EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Torsion Bar Removal and Installation FMC Spec's
Reply
Thread Tools
Old 06-15-2003, 12:19 AM   #1
Campo
Elitus Explorus
White City, KS
Campo's Avatar
99 XLT 4x4
Vehicle Specs
(Original Poster)
OK all,
I was able to acuire info, from a very trusted and loyal FMC Senior Master Mechanic, so I'm posting the R&R of Torsion Bars FMC style and spec's
Enjoy...
SECTION 204-01A: Front Suspension — 4x2 1999 Explorer/Mountaineer Workshop Manual
REMOVAL AND INSTALLATION Procedure revision date: 11/28/2001
Bar —Torsion
Special Tool(s) Bolt Set
T96T-5310-B
Torsion Bar Tool
T95T-5310-AR
Removal
WARNING: The electrical power to the air suspension system must be shut off prior to hoisting, jacking or towing an air suspension vehicle. This can be accomplished by turning off the air suspension switch located in the rear jack storage area. Failure to do so can result in unexpected inflation or deflation of the air springs or shocks, which can result in shifting of the vehicle during these operations.
Raise the vehicle on a hoist. For additional information, refer to Section 100-02.
Remove the torsion bar cover plate.
Remove the torsion bar cover plate bolts.
NOTE: Before relieving the torsion bar tension, measure and record the measurement of the torsion bar adjustment bolt. This measurement will be used as the preset depth for the new torsion bar adjustment bolt during installation.
Make preliminary adjustment references.
Measure and record the length where indicated.
Relieve the torsion bar tension.
Position the Torsion Bar Tool and adapters.
Tighten the Torsion Bar Tool until the torsion bar adjuster lifts off the adjustment bolt.
CAUTION: The torsion bar adjustment bolt is coated with dry adhesive and must be replaced if it is backed off or removed. Failure to do so can cause the adjustment bolt to loosen during operation and cause a loss of vehicle alignment.
Remove the torsion bar adjustment bolt and nut.
Loosen the Torsion Bar Tool until the tension is removed from the torsion bar.
Remove the torsion bar.
Mark the torsion bar and the adjuster for proper installation.
Remove the torsion bar insulator.
Grasp the torsion bar and pull it free from the front suspension lower arm.
Installation
Position the torsion bar and the torsion bar adjuster.
Install the torsion bar adjuster.
Align the marks on the torsion bar and the torsion bar adjuster, then install the torsion bar adjuster.
Position the torsion bar insulator.
Preload the torsion bar.
Install the Torsion Bar Tool and the adapters.
Tighten the Torsion Bar Tool until the new adjustment bolt and nut can be installed.
Turn the adjustment bolt until the preliminary adjustment measurement (recorded length of the old adjustment bolt) is reached.
Remove the tool.
Install the torsion bar cover plate.
Position the torsion bar cover plate.
Install the torsion bar cover plate bolts.
NOTE: If equipped with air suspension, reactivate the system by turning on the air suspension switch.
Lower the vehicle.
Adjust the ride height. For additional information, refer to Ride Height in this section.
Check the alignment. For additional information, refer to Section 204-00.
__________________
If it ain't broke, fix it till it is.
99 XLT 4x4 SOHC V6 2"TT/AAL 31" Kelly AT's aka Blue Mistress
96 Ranger ExCab 4x4 OHV V6 31" Goodyear RT/S's (not for long)
KC Area Explorers
Campo is offline   Reply With Quote
Old 06-15-2003, 07:33 AM   #2
JDraper
Elite Garage Builder
McVeytown, PA
JDraper's Avatar
'11 XLT
Vehicle Specs
Lemme just add a footnote to this. I just put a new set of torsion bars in an Explorer, and I would suggest not buying the torsion bar puller. You're better off buying a universal gear puller that has the capability of changing from a 3 jaw puller to a 2 jaw puller (torsion bars require the 2 jaw setup). It works just as well, costs considerably less, and has many more uses.
I was doing a 4" Superlift for a friend, and the kit was purchased with a tool just for removing and installing torsion bars. I ended up tossing that aside and using my gear puller. It was easier to use.
__________________
Moderator..Home Improvement/Explorer 911/2011 Explorer Forum
You took my breath away....and now I want it back....
'66 Mustang Coupe, '04 Mustang Mach 1, '08 Focus, '11 Explorer XLT
"Ex"plorer's: '92 Sport, '94 Sport, '01 XLS
Our Crappy Website
JDraper is offline   Reply With Quote
Old 02-05-2007, 10:17 AM   #3
khoward
Pelahatchie Ms,
'92 XLT
Vehicle Specs
does a 92 4x4 have torsion bars
khoward is offline   Reply With Quote
Old 02-05-2007, 10:22 AM   #4
Dan Whitaker
One fast putty tat
Raytown MO (Kansas City suburb)
Dan Whitaker's Avatar
No Mounty no more.
