4x4 dash light fix after 1354E to 1354M swap | Ford Explorer Forums - Serious Explorations
mr cribb
US Army Retired
Naylor, MO
98 Z71, 89 stepside
I spent a good 2 hours searching this issue, and no luck.
I recently swapped out my Electric 1354 for a Manual 1354.
What I am looking for is the wire colors to tap into to make the 4x4 and low range lights work on the dash.
I still need to get the plug from the junkyard, because I forgot that.
Thanks.
Why do you want the lights to work?
I bought the harness today from the junkyard.
My OCD is now solved.
Was wondering if you had a write up of the swap. I am also wanting to swap to the manual Transfer.
Thank you sir
Thank you sir
There's nothing really noteworthy with the swap. Finding all the parts was the hard part. I got the case from one yard, the shifter and harness from another. It will run easily $300 if you get it all from one yard. Some salvages think the case is a magical part and charging $250 just for the case.
The hardest part I had, was making the shifter bezels match. Then again I was a 5 speed so I had two bezels to piece together. They did make a one piece bezel for the double stick people, but I think that's more rare than the manual case itself.
It was a simple swap. The top bolt on the transmission/ transfer case is entertaining to get to unless you have small hands. The only thing I suggest is make sure the speedometer gears match, because I had to swap mine. It's an easy one bolt item.
Thank you sir. Now time for a hunt. :)
