Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
95 explorer check engine light hesitation PLEASE help
Reply
Thread Tools
Old 04-21-2004, 01:02 AM   #1
ajb03
Northwest
'95 XLT
Vehicle Specs
(Original Poster)
Exclamation 95 explorer check engine light hesitation PLEASE help
Ok guys im new here and tried to search on the topic but here it goes...
Pretty much since I bought my 95 Explorer XLT v6 the check engine light has come on, it would occasionally lag a little or "miss" while driving, which wasnt a big deal until earlier today, when it would miss whenever I put my foot on the gas or whenever it was idling.... basically the car is mis-firing the entire time its on, shaking and lagging badly in response.
Now thats the problem, but when I did a little research before when the CEL first started coming on I had found out from a friend that the 95-96 explorers had problems like that, something to do with the ignition module?
ive done a little more research tonight and found out that maybe my Mass Airflow Sensor (MAS) needs to be cleaned? any help would be greatly appreciated guys, thanks in advance!!
ajb03 is offline   Reply With Quote
Old 04-21-2004, 11:39 AM   #2
mhn3773
C.A
91 zuki
Vehicle Specs
the only thing i can think of is to have the code pulled...sry i know its not much help
mhn3773 is offline   Reply With Quote
Old 04-21-2004, 02:16 PM   #3
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
Get the code and it will at least point you in the right direction. Once you do, come back here and tell us the exact numeric code! (not what someone said it meant)
Glacier991 is offline   Reply With Quote
Old 04-21-2004, 02:46 PM   #4
wmdpalmer
Eglin FL
98 Exploder XLT
Vehicle Specs
Checkers will do a free diagnosis for you
will
wmdpalmer is offline   Reply With Quote
Old 04-21-2004, 02:54 PM   #5
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
Vehicle Specs
Most if not all '95's are EEC-IV/OBD-1, which means you can pull the codes yourself with nothing more than a paper clip (www.dalidesign.com/hbook/eectest.html). In addition to bringing back the code number, don't forget to note which type of code (KOEO hard fault, continuous memory, or KOER) it is. It can make a difference in how you approach the problem.
__________________
Mr. Shorty
92 XLT 4x4
87 Bronco II XLT 4x4
'98 Chev K1500 Suburban SLT 4x4
MrShorty is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
My Advice on Check Engine Light Ira Under the Hood 10 03-03-2006 05:08 PM
Check engine light on 91 Explorer Ira Under the Hood 16 01-27-2000 06:59 PM
Rough Idle, Check Engine Light Butcher99 Under the Hood 1 07-27-1999 02:34 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