Vehicle Specs
No they don't. They have TTB Which I believe stands for Twin Traction Beam but don't quote me on that.
Search in the 91-94 Forums and you will find your answer for sure.
__________________
P r i c k me, do I not bleed Ford Blue.
Dan Whitaker is offline   Reply With Quote
Old 03-06-2007, 06:50 PM   #5
tenikiwon
Yakima, WA
tenikiwon's Avatar
02 F250/Zuk twins
Vehicle Specs
Torsion Bar options
Aren't there different options for torsion bars? I'd like to get stiffer ones if possible and I thought there was a post on here about them. In any case this thread would make a perfect place for that.
Reference to torsion bar codes.
__________________
Gone wheel'n......I wish
Andrew J. Nowicki
The FORD III - 2002 F250 7.3L PowerStroke Diesel - Tow Vehicle
Zuk Twins (87 & 88.5) Suzuki Samurai <-- It's a Samurai thing even I don't understand.
My Home on the Web
tenikiwon is offline   Reply With Quote
Old 04-08-2007, 06:35 PM   #6
bennettcl
Olathe, KS
1998 Explorer Eddie Bauer
Vehicle Specs
question
When you say "CAUTION: The torsion bar adjustment bolt is coated with dry adhesive and must be replaced if it is backed off or removed. Failure to do so can cause the adjustment bolt to loosen during operation and cause a loss of vehicle alignment."
Does that mean replace the entire bolt???? Or do you mean make sure you put some dry adhesive on the threads before putting the bolt back in? If you mean replace the entire bolt, where can you get the new bolts at???
bennettcl is offline   Reply With Quote
Old 05-28-2007, 09:32 PM   #7
Bob McNabb
1999 4x4 ranger
Vehicle Specs
Ranger Torsion Bar Crack
My torsion bar cracked while in 4wd. Road was a little rugged but not that bad. What would cause this? Metal fatigue or something? what about wear of other front end suspension parts would that cause the bar to crack? what should I look for? Link rod (that goes to lower control arm seems to have bad rubber) ANy help or suggestions would be GREAT. Can I drive the truck at low speed 6 miles to the shop without damaging anything?
Bob McNabb is offline   Reply With Quote
Old 05-29-2007, 12:42 AM   #8
97awdx
Lake Wallenpaupack, PA
2002 XLS
Vehicle Specs
You can drive it at a very very low speed. The a-arm is going to be against the bump stop so it will ride like crap.
97awdx is offline   Reply With Quote
Old 07-08-2007, 01:45 PM   #9
scruff
Atlanta, GA
2000 Limited chassis only
Vehicle Specs
Bennetcl
Dry adhesive just means that bolt ius locktited in there. Ford uses this blue stuff that looks like blue paint on a lot of chassis parts, it's a pain to get them out.
So you don't need to replace the bolt, just renew the locktite.
__________________
Ford Explorer chassis under 1951 F1
http://www.explorerforum.com/forums/...d.php?t=174298
http://picasaweb.google.com/stragedy/ProjectTruck
< home < home for now
scruff is offline   Reply With Quote
Old 09-14-2007, 10:03 AM   #10
hardywo
Washington, DC
'97 XLT Stick
Vehicle Specs
US
Quote:
Originally Posted by JDraper View Post
[COLOR=darkblue]Lemme just add a footnote to this. I just put a new set of torsion bars in an Explorer, and I would suggest not buying the torsion bar puller. You're better off buying a universal gear puller that has the capability of changing from a 3 jaw puller to a 2 jaw puller (torsion bars require the 2 jaw setup). It works just as well, costs considerably less, and has many more uses.[COLOR]
I can get this from Harbor Freight's website for $13, well $20 with shipping...sound about right price-wise? This is what you're talking about, right? Thanks for the advice.
