| 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Home | Register | Members Rides | Vendors | Top Posters | FAQ/Rules | Social Groups | Search | Today's Posts | Mark Forums Read |
| Need for Speed! Explorer, Ranger, Mountaineer 4.0 - 4.6 - 5.0 Nitrous, Superchargers, Camshafts, Head Work, Stroker Kits... DRAG RACING. Explorers, Mountaineers and Rangers CAN move! |
Thread Tools |
#701 |
va beach
92 SC
That's the way i have mine and getting all kinds of slippage ;(i wonder if your m90 uses the same bolt pattern on the snout,if so you can use the same add on pulley i am.
__________________ 92 xl 5.5"duff arms,3"BL,PJ 36x14.50,wrapped headers,side dump exhaust,.20 over,HF oil pump,422cam,45cc 95tm p+p 10.67:1 heads,p+p lower manifold,75mm TB,90mm maf,36lbs injectors,P+P GM M90 Supercharged & intercooled!!SCT tuned!!electric fan,4.88s aussie locked front & back!!next NOS&W/M
http://www.explorerforum.com/forums/...=double+vision |
#702 |
Supercharged OHV
Winnipeg, Manitoba
00 Explorer XLT 4.0 OHV
shit.
I looked at yours, and figured mine had a slight bit more wrap than yours. If your getting all kinds of slipping, then Im not going to be much better off than you. I might have to stick with original configuration, and the gatorback. I'll maybe try one size smaller of belt in my original configuration, as it might fit with the smaller pulley. If my tensioner is tight there is more wrap on the alternator. At least the shorter belt will work fine for the highway, as the next couple of weekends are going to be spent on it. That belt wrap kit might work for me also. I think the rotors from yours work on mine with the positioning pins moved around There is really no way to know for sure, other than buying one and trying it. __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#703 |
va beach
92 SC
I personally would leave it the way you have it and look into a belt wrap kit.the way you have it is the way its ran from factory besides the sc.belt wrap would properly fix the problem without affecting any other pulley.really odd that green belt stretched,I've read they are pretty stiff and never seen anything bad about them.soon your have a belt collection like me and now i need two new ones!!lol
#704 |
Supercharged OHV
Winnipeg, Manitoba
hahaha..ya, if I break a belt, I have an assortment to choose from to limp home, thats for sure.
I think the belt wrap kit you are looking at will work as far as bolt spacing. Im a bit concerned about the snout length though. Worst case, I could shorten the length of the idler pulley arm on the kit. I'll take the plunge and order one. __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#705 |
va beach
92 SC
O yea you are totally right.the snout is different.i just got home so ill do some searching in a bit.they have to make one.i didnt find those by searching but in some threads.
#706 |
Supercharged OHV
Winnipeg, Manitoba
I'm off to be the wildlife for a few days camping. I checked with Ron and he has one for the sohc. He sent me a pic of it, but I need to see how it mounts.
I'll pick this up next week. __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#707 | |
va beach
92 SC
http://www.explorerforum.com/forums/...=double+vision Last edited by jd4242; 08-04-2012 at 01:35 PM. |
#708 | |
Resident Gearhead
Lake Villa, Illinois
'03 XLT 4.6
Quote:
__________________ 2003 4.6 V8 XLT Black Explorer, Kenne Bell 2.2 Supercharger, VT Billet bottom end, MPH 2.5 Heads, Blower cams, A1000 custom fuel system, and on and on... 2009 6.6 V8 Pontiac G8 GT, Twin Turbo, 402ci, Turbocam, Circle D Built 6L80E, Circle D 3000 Stall, new fuel system on its way...Shooting for 750+rwhp and easy middle 10's. 2002 4.0 V6 Explorer Sport, CAI, Gibson Exhaust... 2005 3.9 V8 Lincoln LS, KBX Performance Garrett Turbo System...Sold... |
#709 |
va beach
92 SC
The belt wrap kit im going to be using.its made for the gm snout so its 2" longer.they both use the same bolt pattern for the snout where it mounts,so it appears he can just cut it down for the shorter ford snout and it would work.we cant seem to find one made for the ford charger,maybe belt slip wasn't as big as an issue for them as it is for the gm charger.here is a pic of it but on a car,i haven't gotten mine in yet.
http://www.explorerforum.com/forums/...=double+vision Last edited by jd4242; 08-04-2012 at 08:46 PM. |
#710 |
Supercharged OHV
Winnipeg, Manitoba
Here is what Ron made at BansheeSupercharger for the SOHC's.
I'll have to have a close look at mine and see if he is mounting to the block, or the heads. I understand the block is very similar, so with the picture I should be able to eye it up. If I can find some aluminum, I might be able to make something like he has done if the mounting points dont look like they will fit the ohv. __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#711 |
Supercharged OHV
Winnipeg, Manitoba
next pic
#712 | |
va beach
92 SC
http://www.explorerforum.com/forums/...=double+vision Last edited by jd4242; 08-07-2012 at 04:20 PM. |
#713 |
Supercharged OHV
Winnipeg, Manitoba
I havn't had a chance to look yet, but I'm sure your right.
#714 |
va beach
92 SC
Shoot i hope im wrong and you see something i don't,would be a nice easy fix for both of us and both type of motors
#715 |
Wannabe Elite Explorer
96.5
Do you want pictures of the one off my instacharger?
#716 |
va beach
92 SC
absolutely!!!
you have the ohv right?
#717 |
Supercharged OHV
Winnipeg, Manitoba
Phix, we would love a picture. All idea's are good idea's.
I'm still enjoying the benefits of low down torque, and can't feel the belt slip, but at higher rpm's Im sure there is power being left on the table. hahaha....you beat me. Yes, Im pretty sure Phix has the ohv. __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#718 | |
va beach
92 SC
Quote:
yea pretty sure he does to.if you look at both our chargers and drew a center line down the motor you can see yours sits more towards the passenger side where mine sits more towards the drivers.so it looks like you have a little more belt wrap than me.i can hear it when i gas it hard and feel it at WOT.the true way to tell is to log it and you can see it with the maf tables and something else,or that's how my tuner saw it when i was on dyno.then my belt stretched and its just real bad now
http://www.explorerforum.com/forums/...=double+vision Last edited by jd4242; 08-07-2012 at 04:21 PM. |
#719 |
Supercharged OHV
Winnipeg, Manitoba
hahaha....its funny that we are stretching belts so badly.
So far, I am still finding the gatorbacks seem to stretch the least. __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#720 | |
va beach
92 SC
Quote:
once i get this belt slip fixed I've got a little something up my sleeve that I've been working on and next set of dyno number should be WAY better![]() ![]()
http://www.explorerforum.com/forums/...=double+vision Last edited by jd4242; 08-07-2012 at 04:22 PM. |
| Suggest this thread to friends: |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1999 Ford Explorer 4.0 SOHC swap to 4.0 OHV | Pckid212 | Stock 1995 - 2001 Explorers | 33 | 02-06-2013 03:12 PM |
| Brandon's mild 4.0 OHV build | Brandon96 | Need for Speed! | 633 | 01-23-2012 01:59 AM |
| 98 EGR tube (4.0 V6 OHV) | brukshut | Stock 1995 - 2001 Explorers | 8 | 10-18-2010 06:49 PM |
| Eddie Bauer Question | erixon | Stock 1995 - 2001 Explorers | 9 | 09-08-2009 11:43 PM |
| Tranny code between 95 ohv and 97 ohv. | jasonphan | Stock 1995 - 2001 Explorers | 5 | 08-17-2009 11:06 AM |
| Thread Tools | |
