Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Modified 1991-1994 Explorers
Notices
Modified 1991-1994 Explorers Questions concerning modifications to the 1991-1994 Explorer, Mountaineer, Ranger and Navajo. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
Warn Hubs and Torquing Wheel Bearings
Reply
Thread Tools
Old 06-21-2010, 11:44 PM   #1
mechjames
Triangle Beach Explorer
Richmond, BC
mechjames's Avatar
1994 Explorer XLT
Vehicle Specs
(Original Poster)
I just did my front wheel bearings again tonight. I did them about a year ago as well. Is it possible i'm not torquing the bearings correctly? They we're really burnt, and the inner one was stuck to the spindle again.
I'm following the instructions as per the Warn Spindle Nut Conversion kit. Torque to 35 ft-lbs and then back off 90 degrees.
The bearings seem really tight, but i'm not too happy about the backing of the 90 degrees part. Is this normal while torquing wheel bearings?
mechjames is offline   Reply With Quote
Old 06-21-2010, 11:46 PM   #2
rileyrs
2002 ranger
Vehicle Specs
several bearing procedures call for this. how are you packing them with grease?
__________________
Riley
My Registry
My Ranger Build
rileyrs is offline   Reply With Quote
Old 06-21-2010, 11:47 PM   #3
Brian1
Albuquerque, NM
Brian1's Avatar
1991 XLT
Vehicle Specs
Yes that is the proper procedure for the inner nut. The torque is to seat the bearing then you back it off to give it the proper preload. If it is too tight maybe the inner nut rotated while you were torquing the outer nut? That sometimes happens to me.
Brian1 is online now   Reply With Quote
Old 06-21-2010, 11:49 PM   #4
mechjames
Richmond, BC
mechjames's Avatar
1994 Explorer XLT
Vehicle Specs
(Original Poster)
Quote:
As much as humanly possible
Old 06-21-2010, 11:51 PM   #5
mechjames
Richmond, BC
mechjames's Avatar
1994 Explorer XLT
Vehicle Specs
(Original Poster)
Quote:
I don't see how that is possible with the warn it. The little pin on the inner nut lines up with the washer and locks with the keyway on the axle.
I don't remember changing the wheel dust seal on the back when I did it last time. I changed them both this time.
It also looked really dirty in the hub side. I'm wondering if it is possible that while switching a tire at one time, the hub o-ring sort of fell off and wasn't installed correctly.
Good to know that the preload is set properly.
Old 06-21-2010, 11:53 PM   #6
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
The little washer with the holes can move in the keyway some which allows it to tighten up some. Also, its easy to break or knock in the pins on the bigger nuts which allows them to turn independant of the holed washer.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is online now   Reply With Quote
Old 06-22-2010, 12:48 AM   #7
4x4junkie
So.Calif.(San Fernando Valley)
'94 Ranger, '90 Bronco II
Vehicle Specs
Agreed, I've had the tab try to ride up out of the spindle groove once also (damaging the threads in the process, allowing it to ride up that much easier on subsequent tightenings).
Fortunately it's pretty easy to see if this has happened by the inner nut turning with the outer nut.
The way I do mine:
Tighten inner nut to 35ft-lbs
Back off ½ turn,
Retighten to 15 INCH-lbs (or about hand tight with the socket)
Install locking ring (flip it over if the pin doesn't line up, do not turn the nut)
Tighten outer nut to 225-250ft-lbs, making sure the inner nut doesn't turn with it.
__________________
'90 Bronco II XLT
5" lift (Skyjacker jeep coils), locked D35 & 8.8", 5.13s, double T-case, 35x12.50s & cut fenders
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 06-22-2010, 02:08 AM   #8
mechjames
Richmond, BC
mechjames's Avatar
1994 Explorer XLT
Vehicle Specs
(Original Poster)
The way I do mine:
Back off ½ turn,
I pretty much do the same, except I only back off 90 degrees (1/4 turn) so that would just about account for your 1/2 turn and tightning hand tight.
Except tighting the outer nut to 225-250 ft lbs. I followed the instructions and tightened it to 85 ft lbs.
