorer transmissions.
We also have kits using NP208 planetary gears, as well as 231/241.
Jeep kits are also available using the 231 planetary gears
Upcoming kits for other gears include BW1345, BW440* series, and NV271.
Our ultimate goal is to offer kits that will work with the planetary gears that are readily available to you; saving you time and money otherwise spent looking for that one manual shift case that might work with other kits.
WWW.BEHEMOTHDRIVETRAIN.COM
NEW!
YES, WE ALSO HAVE A KIT THAT PUTS A NP205F BEHIND STOCK RANGER/EXPLORER TRANSMISSIONS!!!
Standard Ranger/Explorer kits have a steel plate integrated into the clocking adapter that can be upgraded along with the output shaft to accomodate a Ford NP205
STRONG BOX FEATURES:
•~2.4:1 - ~2.7:1 Low range multiplier
•Low profile design minimizes / eliminates fitment issues with floorboards, exhaust, front driveshaft, shifters, etc...
•72 position, 360º clockability in 5º increments
•New 4340 chromo output shaft
•6061 billet aluminum housings precision machined
•Fill plug, drain plug, and particle magnet
•Bolt-on shifter included
•Easy installation: No machining, or welding required
These kits are designed to be compatable with many different transfer cases, including the NP 205 transfer case, and allow use of the original NP 205 shift rails with little to no modification, even with most "twin stick" conversions.
The Strong Box is 7.9" diameter, and will range from 6.5" long to 8" long, depending on the choice of planetary gears used, and options.
Our Strong Box kit is ready to bolt on when it is delivered to your door. Just don't forget to pour in the gear oil. If you ever need to clock the trasfer case in a different position, you remove 6 bolts, rotate the transfer case to the desired alignment, replace 6 bolts. No need to drain, or scrape RTV, due to it's completely sealed design.
Introductory Price: $899.00 before $200.00 core discount - GET ONE BEFORE THE PRICE GOES UP!!
Strong Box + NP 205F = 19" - 21" long to center of rear yoke
1:1 Hi / Hi
~2:1 Hi / Low
2.7:1 Low / Hi
5.4:1 Low / Low
2.7:1 2wd Low without modifications to NP205
(figures are for the 2.7:1 low range)
We make kits for nearly every application, contact us to order the Strong Box that will make your rig the Torque Monster you need to dominate the trail and the competition.
CORE DISCOUNT
•Introductory price of $699.00
Until further notice, if a customer provides a good, used planetary gear set from a transfer case of any version (manual shift, electric shift, etc...), they will get a $200.00 discount off of the original $899.00 price. Discount will be applied only after core parts have been inspected and approved.
NOTE: The gear set you are providing for a core discount does not nececarily have to match the Strong Box you are purchasing; it just has to be a gear set that we can use (example: You have a 23 spline Jeep 231 and you want to purchase a 32 spline Chevy 241 Strong Box). Please contact us to see if we currently need the planetary gear set that you may have to offer.
__________________
At some point, the weak link on your trail ride will be the obstacles that you encounter, and not your rig.
Behemoth DT is offline   Reply With Quote
Old 05-04-2012, 02:29 PM   #2
splodo49
Ejection seat man..
Tooele,Utah
splodo49's Avatar
94 XLT,75 FJ, 05 Cummins
Vehicle Specs
205
I have found a 205 and in fact am currently taking out the shift rail and sending it to you to be machined so i can have front diggs. Im also going to get your rear output support to help hold up the heavy pig. Thanks again Behemoth.
__________________
SAS BUILD UP
2.5 Ton Rocks, Fully Locked, Pinion Brakes, Full Hydro, Re-Centered H1s, Rock rings. 42" Pitbulls Max speed about 35-40
splodo49 is offline   Reply With Quote
Old 05-08-2012, 01:08 AM   #3
yostyexplorer94
Slow and Steady
Newburg, PA
yostyexplorer94's Avatar
'94 Eddie Bauer
Vehicle Specs
Quote:
Originally Posted by Behemoth DT View Post
We will have some pics of completed new housings this weekend
Got any pictures yet?
__________________
____________________________________________________________________________
SAS <-> Car Trailer Build Thread <-> Explorer Registry <-> Clutch Pedal Swap
Ryan Yost
yostyexplorer94 is offline   Reply With Quote
Old 05-08-2012, 11:16 PM   #4
Behemoth DT
Torque Monster
Clarkson,KY
Vehicle Specs
(Original Poster)
Quote:
Finishing up on the billet 1354 and 1356 housings. running behind. They are looking sweet.
By the way, I recieved both of your cores safe and sound.
Thanks for the orders!
__________________
Old 05-08-2012, 11:25 PM   #5
yostyexplorer94
Slow and Steady
Newburg, PA
'94 Eddie Bauer
Vehicle Specs
Good to hear, thanks for the update.
__________________
Ryan Yost
Old 05-10-2012, 02:34 PM   #6
bronco2guy
Built not bought.
Columbia, MO
bronco2guy's Avatar
91 Ford Explorer
Vehicle Specs
Will you have something like 1356 front section *doubler*, cause I'm running V8 setup with tranny that has 6 bolts and 31 spline that goes to the transfercase. I would be interested in something like that.
bronco2guy is offline   Reply With Quote
Old 05-10-2012, 11:26 PM   #7
Behemoth DT
Torque Monster
Clarkson,KY
Vehicle Specs
(Original Poster)
Quote:
Yes, for the full size transmissions we have 1356 and 208 Strong Box kits.
__________________
Old 05-11-2012, 07:17 AM   #8
bronco2guy
Built not bought.
Columbia, MO
bronco2guy's Avatar
91 Ford Explorer
Vehicle Specs
Do you have any pics of the 1356 section?
Also do you have a pic of your 1354 to 1354 using a new section not choped t-case? I might sign up for one of those.
Old 05-13-2012, 02:09 AM   #9
yostyexplorer94
Slow and Steady
Newburg, PA
'94 Eddie Bauer
Vehicle Specs
http://www.explorerforum.com/forums/...58#post2956958
Pictures?
__________________
Ryan Yost
Old 05-16-2012, 02:49 PM   #10
yostyexplorer94
Slow and Steady
Newburg, PA
'94 Eddie Bauer
Vehicle Specs
1354 billet housing picture jacob emailed me.
__________________
Ryan Yost
Old 06-06-2012, 02:43 AM   #11
Behemoth DT
Torque Monster
Clarkson,KY
Vehicle Specs
(Original Poster)
Pictures?
Pictures of 1354 Strong Box added to first post, 1356 pics are about a week away. Thanks for the orders so far!
We had about 2 weeks of machines down, but we are back up and running 100%.
__________________
Old 06-23-2012, 06:52 AM   #12
Behemoth DT
Torque Monster
Clarkson,KY
Vehicle Specs
(Original Poster)
Here is a video of a customer running the 1354 Strong Box with a 1350 behind it.
https://www.youtube.com/watch?v=f3ec...e_gdata_player
Next week I'll be finishing up on 2 more 1354 Strong Boxes.
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Doubler Kit Installed ford-racing-89 New Member Forum 8 10-09-2012 08:02 PM
doubler kits brnbomr Offroad Drivelines 0 04-26-2012 02:10 AM
Is anyone making doubler kits anymore? splodo49 Explorer & Ranger Transmissions, Transfer Cases, & Differentials 3 06-28-2010 12:50 PM
Box Building Questions - Polyfill and cu.ft. V8BoatBuilder Explorer Audio & Navigation 2 08-10-2003 02:22 PM
Port length and a few box ?'s Mbrooks420 Explorer Audio & Navigation 8 07-31-2002 12:43 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