__________________
~Bill
My site
97 XLT Stick - Lift: TT w/ longer bolts, Advance Auto Parts shackles, F-150 leaf mod (6 freshly painted red leaves total now), 3" BL(just need to make bumper brackets now).
hardywo is offline   Reply With Quote
Old 11-20-2008, 08:16 PM   #11
danrathexplorer
Bethlehem PA
96 XLT 4 Door 4.0
Vehicle Specs
torsion bars
yo does anyone make new torsion bar keys to give more lift without having the torsion bars jacked up all the time? i know they make them for other trucks like the gm fullsize
danrathexplorer is offline   Reply With Quote
Old 11-21-2008, 08:45 AM   #12
Cobraguy
Phoenix...Greatest City on Earth
Cobraguy's Avatar
1995 EB & 1999 EB 5.0
Vehicle Specs
I just used a two jaw puller...not sure how to make two of a three jaw puller work where they aren't opposite each other...but regardless...Draper is dead on the money. Don't buy the special tool.
__________________
http://banners.wunderground.com/weat...AZ/Phoenix.gif
Quote:
Originally Posted by four0sport
she is a girl, there are no answers, only more questions!
Cobraguy is offline   Reply With Quote
Old 12-21-2008, 06:49 PM   #13
ehosterman
Vehicle Specs
What size gear puller do you use?
ehosterman is offline   Reply With Quote
Old 10-02-2009, 04:02 PM   #14
jrjr2u
Upstate NY near Rochester
97 sport
Vehicle Specs
Sorry to resurrect an old thread but..... this seems an appropriate place.
I am replacing both torsion bars on a 97 sport, and putting in '1' bars. I have both rear ends loose and swinging in the breeze and now am trying to get the bars loose in front.
I have a solid bar about 4' long placed in from the front on the torsion bar and have wacked the crap out of it with about a 2 pound hammer but the bar is not moving at all.
I have sprayed with PB blaster several times.
Am I mistaken in that they should move rearward to be taken out? Should I be driving them from the rear toward the front? OR should I just get a sledge and try more force? Seems to me like heat would not be a good thing as its probably tempered in the bar seats.....
Input please!!!
jrjr2u is offline   Reply With Quote
Old 10-02-2009, 04:22 PM   #15
Dan Whitaker
One fast putty tat
No Mounty no more.
Vehicle Specs
You need someone to hold the rear of the torsion bar up. With it dangling it is going to cause binding.
It is a pain to get them out. I would also recomend letting the PB set awhile then try it.
__________________
Old 10-02-2009, 04:23 PM   #16
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
Well, it should slide rearward. Try whacking a bit harder---
However,
My son's truck held on to the driver side bar, and wouldn't let it go even with the whole arm in my 20 ton shop press.
Sometimes they are shtuck. In this case you need a new control arm and bars
__________________
Jon
2000 Mountaineer
Turdle-gone
Vitamin D Wagon Sold also
Turdle is online now   Reply With Quote
Old 10-02-2009, 04:40 PM   #17
Dan Whitaker
One fast putty tat
No Mounty no more.
Vehicle Specs
If you live in snow country and they use a lot of salt you are fighting a loosing battle.
__________________
Old 10-02-2009, 05:37 PM   #18
patrick112390
chesterfield,va
97' mountaineer 5.0 4406
Vehicle Specs
you dont even have to have any puller at all... just unbolt the shock and UCA at the knuckle with the LCA supported by a jack and lower st till it droops. the bar will fall out.-----to load it up do the opposite. jack it up
__________________
97' mountaineer 5.0 V8 4406- k&n intake, hunter brush guard, shackles, TT, aal front/rear tow hooks, 35X14.50 Mud Grapplers, crager soft 8 rims, remote start, cb, 3'' pa body lift, 4'' superlift, 4406 swap, 4.88 gears and a full carrier Detroit Locker
patrick112390 is offline   Reply With Quote
Old 10-02-2009, 05:49 PM   #19
jrjr2u
97 sport
Vehicle Specs
Quote:
However,
Thanks all for the input.
What do you all think about heating the socket? All I have is an acetylene torch (B Tank) so it's not like a cutting torch heat, but still pretty hot.....
I will move to the other side tomorrow. The PB will have had a while to soak in and see how that one goes. I will also have some help tomorrow too...
Oh, and yes, I am in upstate NY near Rochester... lots of salt on the winter roads.
Thanks again!
Old 10-03-2009, 03:34 PM   #20
jrjr2u
97 sport
Vehicle Specs
Got them out!
Drivers side came out by heating with the acetylene torch and beating with a 10 pound mall. Couldn't get the passenger side to budge so I borrowed an oxy/acetylene torch and that did the trick.
Many thanks to my buddy that dared to hold the bar while I was taking full swings at the end!
Ex is all back together now and it seems to have worked out well. When I lift the plow now it only slightly sags.... about 2" which I deem good enough.
I set the adjuster bolts at the same length as the original and it lifted the truck one inch even by having new and stronger bars.
Ride is nice too.... firm but yet not too firm..... I am happy
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
