Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks 2011 Explorer Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Troubleshooting - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
Thread Tools
Old 12-18-2003, 05:57 PM   #1
CoryL
Louisville, KY
CoryL's Avatar
94 Eddie Bauer
Vehicle Specs
Advance Adapters 700R4 Conversion Parts Available NOW!!!
We've been waiting a long time for these parts and they are now available!
That tired A4LD can be tossed aside for a much more reliable 700R4 GM transmission. With the lowest first gear out of all automatics and OD, it is the most sought after automatic transmission. From rock crawlers to daily drivers, it will be a substantial upgrade.
This kit is designed to work with the 700R4 that came behind a 2.8L GM motor. There are two parts you need.
1) The Bellhousing Kit. This kit comes with a new bellhousing adapter plate, torque converter adapter ring, crank bushing, necessary hardware, and instructions.
2) The Transfer Case Kit. This kit comes with a new output shaft for the transmission and the transfer case adapter.
Using both will allow you to keep your stock driveshafts and transmission crossmember.
You may need slight exhaust modifications.
You will be required to purchase a torque converter lock-up kit and TV kickdown cable. The TV cable and bracket are available from Bowtie Overdrive (760) 947-5240.
This will also allow you to use different transfer cases. If you wanted to run a Bronco D20 you now can. Likewise, you could run a flipped Jeep D300 t-case.
Retail from Advance Adapters is $956.20.
However, if you give us a call and mention ExplorerForum.com we will drop the price $150. That would put you at $806.20 + shipping. Almost 20% off retail price!
Call us M-F, 9am - 6pm Eastern and Saturday, 11am-3pm Eastern @ (502) 962-8141 and ask for Cory.
__________________
"You ever kill anybody?"
"I hurt someone's feelings once."
Moab Off-Road / Accessories and Custom Fabrication
CoryL is offline
Sponsored Links (Less Ads)
Old 12-18-2003, 07:01 PM   #2
TheRookie
Traveling SAS guru
West Chester PA
TheRookie's Avatar
91 explorer xlt
Vehicle Specs
YESSS Great to see this available. Is this using the torque converter from the a4 or the 700r? If I had the cash right now I would already have this from you. SOON
__________________
Then: 91 XLT or currie 9's, lots of mods
Now: Bone stock Zuk waiting to get cut up
Check out our new clubs forum at www.Get-BentOffroad.com/forum
TheRookie is offline
Old 12-18-2003, 08:29 PM   #3
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Cory,
Couple of questions to clarify a few things
WHat happens to my floor shifter, I have the floor shifter from a 84 Bronco II with the bell crank and shift linkage (not the Explorer column mount cable shift). I assume the plan would be to install an aftermarket shifter that matches the 700R4 shift pattern (Same as A4LD?)
What wiring or computer changes are required?
How is the new kick down cable installed? to the TB or to the pedal?
Just curious. When my A4LD kicks it I was planning to run a C5/4 but I may opt for the 700R4 due to the OD and the increased T case choices.
Also what modifications are considered "minimal" to the 60 - degree 700R4? Obviously its a good idea to rebuild it, but I have heard they are not much more reliable then an A4LD unless they are upgraded...
I also assume the price is cheaper for the bellhousing /converter adapter if you opt for a different T case?
Can there be a discount if we purchase an Atlas II at the same time as the adapter??
Thanks!!! This should prove to be a GOOD seller!!!
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline
Old 12-19-2003, 08:21 AM   #4
CoryL
Louisville, KY
CoryL's Avatar
94 Eddie Bauer
Vehicle Specs
To my knowledge you need a TQ converter from a 700R4. The adapter ring is merely that small spacer that converts the pattern from the crank to the GM flexplate.
1) Floor shifter. Aftermarket for a 700R4 would probably be easier than anything else. They don't specify one way or the other if you can reuse your own shifter, but I would assume you cannot.
2) No computer modifications are needed. The only wiring you need to do is for the Neutral Safety Switch and they provide instructions on how to do that.
3) They do not provide the TV cable or bracket, but I would assume it goes to the TB.
4) From what I know of the 700R4s, make sure you get one built after 1987. Prior to that they were unreliable and not much better than the 700R4. Some things I know that most people do are installing a shift kit. reverse manual valve body, and a Corvette servo.
5) If you opt for a different t-case, possibly one that was a driver's side drop that came bolted to a 700R4 would mean only needing to purchase the bellhousing kit. That kit alone would run you $437.25.
If you wish to purchase both an Atlas 2 and this adapter, please call me and we can try to work something out.
__________________
CoryL is offline
Old 12-19-2003, 10:17 AM   #5
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Thanks Cory!
Yes I WISH to purchase an Atlas II along with the adapter and also along with a custom 700R4, maybe someday my wish will come true!!!
Merry X mas!
__________________
Old 12-21-2003, 09:39 PM   #6
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL
Vehicle Specs
Here is a link to the Advance Adapters write up regarding the 700R4. http://www.advanceadapters.com/projects/40lford.html
For those who don't know that is Kevin McInchak's Explorer from this site. Kevin is Diff Whack Daddy.
