| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Home | Register | Members Rides | Vendors | Top Posters | FAQ/Rules | Social Groups | Search | Today's Posts | Mark Forums Read |
| Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum. |
Thread Tools |
#1 |
Wannabe Elite Explorer
2002 Explorer xls
installing quickstruts on my 2002 ex. Will I need a spring compressor?
I know the rear drivers side is broken and the passenger side might be also. I will changing both rears. Found on Amazon for 130 bucks each. been reading thru posts on here and seems like a pretty easy job but no one mentions if a spring compressor is needed.
#2 |
KCMO
'02 Mountaineer AWD V8
It's not needed. quickstruts have springs already assembled. You just take out the old strut assembly and put in the new one.
I did mine using strutteks, http://www.facebook.com/media/set/?s...2348605&type=3 ----------------------------------------------------------- MY MOUNTY http://www.facebook.com/diyfordexplorer?sk=photos |
#3 |
2002 Explorer xls
So the new ones must have a band that is cut I am guessing. thanks for the info
#4 |
I'm a jackass!
El Paso, TX
blue 02 xlt & white 02xls
No band you replace the whole assembly not the spring
__________________ If interior is to exterior and include is to exclude, then increment is to: |
#5 |
2002 Explorer xls
I guess I am just picturing the spring being fully extended and wondering if that will be hard to deal with unless I just use the vehicle weight to compress it before tightening the lower control arm. I was a mechanic for most my life but haven't messed with anything for about 8 years now.
| Suggest this thread to friends: |
| Tags |
| 2002, broken spring, quickstrut, xls |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| New 2002 Ex owner | christeymg | New Member Forum | 5 | 01-31-2012 06:52 PM |
| My 2002 Ex ....hello everyone | AcroEX | Modified 2002 - 2005 Explorers | 5 | 08-03-2006 07:38 AM |
| Coil Spring Compressor | Rod Bivens | Explorer - Ranger Shocks, Suspensions, Lift Kits | 1 | 07-21-2000 11:09 AM |
| Thread Tools | |
