| 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Home | Register | Members Rides | Vendors | Top Posters | FAQ/Rules | Social Groups | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#1 |
Wannabe Elite Explorer
04 Sport trac XLS
P0193 - Fuel rail pressure sensor circuit high input
I keep getting this code. I would reset with my OBD II Scanner and it would still appear. Can some one guide me in the right direction as what i may need to check and repair/replace. I have a sport trac 2004 XLS.
Thanks |
#2 |
Towing Moderator
North East Arkansas
2012 F150 4x4
Sounds like your fuel pressure regulator or whatever your truck uses to regulate fuel pressure is messed up, or the sending unit is bad. Clearing the code won't work- you have a problem that needs to be fixed. I think yours uses a returnless fuel system, so the pump and regulator may be all the same thing
![]() The best thing to do is get a fuel pressure gauge, connect it to your rail and see what your fuel pressure is. __________________ -Evan Febuary 09 Feature Truck - Elite Registry - Photo Gallery - Feedback - Go Elite! - My Write Ups - EF Vendors |
#3 |
Avondale, AZ
06 Explorer EB
is this a flex fuel vehicle?? VIN code K
if so, with scanner connected, Key ON Engine RUN, is pressure above 119.9 psi?? __________________ 06 EB Explorer - SCT X3, K&N CAI kit, MSD COPs 94 GT Vert - see http://www.cardomain.com/id/cjones101812 for mods 00 Excursion - see http://www.cardomain.com/id/cjones101812 for mods |
#4 |
04 Sport trac XLS
Engine Type
The vehicle's engine type is 4.0L V6 FI SOHC. Don't know if that information will be helpful. The eighth character in the VIN is a K.
#5 |
Avondale, AZ
06 Explorer EB
according to my book, vin X is the 4.0L FlexFuel engine.
are you running gasoline or natural gas?? assuming you are running gasoline... check for fuel in the vacuum hose of the FRP sensor after running engine at idle for 2 minutes. if not, check fuel pressure. if pressure good, check voltage between Sensor connector Vref (Pin#3 LB)and Signal Return (Pin#4 GY/RD) should be 4.0-5.5v with key ON. |
#6 |
columbus, georgia
2004 ford sport trac
where can locate the fuel rail pressure sensor a circuit high on my 2004 sport trac ford?
| Suggest this thread to friends: |
| Thread Tools | |