Old 06-22-2010, 12:09 PM   #9
nitro71
Spokane WA
Vehicle Specs
I take it you replaced the race also? I use a differenty method myself. I tighten them up till I don't get any wheel wobble and it still spins smoothly. If it feels to tight I back it off till it smooths out again. I know, unscientific.
nitro71 is offline   Reply With Quote
Old 06-22-2010, 12:13 PM   #10
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Thats more how I do it now..
I tighten the inner nut a bunch then back it off then hand tighten it (no socket). Then I put on the washer then the outer nut and crank down on the outer nut. I don't have the pins in my nuts anymore and I watch the inner nut. It can move a "little" but if it moves too much I use a punch and hammer to knock it back a hair.
Its more by "feel" now than any torque method. If I use the proper technique they come loose too quickly with 33's.
~Mark
__________________
Old 06-22-2010, 06:57 PM   #11
Riceburner247
Riceburner247's Avatar
'92 EB
Vehicle Specs
~Mark
Lol, 33's with 3.75" offset here. I tighten the inner so that there is a slight drag, then tighten the outer using my 1/2 drive impact gun on the highest setting. Done this procedure so many times now, it's like clockwork.
__________________
I burn rice 24/7.
Riceburner247 is offline   Reply With Quote
Old 07-16-2012, 08:05 PM   #12
adamsbro2
Clearfield, UT
adamsbro2's Avatar
93 XLT
Vehicle Specs
Ok. question then? Im running 35s is there a wheel bearing thats better than the next? In the past ive only put on the cheapo bearings and they lasted fine but i have ruined the passenger 2 weeks after the lift and tires, then today lost the drivers side!! I guess i need to look into what grease i use and what bearings i get cause im sure ill be replacing the spindle on the drivers side this time!
__________________
The Hulk '93 Explorer 5.5" Superlift, 35x12.50x15 BFG KM2s, 4.56 gears, Eaton E Locker rear, 96 Ranger knuckle and brake swap, Dynomax Turbo Cat Back Exhaust, Front bumper from jamscal with warn xd9000i winch, coming hopefully this year front sas with 4.88 gears and locker in front.
Build Thread/Elite Registry http://www.explorerforum.com/forums/...d.php?t=356278
Bryan
adamsbro2 is offline   Reply With Quote
Old 07-17-2012, 07:51 AM   #13
Flip4ford
Newton, KS
94' Sport
Vehicle Specs
Temeber not to greaese the actual spindle where the bearing rides. I tighted mine outer to 150lbs that's according the chilton's.
__________________
Flip
'94 Exlpoder/8500 Winch
4:56 Gears/Stubbler
Lockers Front/Rear
6" Susp Lift/SOA/BII Tank
33"x12.5"x15's BFG MT
Flip4ford is online now   Reply With Quote
Old 07-17-2012, 09:34 AM   #14
Anime
GREEN SCREAM!!
Hattiesburg, MS
Anime's Avatar
'93 Sport 4x4
Vehicle Specs
Quote:
Timken, SKF, National all make great bearings and seals. Any brand name high-temp wheel bearing grease that meets NLGI #2 and API GL-5/GC-LB should do the job well if you pack the bearings good and put enough in the seal as well. I like the Castrol grease but even store brand grease is good if it meets the specs.
If you have 35's you just need to keep up with the wheel bearing torque and make sure nothing is coming loose. It's a really good idea to jack up the wheel/tire and check for bearing play after installing bearings and having driven for awhile, or just as a safety precaution after some heavy trail use or even just every so often.
__________________
"I think man has always gone where he has been able to go, and I think that when man stops going where he can go, he will have lost a lot. Man has always been an explorer. To me, there's a fascination in thrusting out and going to new places. It's like going through a door because you find the door in front of you." - Michael Collins
Anime is offline   Reply With Quote
Old 07-17-2012, 08:15 PM   #15
4x4junkie
Vehicle Specs
I use Timken bearings (SET-37). Never have had any issues with them using the tightening sequence I posted earlier above.
__________________
'90 Bronco II XLT
'94 Ranger XLT
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
