| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Home | Register | Members Rides | Vendors | Top Posters | FAQ/Rules | Social Groups | Search | Today's Posts | Mark Forums Read |
| Explorer Audio & Navigation Audio and navigation systems. CD, DVD, MP3, GPS, Video, Mobile Computer, Speakers, Amplifiers. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Alabama
'97 Mounty 5.0 V8 AWD
System Upgrades (semi complex)
Ok, my system is due for a little refresh.
Current setup: Pioneer AVH-P1400DVD Planet Audio 4 Channel Amp 2 12" Orion's Turbo Bass Probox Sony Xplod door speakers Plans: Get a new 2 channel amp for the subs and run the Planet Audio 4 channel to door speakers and add a capacitor. I want to do this by utilizing distribution blocks for power and grounds. I want this install to be clean. I will be going along this guide: ![]() Picture from Crutchfield Multiple pics to come
#2 |
Alabama
Ideas & Supplies
Ideas:
I have an Optima YellowTop Battery, I believe this is plenty of battery for my system but I do have a Wal-Mart brand battery that is perfectly fine. Should I wire this into my system? What about my alternator? It is stock and I'm not sure what it is rated at. Should this be upgraded as well. I've read the "Big Three" wiring upgrade, should I do this as well? Supplies: What I Need-- Power/Ground Wire Distribution Blocks Two sets of RCAs Second (or is it primary) Amp More remote wire What I Have-- Capacitor Head Unit/Amp/Box/Component Speakers/etc. Supplies are in: ![]() Amp: ![]() Wires: ![]() Capacitor: ![]() Distribution Blocks x2:
#3 |
Alabama
Install is finished.
Head Unit: ![]() Crunch Amp, Capacitor, Distribution Blocks: ![]() Planet Audio Amp: ![]() Orion 12s and Turbo Bass Probox:
#4 |
Kenmore , WA
1992 Explorer XLT
The Big Three could help you get more out of your current alternator/battery set up. And is probably worth doing since the factory gauge wire is tiny. Im pertty sure you have a 130 amp alternator, someone correct me if thats wrong. Whats the Wrms of the 4 channel amp? Do you have any problems currently with it? (power wise)
#5 |
Kenmore , WA
1992 Explorer XLT
Also, what will the new 2 channel wattage be?
#6 |
Minneapolis, MN
'06 XLS
I would put your walmart battery under the hood, and use your yellow top and not your cap. Caps do what they are supposed to do when there is the big bass hits, but they put resistance in line during continuous use. where as a battery doesnt.
#7 | |
Alabama
Quote:
4 X 75 Watts RMS Power (4 Ohm) 4 X 150 Watts RMS Power (2 Ohm) 2 X 300 Watts RMS Power (4 Ohm) It is in perfect condition. I'm not really sure yet, my subs are Orion Cobalt 12s (CO124S). I may however end up upgrading these as well. Not 100% sure yet. Interesting. I will definitely do some more research into this. |
#8 |
Alabama
All the supplies are in, the setup will be:
Optima YellowTop Battery Pioneer AVH-P1400DVD Head Unit Diesel Audio 1.5 Farad Capacitor Planet Audio 300.4 Amp Sony Xplod Door Speakers Crunch Powerzone 1400.2 Amp Orion Cobalt 12" Subwoofers x2 (CO124S) Turbo Bass Probox Scosche Distribution Block x2 Scosche Wiring (for the most part) I think that's it. The third post will be edited for installation. I'm so excited!!! Last edited by YoungMounty; 06-26-2012 at 03:22 PM. Reason: Typo |
#9 |
Kenmore , WA
1992 Explorer XLT
Put up the pics once its all installed!
#10 |
Middle GA
91 Mazda Navajo
The Big Three Helps Allot , I've Upgraded my big three and it helped , The less voltage drop you Have the Better you system and Subs will sound , As Well as Last , I've been beating my Audiobahn aw1200x subs in there JL audio HO enclosure Wired at 1 ohm with a 1800 Watt Quantum audio 1 ohm amp , and these subs are still pounding , I listen to all types of music with it , Rap, Heavy metal , Country ,Current Hits ,And Most all music that re produces sounds great ! My subs were Manufactured in 2001 , not sure how there still alive haha , Tuned in for pics !!
__________________ 1999-Exdpedition Xlt 4.6 Silver-Grey- OIL LEAKING .haha ZAPV#161, 91 Navajo, 3" Bodylift , 2.5"skyjacker coils,skyjacker shocks , 2" ext shackels, . home made CAI.no muffler's straight cat's ,warn locking hub's,throttle cable mod ,deleted rear swaybar , front sway bar disco's ,custom cut front bumper ,deleted front fender flare's ,clear turn's ,clear tail's,33" Pro Comp AT's 1953 Ford F-100 Restoration Project |
#11 |
Alabama
Third post updated with install.
I ran into a problem with the Planet Audio. Apparently the other two channels don't work and I just now figured it out because I've never used them before now. I've got all 4 door speakers wired to 2 channels right now so I'm looking for a new 4 channel. Probably gonna go with Crunch. Last edited by YoungMounty; 06-26-2012 at 03:21 PM. Reason: Typo |
#12 |
Alabama
I got a new 4 Channel. It is a JBL GTO-504EZ:
![]() This amp is amazing. Easy controls and powers my Sony Xplods better than I could have ever imagined. If you're looking for a cheap ($150), awesome door speaker amp go with this amp, you won't be disappointed. I have a question for you audio guys. Can my AGM Optima battery be wired up to a regular Lead Acid Battery without causing problems? |
| Suggest this thread to friends: |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| EEC-IV 2 and 3 digit trouble codes. | BrooklynBay | EEC IV | 16 | 03-26-2012 09:46 PM |
| ford manufacturer specific codes | whale45714 | Stock 1995 - 2001 Explorers | 0 | 04-16-2011 10:03 AM |
| ABS System Basics | ExplorerDMB | Under the Hood | 11 | 11-09-2010 05:15 PM |
| 93 A/C Upgrade: Am I Being Screwed? | mikeinri | Stock 1991 - 1994 Explorers | 8 | 08-28-2007 09:07 PM |
| Pentagon Developing System To ID People By Their Walk | 02XSport | Exploring every thing under the sun!! | 2 | 05-20-2003 01:58 PM |
| Thread Tools | |
