Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Stock 2006 -2010 Explorers
Notices
Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
2006 XLT Shifter shifts easily but car doesn't move
Reply
Thread Tools
Old 04-19-2012, 01:39 PM   #1
zwin
2006 Explorer
Vehicle Specs
(Original Poster)
2006 Explorer XLT 92,000 miles.
From "Park" the shifter easily moves into all other gears R,D,N, etc.
But while the shifter moves easily, the transmission does not engage to move the car (forward or reverse).
Dealer said this was a common problem and that a pump in the transmission needed to be replaced, but since they were in there recommended replacing the entire transmission $4,800!
Anyone have this problem or ideas?
PS No indicator lights are illuminated -- check engine light is not on. Noticed the problem happens on cold start, but maybe coincidental. Problem is intermittent -- does not happen all the time.
zwin is offline   Reply With Quote
Old 04-20-2012, 12:39 AM   #2
asull85
Agawam, MA
2010 Explorer XLT
Vehicle Specs
Sounds right. My mother just had this issue with her Taurtus and she ended up needing a new transmission. Good luck.
__________________
My Registry- Magnaflow Exhaust, K&N Cold Air Intake, Aries Grille Guard, Blacked out grille, Kenwood DDX616 head unit w/ Sirius Satellite Radio, 5000k HID headlights and fogs, KC Daylighters w/ 5000K HID's, LED turn, tail, brake and backup lights.
WishlistBlacked out headlights, Rancho Quicklift struts...
asull85 is offline   Reply With Quote
Old 04-20-2012, 08:11 AM   #3
Explorer_PL
Rockland County, NY
2006EB,V8, Fisher plow
Vehicle Specs
$4800 for a tranny ???
Holy s***t !!!
Explorer_PL is offline   Reply With Quote
Old 04-20-2012, 08:44 AM   #4
asull85
Agawam, MA
2010 Explorer XLT
Vehicle Specs
I just want to clarify that the problem sounds right not the price of the repair. $4800 is outrageous. I would definitely shop around.
__________________
Old 05-08-2012, 09:03 AM   #5
caferacer
Brooklyn, NY
'06 XLT
Vehicle Specs
Hey Zwin, any resolution on this issue? My '06 with 78,000 miles would not engage reverse last night. Forward gears are fine and no lights on the dash. I fear I need a new tranny...
caferacer is offline   Reply With Quote
Old 05-09-2012, 08:20 AM   #6
zwin
2006 Explorer
Vehicle Specs
(Original Poster)
I brought it to a transmission specialist who tested it for several days and wasn't able to replicate the problem. He then did a transmission service ($225.00) in which he took the pan off and replaced the fluids. Problem has not resurfaced, but I've upgraded my AAA towing plan just in case... My problem was a bit different because it didn't go into any gear and there were no problems with electronics at all. Good luck
Old 05-09-2012, 08:21 AM   #7
zwin
2006 Explorer
Vehicle Specs
(Original Poster)
PS, make sure there's sufficient transmission fluid. There's no transmission fluid "dip stick" on the car though.
Reply
Tags
shifter, transmission
Similar Threads
Thread Thread Starter Forum Replies Last Post
2006 Ford Explorer Shifter click noise mkdeceiver Stock 2006 -2010 Explorers 7 01-04-2013 04:15 AM
2006 Ford Explorer XLT with rear end damage. Tam Body Work & Detailing 1 07-15-2010 09:26 AM
2006 xlt with 87k mileage...should we buy it? wensilver Stock 2006 -2010 Explorers 7 08-14-2009 04:23 PM
Fan noise while towing - 2006 Explorer XLT ben1000 Under the Hood 2 08-15-2006 04:01 PM
Hepl!!! 2006 XLT FJB20 Ford Explorer - Ranger Tires & Wheels 6 11-02-2005 01:08 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