__________________
Rick Horwitz, AB7FH "Serious Exploration's" Admin
Rick's '93/'98 Explorer
Dodge Dart 512 Resto/Race
2004 Mustang Mach 1
2003 Dodge Ram/Cummins Dually
Rick is offline
Old 12-22-2003, 03:04 PM   #7
Kris Guilbeaux
Demon Secretary
Austin,Tx
Kris Guilbeaux's Avatar
92 Nav, 99 Mounty, 98 Ex
Vehicle Specs
So we can Keep the Stock coloum shifter?
This is One thing I have bee wondering.
__________________
Kris Guilbeaux
1992 Mazda Navajo
1998 Ford Explorer Eddie bauer
1999 Mercury Mountaineer V-8
There are more but I am tired of typing how many I own ..
Kris Guilbeaux is offline
Old 12-23-2003, 09:01 AM   #8
CoryL
Louisville, KY
CoryL's Avatar
94 Eddie Bauer
Vehicle Specs
I am not sure, but I wouldn't think so since the shifting patterns and brackets are totally different.
__________________
CoryL is offline
Old 12-23-2003, 09:49 AM   #9
IAmTodd
IAmTodd's Avatar
2006 Saab 9-3 Aero
Vehicle Specs
This is a question that I have always been asking, but yet to get an answer, Is this a replacement for the 4R55E too? I would think you would have to get a manual computer since the computer controls the tranny, but that would be the only difference. Will you need custom driveshafts? or will the dimensions work out to be all the same?
IAmTodd is offline
Old 12-23-2003, 10:40 PM   #10
TheRookie
Traveling SAS guru
West Chester PA
TheRookie's Avatar
91 explorer xlt
Vehicle Specs
Todd that is a great question. Hopefully it will get answered. It may be that it has not yet been tried. As of today my 5th YES FIFTH a4ld is acting a little strange. The question is will it last long enouigh for the 302 or will I have to get this to hold me over
__________________
Old 12-24-2003, 08:48 AM   #11
CoryL
Louisville, KY
CoryL's Avatar
94 Eddie Bauer
Vehicle Specs
Quote:
Not sure on the computer. I will call them when we reopen and find out for sure. I think it would depend on if the computer needs the feedback from the tranny. If all the computer does is tell it how and when to shift, you shouldn't need a different one. If the computer gets feedback from the tranny in order to determine air/fuel mix based on gearing, then a manual comptuer may be needed.
I do know that you will not need custom driveshafts if you use the BW1350/4 t-case. The overall length is almost identical.
__________________
CoryL is offline
Old 12-28-2003, 12:44 PM   #12
Brett
Moderator Emeritus
Littleton, CO
94 Explorer Sport
Vehicle Specs
What GM transfer case options came with the 2.8 700r4?
__________________
Brett
94 Explorer Sport
4.0L SOHC
Brett is offline
Old 12-29-2003, 04:52 PM   #13
CoryL
Louisville, KY
CoryL's Avatar
94 Eddie Bauer
Vehicle Specs
Quote:
I think the stock option was an NP241.
__________________
CoryL is offline
Old 12-29-2003, 05:45 PM   #14
Brett
Moderator Emeritus
Littleton, CO
94 Explorer Sport
Vehicle Specs
Okay,
What are the other options w/o buying the tailhousing adapter or tailshaft?
Brett
__________________
Brett
94 Explorer Sport
4.0L SOHC
Brett is offline
Old 01-10-2004, 01:17 PM   #15
Elder Elemental Evil
Demon4x4 Member
Mo. City, TX
Elder Elemental Evil's Avatar
1991 Demon Edition
Vehicle Specs
Cory, what is your price on just the tranny bellhousing kit? It's the only piece I need to finish
__________________
Demon4x4.com - Wheelin' Demons
1991 Garage Edition
IF YOU'RE GONNA USE IT, ABUSE IT!!
Elder Elemental Evil is offline
Old 01-12-2004, 09:26 AM   #16
CoryL
Louisville, KY
CoryL's Avatar
94 Eddie Bauer
Vehicle Specs
Tranny bellhousing kit = $354.90 + shipping.
__________________
CoryL is offline
Old 01-13-2004, 01:49 PM   #17
rocklaurence
Lakeland,Fl
93 SPORT
Vehicle Specs
Finally! This opens so many options related to the 700. Such as, torque converters, shift kits etc. One more question, I bet that you can use a non-lock up converter with the 700. Cool!
__________________
151K miles but always something new--6"suspenion,2"B/L,4:56 gears, Locked front and rear, 37"Boggers, custom bumpers & nerf bars, 8000 winch, Dual batteries, Ifab intake, BBK T/B, Borla headers, SuperChip, P&P heads, RV cam.
rocklaurence is offline
Old 01-13-2004, 01:54 PM   #18
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL
Vehicle Specs
I've driven Kevin's Explorer (diffwhackdaddy). His was the first to have the 700R4 swap. That thing is sweet!! The 700R4 has a very low first gear ratio so it launches very hard. Shifts are very positive. Can't say enough good things about it
__________________
2004 Mustang Mach 1
Rick is offline
Old 01-13-2004, 01:55 PM   #19
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Rick do I see one in your future?
__________________
Old 01-16-2004, 10:30 PM   #20
Digital_Hate
chino,ca
96 Ranger
Vehicle Specs
does anyone know if this will fit the Ford ranger 4.0 that came with the 4r55e trans
Digital_Hate is offline
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
Copyright 2010 - 1996 Rick Horwitz Photography
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
