Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Stock 2006 -2010 Explorers
Notices
Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Brake caliper bleeder valve ripped off
Reply
Thread Tools
Old 05-07-2012, 07:08 AM   #1
joachimf
Cologne, Germany
'07 Eddie Bauer 4x4
Vehicle Specs
(Original Poster)
Dear @all,
yesterday I wanted to sevice the brake fluid on our '07 EB. Unfortunately I ripped off a bleeder valve of a rear caliper. Head with hexagon is ripped off, valve itself is still in the caliper. No ridge to use a vice or similar.
Away from ordering a new caliper, is there a process to get the damaged valve out?
What is the dimension of the new valve?
Thank you for your help!
__________________
Joachim
07 Explorer Eddie Bauer 4x4
02 Explorer XLS M/T 4x2
95 Mustang 5.0 GT Convertible
82 Corvette Coupe
67 Mustang 289 M/T Convertible
joachimf is offline   Reply With Quote
Old 05-07-2012, 07:07 PM   #2
Explorer_PL
Rockland County, NY
2006EB,V8, Fisher plow
Vehicle Specs
Sorry I do not have the size answer, but you are not the first one breaking them off. They tend to snap off.
Check this:
http://www.ehow.com/how_5908178_remo...e-bleeder.html
http://ls1tech.com/forums/suspension...e-caliper.html
Explorer_PL is offline   Reply With Quote
Old 05-07-2012, 07:12 PM   #3
techieman33
Topeka, KS
techieman33's Avatar
00 V8 Mountaineer
Vehicle Specs
At $35-$40 for a new caliper I would just order a new one.
techieman33 is offline   Reply With Quote
Old 05-07-2012, 07:47 PM   #4
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Use an easy out bolt & screw extractor.
BrooklynBay is online now   Reply With Quote
Old 05-08-2012, 09:13 AM   #5
vipersinu2
The Big City of Orange City, Florida
vipersinu2's Avatar
97,03 explorer 07 mounty
Vehicle Specs
yes easy out or left hand drill bit it might spin out.
vipersinu2 is offline   Reply With Quote
Old 05-13-2012, 04:57 AM   #6
joachimf
Cologne, Germany
'07 Eddie Bauer 4x4
Vehicle Specs
(Original Poster)
Thank you guys for reply.
Yes, my first idea was to order me a new caliper, just a $50 affair. I checked RockAuto and found out rear calipers are the same from '01 to '10.
Fortunately I do have a rear right caliper in stock for our '02 Explorer. They seem to be identical. But... the threads taped into the housing for bleeder valve and brake line are different. Whereas the '02 caliper has 3/8" UNF theard the '07 caliper is metric, 10mm.
So I'm going to get me some metric 10mm bleeder valves and try to screw the ripped-off out after soaking in penetrating oil for some days.
__________________
Joachim
82 Corvette Coupe
Old 05-13-2012, 06:12 AM   #7
corkey
Elite Canuck, Eh ??
In the Great White North where winter never seems to end ,Ontario,, still ice fishing,,
corkey's Avatar
96xl,99xls,old Rangers
Vehicle Specs
there is an easy way, just get a drill bit that fits in the hole, make sure the hole is completely clean with that bit.
than step up just a bit bigger but not as big as the threads, and drill it again, as the metal thins you may be able to use a slot screwdriver that fits in the hole to spin it out as the heat from drilling will loosen it,
just make sure your bit is in the middle,,
__________________
Log Roller,, Fox Coilovers 35's and others, ,
Truck of the month
Ranger Of Danger,,,project truck,
also look for Blues Traveller Elite registry, ,
corkey is offline   Reply With Quote
Old 05-13-2012, 08:52 AM   #8
BrooklynBay
Brooklyn, NY
Vehicle Specs
These bits go into a drill:
You set the drill to reverse, then the bit will drill into the bleeder until the easy out part grabs the bleeder. Here's another extractor:
You drill a hole into the bleeder, then tap the extractor into the hole. A wrench or a socket turns the extractor with the bleeder. Here's another extractor set:
A drill bit drills the hole, then the spiral extractor grabs the bleeder.
Old 05-13-2012, 08:58 AM   #9
gmanpaint
Torsion Bar Free
since 2010
gmanpaint's Avatar
94 XLT-95 FX4
Vehicle Specs
BB, I need to get me a set of those Pro-Grabit! Those look very handy indeed.
__________________
The Black Hole
Pugly
gmanpaint is online now   Reply With Quote
Old 05-13-2012, 09:02 AM   #10
BrooklynBay
Brooklyn, NY
Vehicle Specs
Sears sells their own version of them. Check Lowe's & Home Depot as well. The first time I've used one of these bits was on a Craftsman planer. One of the screws holding the blade was stripped, and I couldn't remove it. It was an Allen head bolt. The tool zipped right into it, and removed it in no time.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to change your 2005 V6's PCV Valve High_Order1 Stock 2002 - 2005 Explorers 8 02-03-2013 04:10 PM
A4LD Valve Body Rebuild Journal - Reassembly (w/pics) TN_Explorer Explorer & Ranger Transmissions, Transfer Cases, & Differentials 28 04-12-2011 11:38 PM
96 5.0L P0402 but no DPFE Sensor? cbr rob Stock 1995 - 2001 Explorers 31 09-02-2010 08:32 PM
Warning!! "Dorman Disc Brake Caliper Bracket" does not fit bkmc24 Stock 1995 - 2001 Explorers 2 03-07-2010 12:02 PM
Brake Caliper slider Pins Icepick2010 Stock 2002 - 2005 Explorers 8 02-18-2010 05:24 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
